Aktualizacja Debiana zg
wirus133
Aktualizacja Debiana zgłasza błąd
Post autor: wirus133 »
Mam Debiana6, zainstalowałem go z serwerem ssh i systemem podstawowym.
Dodałem repozytoria:
deb [URL]http://security.debian.org/[/URL] lenny/updates main
deb-src [URL]http://security.debian.org/[/URL] lenny/updates main
deb [URL]http://volatile.debian.org/debian-volatile[/URL] lenny/volatile main
deb-src [URL]http://volatile.debian.org/debian-volatile[/URL] lenny/volatile main
deb [URL]http://ftp.pl.debian.org/debian/[/URL] squeeze main
deb-src [URL]http://ftp.pl.debian.org/debian/[/URL] squeeze main
deb [URL]http://security.debian.org/[/URL] squeeze/updates main
deb-src [URL]http://security.debian.org/[/URL] squeeze/updates main
# squeeze-updates, previously known as 'volatile'
deb [URL]http://ftp.pl.debian.org/debian/[/URL] squeeze-updates main
deb-src [URL]http://ftp.pl.debian.org/debian/[/URL] squeeze-updates main
i po wpisaniu
apt-get update
wyświetla
Pob: 13 [URL]http://ftp.pl.debian.org[/URL] squeeze-updates Release.gpg [6973 B]
Pob: 14 [URL]http://ftp.pl.debian.org/debian/[/URL] squeeze-updates/main Translation-en [6973 B]
Pob: 15 [URL]http://ftp.pl.debian.org/debian/[/URL] squeeze-updates/main Translation-pl [6973 B]
Pob: 16 [URL]http://volatile.debian.org[/URL] lenny/volatile Release [6973 B]
Pob: 17 [URL]http://ftp.pl.debian.org[/URL] squeeze Release [6973 B]
Pob: 18 [URL]http://ftp.pl.debian.org[/URL] squeeze-updates Release [6973 B]
Pob: 19 [URL]http://security.debian.org[/URL] lenny/updates Release [6973 B]
Pob: 20 [URL]http://security.debian.org[/URL] squeeze/updates Release [6973 B]
Ign [URL]http://volatile.debian.org[/URL] lenny/volatile Release
Pob: 21 [URL]http://volatile.debian.org[/URL] lenny/volatile/main Sources/DiffIndex [6973 B]
Pob: 22 [URL]http://volatile.debian.org[/URL] lenny/volatile/main i386 Packages/DiffIndex [6973 B]
Ign [URL]http://ftp.pl.debian.org[/URL] squeeze Release
Pob: 23 [URL]http://volatile.debian.org[/URL] lenny/volatile/main Sources [6973 B]
Pob: 24 [URL]http://ftp.pl.debian.org[/URL] squeeze/main Sources/DiffIndex [6973 B]
Pob: 25 [URL]http://volatile.debian.org[/URL] lenny/volatile/main i386 Packages [6973 B]
Pob: 26 [URL]http://ftp.pl.debian.org[/URL] squeeze/main i386 Packages/DiffIndex [6973 B]
Pob: 27 [URL]http://ftp.pl.debian.org[/URL] squeeze/main Sources [6973 B]
Ign [URL]http://ftp.pl.debian.org[/URL] squeeze-updates Release
Pob: 28 [URL]http://ftp.pl.debian.org[/URL] squeeze/main i386 Packages [6973 B]
Pob: 29 [URL]http://ftp.pl.debian.org[/URL] squeeze-updates/main Sources/DiffIndex [6973 B]
Pob: 30 [URL]http://ftp.pl.debian.org[/URL] squeeze-updates/main i386 Packages/DiffIndex [6973 B]
Ign [URL]http://security.debian.org[/URL] lenny/updates Release
Pob: 31 [URL]http://ftp.pl.debian.org[/URL] squeeze-updates/main Sources [6973 B]
Pob: 32 [URL]http://security.debian.org[/URL] lenny/updates/main Sources/DiffIndex [6973 B]
Pob: 33 [URL]http://security.debian.org[/URL] lenny/updates/main i386 Packages/DiffIndex [6973 B]
Pob: 34 [URL]http://ftp.pl.debian.org[/URL] squeeze-updates/main i386 Packages [6973 B]
Pob: 35 [URL]http://security.debian.org[/URL] lenny/updates/main Sources [6973 B]
Ign [URL]http://security.debian.org[/URL] squeeze/updates Release
Pob: 36 [URL]http://security.debian.org[/URL] lenny/updates/main i386 Packages [6973 B]
Pob: 37 [URL]http://security.debian.org[/URL] squeeze/updates/main Sources/DiffIndex [6973 B]
Pob: 38 [URL]http://security.debian.org[/URL] squeeze/updates/main i386 Packages/DiffIndex [6973 B]
Pob: 39 [URL]http://security.debian.org[/URL] squeeze/updates/main Sources [6973 B]
Pob: 40 [URL]http://security.debian.org[/URL] squeeze/updates/main i386 Packages [6973 B]
Pobrano 279 kB w 0s (1610 kB/s)
Czytanie list pakietów... Błąd!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/security.debian.org_dists_lenny_updates_main_binary-i386_Packages
E: Nie udało się otworzyć lub zanalizować zawartości list pakietów.
root@rdns2-144:~#
Dzień wcześniej instalowałem Debiana na wirtualnej maszynie z dokładnie tymi samymi repozytoriami (kopiuj wklej).
Szukałem z pomocą Google i znalazłem rozwiązanie.
rm /var/lib/apt/lists/* -vf
Niestety to nic nie pomaga. Po wpisaniu:
 apt-get update
mam dokładnie takie same błędy.
Co źle zrobiłem, że to nie działa? Dystrybucja i386, a procesor athlon, czy to ma jakiś wpływ na apt-get?
W czasie instalacji systemu nie mogłem dodać adresów serwerów lustrzanych. Wyświetlał błąd. Więc zainstalowałem bez serwerów lustrzanych.
A po co mieszasz Lenny ze Squeeze, to mieszanie Debiana w wersji 5 i 6. Aktualne wpisy to Squeeze czyli wersja 6.
wirus133
Przepraszam za błędy.
Niestety wszystkie repozytoria nie działają (Lenny, Squeeze). Jest dokładnie taki sam błąd.
Czy to może być wina że przy instalacji wybrałem żeby nie korzystał z serwerów lustrzanych? Może coś trzeba włączyć doinstalować? Może źle ustawiona sieć? Korzystam z DHCP.
Bastian
Post autor: Bastian »
Co masz aktualnie w pliku /etc/apt/sources.list?
