Mam problem z Calibre, gdy próbuję włączyć miga tylko ikonka i nic się nie dzieje. Po wpisaniu w konsoli:
calibreKod: Zaznacz cały
Traceback (most recent call last):
File "/usr/bin/calibre", line 19, in <module>
sys.exit(main())
File "/usr/lib/calibre/calibre/gui2/main.py", line 338, in main
app, opts, args, actions = init_qt(args)
File "/usr/lib/calibre/calibre/gui2/main.py", line 50, in init_qt
from calibre.gui2.ui import Main
File "/usr/lib/calibre/calibre/gui2/ui.py", line 31, in <module>
from calibre.gui2.widgets import ProgressIndicator
File "/usr/lib/calibre/calibre/gui2/widgets.py", line 24, in <module>
from calibre.gui2.progress_indicator import ProgressIndicator as _ProgressIndicator
File "/usr/lib/calibre/calibre/gui2/progress_indicator/__init__.py", line 15, in <module>
pi_error)
RuntimeError: Failed to load the Progress Indicator plugin: the PyQt4.QtCore module is version 1 but the progress_indicator module requires version -1Używam Debiana Wheezy oraz KDE4.
