Jakie sterowniki karty graficznej s
mscigniew
[+] Jakie sterowniki karty graficznej są w użyciu - radeon czy vesa?
Post autor: mscigniew »
Compiz-check wypisuje, że mam uruchomiony sterownik vesa:
$ ./compiz-check
Gathering information about your system...
 Distribution:          Debian GNU/Linux (wheezy/sid)
 Desktop environment:   KDE4
 Graphics chip:         ATI Technologies Inc RV730 Pro AGP [Radeon HD 4600 Series]
 Driver in use:         vesa
 Rendering method:      AIGLX
Checking if it's possible to run Compiz on your system...  [SKIP]
 Checking for hardware/setup problems...           [SKIP]
At least one check had to be skipped:
 Error: vesa driver in use
Would you like to know more? (Y/n) y
 The vesa driver is not capable of running Compiz, you need to install
 the proper driver for your graphics card.
Jednakże efekty pulpitu działają prawidłowo, wydajność grafiki też jest niezła.
$ lsmod | grep radeon
radeon                579902  3
ttm                    47307  1 radeon
drm_kms_helper         22688  1 radeon
drm                   129847  5 radeon,ttm,drm_kms_helper
i2c_algo_bit           12722  1 radeon
i2c_core               19141  5 i2c_viapro,radeon,drm_kms_helper,drm,i2c_algo_bit
power_supply           13283  1 radeon
Polecenie:
$ lsmod | grep vesa
nie daje żadnego rezultatu.
$ lspci -k
00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge
        Subsystem: ASUSTeK Computer Inc. A7V8X motherboard
        Kernel driver in use: agpgart-via
00:01.0 PCI bridge: VIA Technologies, Inc. VT8235 PCI Bridge
00:0f.0 Network controller: Texas Instruments ACX 100 22Mbps Wireless Interface
        Subsystem: Global Sun Technology Inc WL-8305 IEEE802.11b+ Wireless LAN PCI Adapter
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
        Subsystem: ASUSTeK Computer Inc. A7V8X-X motherboard
        Kernel driver in use: uhci_hcd
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82)
        Subsystem: ASUSTeK Computer Inc. A7V8X-X motherboard rev 1.01
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
        Subsystem: ASUSTeK Computer Inc. A7V8X-X motherboard rev. 1.01
        Kernel driver in use: pata_via
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
        Subsystem: ASUSTeK Computer Inc. A7V8X-X Motherboard
        Kernel driver in use: VIA 82xx Audio
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 74)
        Kernel driver in use: via-rhine
01:00.0 VGA compatible controller: ATI Technologies Inc RV730 Pro AGP [Radeon HD 4600 Series]
        Subsystem: Giga-byte Technology HD4650
        Kernel driver in use: radeon
01:00.1 Audio device: ATI Technologies Inc RV710/730
        Subsystem: Giga-byte Technology Device aa38
        Kernel driver in use: HDA Intel
Tutaj też jest napisane, że sterownik to radeon. Wnioskuję, że działają otwarte sterowniki radeon, ale wolę się upewnić.
Wskazuje na rendering sprzętowy.
A dokładniejsze info o sterowniku wyświetli polecenie:
glxinfo
A jakbyś się tak sam upewnił, przeglądając dokładniej forum:
http://debian.linux.pl/threads/12771-Za ... #post81406
, jesteś pewien, a nie logi?
mscigniew
Czyli wszystko OK. Dzięki za pomoc.
