[+] Jak uruchomi
ksysinek
[+] Jak uruchomić program inSSIDer?
Post autor: ksysinek »
Czy komukolwiek z Was udało się uruchomić program inSSIDer na Debianie Squeeze z GNOME? U mnie się nie da. Próbując w konsoli dostaję:
Unhandled Exception: System.ComponentModel.Composition.CompositionException: The composition produced a single composition error. The root cause is provided below. Review the CompositionException.Errors property for more detailed information.
1) org.freedesktop.DBus.Error.InvalidArgs: No such property PermHwAddress
Resulting in: An exception occurred while trying to create an instance of type 'MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager'.
Resulting in: Cannot activate part 'MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager'.
Element: MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager --> MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager --> DirectoryCatalog (Path="/usr/share/inssider/Components")
Resulting in: Cannot get export 'MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager (ContractName="MetaGeek.inSSIDer.Common.Network.NetworkManager")' from part 'MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager'.
Element: MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager (ContractName="MetaGeek.inSSIDer.Common.Network.NetworkManager") --> MetaGeek.inSSIDer.LinuxNetworkManager.Model.NixNetworkManager --> DirectoryCatalog (Path="/usr/share/inssider/Components")
Resulting in: An exception occurred while trying to create an instance of type 'MetaGeek.inSSIDer.NetworkManager.NetworkController'.
Resulting in: Cannot activate part 'MetaGeek.inSSIDer.NetworkManager.NetworkController'.
Element: MetaGeek.inSSIDer.NetworkManager.NetworkController --> MetaGeek.inSSIDer.NetworkManager.NetworkController --> DirectoryCatalog (Path="/usr/share/inssider/Components")
Resulting in: Cannot get export 'MetaGeek.inSSIDer.Common.Network.INetworkController (ContractName="MetaGeek.inSSIDer.Common.Network.INetworkController")' from part 'MetaGeek.inSSIDer.NetworkManager.NetworkController'.
Element: MetaGeek.inSSIDer.Common.Network.INetworkController (ContractName="MetaGeek.inSSIDer.Common.Network.INetworkController") --> MetaGeek.inSSIDer.NetworkManager.NetworkController --> DirectoryCatalog (Path="/usr/share/inssider/Components")
Resulting in: Cannot set import 'MetaGeek.inSSIDer.Controller.MainViewController.MyNetworkController (ContractName="MetaGeek.inSSIDer.Common.Network.INetworkController")' on part 'MetaGeek.inSSIDer.Controller.MainViewController'.
Element: MetaGeek.inSSIDer.Controller.MainViewController.MyNetworkController (ContractName="MetaGeek.inSSIDer.Common.Network.INetworkController") --> MetaGeek.inSSIDer.Controller.MainViewController
  at System.ComponentModel.Composition.CompositionResult.ThrowOnErrors (System.ComponentModel.Composition.Hosting.AtomicComposition atomicComposition) [0x00000] in <filename unknown>:0
  at System.ComponentModel.Composition.CompositionResult.ThrowOnErrors () [0x00000] in <filename unknown>:0
  at System.ComponentModel.Composition.Hosting.ImportEngine.SatisfyImportsOnce (System.ComponentModel.Composition.Primitives.ComposablePart part) [0x00000] in <filename unknown>:0
  at System.ComponentModel.Composition.Hosting.CompositionContainer.SatisfyImportsOnce (System.ComponentModel.Composition.Primitives.ComposablePart part) [0x00000] in <filename unknown>:0
  at System.ComponentModel.Composition.AttributedModelServices.SatisfyImportsOnce (ICompositionService compositionService, System.Object attributedPart) [0x00000] in <filename unknown>:0
  at MetaGeek.inSSIDer.Common.Extensions.ExtensionManager.Satisfy (IExtensionConsumer consumer) [0x00000] in <filename unknown>:0
  at MetaGeek.inSSIDer.Controller.MainViewController.CreateInstances () [0x00000] in <filename unknown>:0
  at MetaGeek.inSSIDer.Controller.MainViewController..ctor () [0x00000] in <filename unknown>:0
  at MetaGeek.inSSIDer.Inssider..ctor () [0x00000] in <filename unknown>:0
  at MetaGeek.inSSIDer.Inssider.Main (System.String[] args) [0x00000] in <filename unknown>:0
krzys@Samsung:~$ sudo inssider
krzys@Samsung:~$ clear
krzys@Samsung:~$ inssider
Może byś tak podał jakieś informacje o systemie, karcie WIFI i źródle pobrania programu, inaczej zostaje Ci napisać podanie do wróżki.
http://debian.linux.pl/threads/12771-Za ... #post81406
Sama informacja, że to Debian Squeeze to zbyt mało. Uzupełnij.
ksysinek
Debian 6.0.3 z jądrem 2.6.32-5-686 (32bit). Moja karta sieciowa to Intel 5100 AGN.
Program inSSIDer ściągnąłem >stąd<.
I rozwiązałem problem. W katalogu była jeszcze do ściągnięcia łatka. Zainstalowałem zgodnie z instrukcjami:
* Make sure you have installed inSSIDer-0.1.1.0429 beta.
* Copy attached MetaGeek.inSSIDer.LinuxManager.dll to /usr/share/inssider/Components/
* Copy attached MetaGeek.inSSIDer.Extensions.NewsFeed.dll to /usr/share/inssider/Extensions/
(you might need sudo permission to execute above steps)
i działa!
Przepraszam za zawracanie głowy. Przynajmniej przyszłe pokolenia próbujące zainstalować inSSIDer na Debianie będą wiedziały, że należy nałożyć łatę.
Temat do zamknięcia.
