OSS4 5.1 - ustawienie CMedia na wszystkie kana
Kamilko
OSS4 5.1 - ustawienie CMedia na wszystkie kanały 5.1
Post autor: Kamilko »
Mmam kolejny problem, tym razem z OSS.
12:45:48root@kamilkolandhome/kamilko# dpkg -l | grep alsa
ii alsa-base 1.0.23+dfsg-2 ALSA driver configuration files
ii alsa-modules-2.6.32-5-amd64 1.0.23+dfsg-2+2.6.32-30 ALSA modules for kernel 2.6.32-5-amd64
ii alsa-oss 1.0.17-4 ALSA wrapper for OSS applications
ii alsa-source 1.0.23+dfsg-2 ALSA driver sources
ii alsa-tools 1.0.23-3+b1 Console based ALSA utilities for specific hardware
ii alsa-utils 1.0.23-3 Utilities for configuring and using ALSA
ii gstreamer0.10-alsa 0.10.30-1 GStreamer plugin for ALSA
rc libsdl1.2debian-alsa 1.2.14-6.1 Simple DirectMedia Layer (with X11 and ALSA options)
ii python-pyalsa 1.0.24-1 Official ALSA Python binding library
root@kamilkolandhome/kamilko# dpkg -l | grep oss
ii audacity 1.3.12-9 A fast, cross-platform audio editor
ii audacity-data 1.3.12-9 A fast, cross-platform audio editor (data)
ii krosspython 4:4.4.5-3 Python module for Kross
ii libao-common 1.0.0-5 Cross Platform Audio Output Library (Common files)
ii libao4 1.0.0-5 Cross Platform Audio Output Library
ii libflac++6 1.2.1-3 Free Lossless Audio Codec - C++ runtime library
ii libflac8 1.2.1-3 Free Lossless Audio Codec - runtime C library
ii libieee1284-3 0.2.11-6 cross-platform library for parallel port access
ii libkrosscore4 4:4.4.5-3 the Kross Core Library
ii libkrossui4 4:4.4.5-3 the Kross UI Library
ii libqca2-plugin-ossl 0.1~20070904-4 QCA OSSL plugin for libqca2
ii libwavpack1 4.60.1-1 an audio codec (lossy and lossless) - library
ii libwxgtk2.8-0 2.8.10.1-3+b1 wxWidgets Cross-platform C++ GUI toolkit (GTK+ runtime)
ii oss-compat 0.0.4+nmu3 OSS compatibility package
ii oss4-base 4.2-build2003-1 Open Sound System - base package
ii oss4-dev 4.2-build2003-1 Open Sound System - development files
ii oss4-dkms 4.2-build2003-1 Open Sound System - DKMS module sources
ii oss4-gtk 4.2-build2003-1 Open Sound System - simple GTK2-based mixer control
12:46:01root@kamilkolandhome/kamilko# ossinfo
Version info: OSS 4.2 (b 2003/201007150434) (0x00040100) GPL
Platform: Linux/x86_64 2.6.32-5-amd64 #1 SMP Wed Jan 12 03:40:32 UTC 2011 (kamilkoland)
Number of audio devices: 9
Number of audio engines: 17
Number of MIDI devices: 0
Number of mixer devices: 2
Device objects
0: osscore0 OSS core services
1: oss_cmpci0 CMedia CM8738 interrupts=241004 (241004)
2: oss_hdaudio0 ATI HD Audio interrupts=964 (37362)
HD Audio controller ATI HD Audio
Vendor ID 0x10024383
Subvendor ID 0x14627373
Codec 0: ALC888 (0x10ec0888/0x14627373)
3: oss_usb0 USB audio core services
MIDI devices (/dev/midi*)
Mixer devices
0: CMedia CMPCI (Mixer 0 of device object 1)
1: High Definition Audio ALC888 (Mixer 0 of device object 2)
Audio devices
[b]CMedia CM8768 (rev 68) /dev/oss/oss_cmpci0/pcm0 (device index 0)
CMedia CM8768 (playback only) /dev/oss/oss_cmpci0/pcm1 (device index 1)
HD Audio play front /dev/oss/oss_hdaudio0/pcm0 (device index 2)
HD Audio play rear /dev/oss/oss_hdaudio0/pcm1 (device index 3)
HD Audio play center/LFE /dev/oss/oss_hdaudio0/pcm2 (device index 4)
HD Audio play side /dev/oss/oss_hdaudio0/pcm3 (device index 5)
HD Audio play pcm4 /dev/oss/oss_hdaudio0/pcm4 (device index 6)
HD Audio rec mix /dev/oss/oss_hdaudio0/pcmin0 (device index 7)
HD Audio rec mix /dev/oss/oss_hdaudio0/pcmin1 (device index 8)[/b]
Nodes
/dev/dsp -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_in -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_out -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_ac3 -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_mmap -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_multich -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_spdifout -> /dev/oss/oss_cmpci0/pcm0
/dev/dsp_spdifin -> /dev/oss/oss_cmpci0/pcm0
Działają mi tylko dwa głośniki, a chciałbym wszystkie 5.1. Zauważyłem, że wszystko prawie jest ustawione na HD Audio (karta zintegrowana, wyłączona w biosie), używam CMedia, ale jest ustawiona tylko na dwie pozycje.
Tu moje pytanie - Jak ustawić właśnie CMedia na wszystkie kanały 5.1?
