Mam następujący, dość irytujący problem. Otóż polecenie:
ifconfig
root@rb800:~# ifconfig
: error fetching interface information: Device not found
root@rb800:~# ifconfig -a
root@rb800:~# ifconfig eth0
eth0 Link encap:Ethernet HWaddr 00:0c:42:xx:xx:xx
inet addr:192.168.57.244 Bcast:192.168.57.255 Mask:255.255.255.0
inet6 addr: fe80::20c:42ff:fe72:ab16/64 Scope:Link
RX packets:923 errors:0 dropped:0 overruns:0 frame:0
TX packets:206 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:78303 (76.4 KiB) TX bytes:30082 (29.3 KiB)
Base address:0x8000
root@rb800:~# ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr 00:0c:42:xx:xx:xx
BROADCAST MULTICAST MTU:1500 Metric:1
root@rb800:~# cat /etc/udev/rules.d/70-persistent-net.rules
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
# PCI device 0x1969:0x1063 (atl1c)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:0c:42:xx:xx:xx", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:0c:42:xx:xx:xx", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth1"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:0c:42:xx:xx:xx", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth2"
# PCI device 0x168c:0x0029 (ath9k)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:0c:42:xx:xx:xx", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
# PCI device 0x168c:0x001b (ath5k)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:0c:42:xx:xx:xx", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan1"
root@rb800:~# lspci
0000:00:00.0 Power PC: Freescale Semiconductor Inc MPC8544 (rev 11)
0000:00:0c.0 Ethernet controller: Atheros Communications Inc. AR5413 802.11abg NIC (rev 01)
0000:00:0d.0 Network controller: Atheros Communications Inc. AR922X Wireless Network Adapter (rev 01)
0001:01:00.0 PCI bridge: Freescale Semiconductor Inc MPC8544 (rev 11)
0002:03:00.0 PCI bridge: Freescale Semiconductor Inc MPC8544 (rev 11)
0003:05:00.0 PCI bridge: Freescale Semiconductor Inc MPC8544 (rev 11)
0003:06:00.0 Ethernet controller: Atheros Communications AR8131 Gigabit Ethernet (rev c0)
root@rb800:~# uname -a
Linux rb800 2.6.34.8-svn16418 #9 Tue Mar 29 11:50:57 CEST 2011 ppc GNU/Linux
