apt-get install php-pear
Budowanie drzewa zależności
php-pear jest już w najnowszej wersji.
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
Checking system for dependencies...
Checking gettext: [B]YES[/B] Language support enabled
Checking Pear(DB): [B]NO[/B] Pear DB NOT FOUND This is required. Please download from [URL]http://pear.php.net/package/DB/download[/URL] .
Checking GD: [b]YES[/b] GD support enabled
Please, click the link below to test your graph system capabilities (Bacula-web only use PNG):
[url=http://localhost/bacula-web/external_packages/phplot/examples/test_setup.php]Test[/URL]
root@TESTpcpr:/home/delleg# pear list
Installed packages, channel pear.php.net:
Package Version State
Archive_Tar 1.3.7 stable
Console_Getopt 1.3.1 stable
DB 1.7.14RC2 beta
PEAR 1.9.3 stable
Structures_Graph 1.0.4 stable
XML_Util 1.2.1 stable
root@TESTpcpr:/home/delleg# dpkg -l | grep apache
ii apache2 2.2.16-6+squeeze1 Apache HTTP Server metapackage
ii apache2-doc 2.2.16-6+squeeze1 Apache HTTP Server documentation
ii apache2-mpm-prefork 2.2.16-6+squeeze1 Apache HTTP Server - traditional non-threaded model
ii apache2-utils 2.2.16-6+squeeze1 utility programs for webservers
ii apache2.2-bin 2.2.16-6+squeeze1 Apache HTTP Server common binary files
ii apache2.2-common 2.2.16-6+squeeze1 Apache HTTP Server common files
ii libapache2-mod-perl2 2.0.4-7 Integration of perl with the Apache2 web server
ii libapache2-mod-php5 5.3.3-7+squeeze1 server-side, HTML-embedded scripting language (Apache 2 module)
ii libapache2-mod-python 3.3.1-9+b1 Python-embedding module for Apache 2
ii libapache2-reload-perl 0.10-2 Reload Perl modules when changed on disk
root@TESTpcpr:/home/delleg# dpkg -l | grep php
ii php-db 1.7.13-2 PHP PEAR Database Abstraction Layer
ii php-pear 5.3.3-7+squeeze1 PEAR - PHP Extension and Application Repository
ii php5 5.3.3-7+squeeze1 server-side, HTML-embedded scripting language (metapackage)
ii php5-cli 5.3.3-7+squeeze1 command-line interpreter for the php5 scripting language
ii php5-common 5.3.3-7+squeeze1 Common files for packages built from the php5 source
ii php5-gd 5.3.3-7+squeeze1 GD module for php5
ii php5-mysql 5.3.3-7+squeeze1 MySQL module for php5
ii php5-suhosin 0.9.32.1-1 advanced protection module for php5
Wymagane pakiety masz zainstalowane.
Restartowałeś usługę apache po instalacji pakietów (choć podczas instalacji powinna zostać zrestartowana automatycznie)?
