modprobe forcedeth
kernel 2.6.16.29
moze ktos pomoze
#modinfo forcedeth Kod: Zaznacz cały
filename: /lib/modules/2.6.16.29/kernel/drivers/net/forcedeth.ko
license: GPL
description: Reverse Engineered nForce ethernet driver
author: Manfred Spraul <manfred@colorfullife.com>
alias: pci:v000010DEd00000373sv*sd*bc*sc*i*
alias: pci:v000010DEd00000372sv*sd*bc*sc*i*
alias: pci:v000010DEd00000269sv*sd*bc*sc*i*
alias: pci:v000010DEd00000268sv*sd*bc*sc*i*
alias: pci:v000010DEd00000038sv*sd*bc*sc*i*
alias: pci:v000010DEd00000037sv*sd*bc*sc*i*
alias: pci:v000010DEd00000057sv*sd*bc*sc*i*
alias: pci:v000010DEd00000056sv*sd*bc*sc*i*
alias: pci:v000010DEd000000DFsv*sd*bc*sc*i*
alias: pci:v000010DEd000000E6sv*sd*bc*sc*i*
alias: pci:v000010DEd0000008Csv*sd*bc*sc*i*
alias: pci:v000010DEd00000086sv*sd*bc*sc*i*
alias: pci:v000010DEd000000D6sv*sd*bc*sc*i*
alias: pci:v000010DEd00000066sv*sd*bc*sc*i*
alias: pci:v000010DEd000001C3sv*sd*bc*sc*i*
depends:
vermagic: 2.6.16.29 gcc-3.4
parm: max_interrupt_work:forcedeth maximum events handled per interrup t (int)
parm: optimization_mode:In throughput mode (0), every tx & rx packet w ill generate an interrupt. In CPU mode (1), interrupts are controlled by a timer . (int)
parm: poll_interval:Interval determines how frequent timer interrupt i s generated by [(time_in_micro_secs * 100) / (2^10)]. Min is 0 and Max is 65535.
