[+] SSH i brak wpisów do pliku /var/log/lastlog
r0ster
Post autor: r0ster »
Kiedy użytkownik wykonuje zdalne polecenie np.
ssh [b]użytkownik[/b]@host '[I]polecenie[/I]'
lub kiedy się loguje z opcją -T:
ssh  [b]użytkownik[/b]@host [B]-T[/B]
informacje o zalogowaniu (w /var/log/lastlog) nie są zapisywane.
Jest jakiś sposób, żeby zablokować tego typu logowania do systemu, albo żeby wymusić logowanie do pliku /var/log/lastlog w takich przypadkach?
Mój system:
Debian Squeeze 6.0
openssh-server 1:5.5p1-6
markossx
Post autor: markossx »
Jakie masz wpisy w sshd_config dotyczące logowania?
r0ster
Zawartość pliku sshd_config:
# Package generated configuration file
# See the sshd(8) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
Banner /etc/ssh/banner.txt
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
UsePAM yes
Nie ma tu nic "innego". To jest domyślna konfiguracja OpenSSH dla Debiania, za wyjątkiem banera. Chyba, że coś się zmieniło od wersji 5.0 Debiana.
markossx
Dobrze wygląda. Jakiego podsystemu logowania używasz?
r0ster
markossx pisze:Dobrze wygląda. Jakiego podsystemu logowania używasz?
Przy tym pytaniu wymiękam.
Czy chodzi Ci o PAM i tego czy używam LDAP/SQL/plików? Jeśli tak, to używam standardowych plików psswd/shadow/itp.
Jak nie, to byłbym wdzięczny gdybyś sprecyzował pytanie, lub dał jakiś przykład.
markossx
Przepraszam jeśli niezrozumiale napisałem, chodziło mi co zapisuje Twoje logi: syslogd, czy rsyslog a może coś innego?
r0ster
rsyslog
markossx
No, raczej spróbuj przy tym pokombinować :)
r0ster
A mógłbym spytać, czy u Ciebie występuje to samo? Czy system loguje połączenie przez SSH z opcją -T?
markossx
Tak, loguje i dlatego wybrałem taki wektor.
ssh -T *@*
Sep 18 20:56:22 mi* sshd[12233]: Accepted password for * from 192.168.*.* port 46873 ssh2
Sep 18 20:56:22 mi* sshd[12233]: pam_unix(sshd:session): session opened for user * by (uid=0)
Sep 18 20:56:31 mi* sshd[12233]: pam_unix(sshd:session): session closed for user *
A co masz w pliku /var/log/auth.log? Może dobrze jest napisane ale nie tam sprawdzasz gdzie należy?
Ja te informacje wyciągam właśnie z pliku /var/log/auth.log.
