Po zainstalowaniu Nfdump i Nfsen program się uruchamia i zbiera statystyki (mechanizm netflow) z rutera Cisco ale po wejściu po przez przeglądarkę pokazuje mi:
ERROR: nfsend connect() error: Permission denied!
ERROR: nfsend - connection failed!!
ERROR: Can not initialize globals!
moja konfiguracja nfsen.conf
# NfSen master config file
# $Id: nfsen-dist.conf 22 2007-11-20 12:27:38Z phaag $
# Configuration of NfSen:
# Set all the values to fit your NfSen setup and run the 'install.pl'
# script from the nfsen distribution directory.
# The syntax must conform to Perl syntax.
# NfSen default layout:
# Any scripts, modules or profiles are installed by default under $BASEDIR.
# However, you may change any of these settings to fit your requested layout.
# Required for default layout
$BASEDIR = "/data/nfsen";
# Where to install the NfSen binaries
$BINDIR="${BASEDIR}/bin";
# Where to install the NfSen Perl modules
$LIBEXECDIR="${BASEDIR}/libexec";
# Where to install the config files
$CONFDIR="${BASEDIR}/etc";
# NfSen html pages directory:
# All php scripts will be installed here.
# URL: Entry point for nfsen: [URL]http://<webserver>/nfsen/nfsen.php[/URL]
$HTMLDIR = "/var/www/nfsen/";
# Where to install the docs
$DOCDIR="${HTMLDIR}/doc";
# Var space for NfSen
$VARDIR="${BASEDIR}/var";
# directory for all pid files
# $PIDDIR="$VARDIR/run";
# Filter directory
# FILTERDIR="${VARDIR}/filters";
# FORMATDIR for custom printing formats
# FORMATDIR="${VARDIR}/fmt";
# The Profiles stat directory, where all profile information
# RRD DBs and png pictures of the profile are stored
$PROFILESTATDIR="${BASEDIR}/profiles-stat";
# The Profiles directory, where all netflow data is stored
$PROFILEDATADIR="${BASEDIR}/profiles-data";
# Where go all the backend plugins
$BACKEND_PLUGINDIR="${BASEDIR}/plugins";
# Where go all the frontend plugins
$FRONTEND_PLUGINDIR="${HTMLDIR}/plugins";
# nfdump tools path
$PREFIX = '/usr/local/bin';
# nfsend communication socket
$COMMSOCKET = "/data/nfsen/var/run/nfsen.comm";
# BASEDIR unrelated vars:
# Run nfcapd as this user
# This may be a different or the same uid than your web server.
# Note: This user must be in group $WWWGROUP, otherwise nfcapd
# is not able to write data files!
$USER = "netflow";
# user and group of the web server process
# All netflow processing will be done with this user
$WWWUSER = "www";
$WWWGROUP = "www";
# Receive buffer size for nfcapd - see man page nfcapd(1)
$BUFFLEN = 200000;
# list of extensions for each collector. See argument -T
# for nfcapd(1) for more detailes.
# defaults to empty -> compatible to nfdump-1.5.8
# $EXTENSIONS = '';
# Example:
# $EXTENSIONS = 'all';
# $EXTENSIONS = '+3,+4';
# Directory sub hierarchy layout:
# Possible layouts:
# 0 default no hierachy levels - flat layout - compatible with pre NfSen versions
# 1 %Y/%m/%d year/month/day
# 2 %Y/%m/%d/%H year/month/day/hour
# 3 %Y/%W/%u year/week_of_year/day_of_week
# 4 %Y/%W/%u/%H year/week_of_year/day_of_week/hour
# 5 %Y/%j year/day-of-year
# 6 %Y/%j/%H year/day-of-year/hour
# 7 %Y-%m-%d year-month-day
# 8 %Y-%m-%d/%H year-month-day/hour
$SUBDIRLAYOUT = 1;
# Compress flows while collecting 0 or 1
$ZIPcollected = 1;
# Compress flows in profiles 0 or 1
$ZIPprofiles = 1;
# number of nfprofile processes to spawn during the profiling phase
# depends on how busy your system is and how many CPUs you have
# on very busy systems increase it to a higher value
$PROFILERS = 2;
# if the PROFILEDATADIR is filled up to this percentage, a warning message will be printed.
# set to 0 to disable the test
$DISKLIMIT = 98;
$PROFILERS = 6;
# Netflow sources
# Define an ident string, port and colour per netflow source
# Required parameters:
# ident identifies this netflow source. e.g. the router name,
# Upstream provider name etc.
# port nfcapd listens on this port for netflow data for this source
# set port to '0' if you do not want a collector to be started
# col colour in nfsen graphs for this source
# Optional parameters
# type Collector type needed for this source. Can be 'netflow' or 'sflow'. Default is netflow
# optarg Optional args to the collector at startup
# Syntax:
# 'ident' => { 'port' => '<portnum>', 'col' => '<colour>', 'type' => '<type>' }
# Ident strings must be 1 to 19 characters long only, containing characters [a-zA-Z0-9_].
%sources = (
'MYROUTER' => { 'port' => '9996', 'col' => '#0000ff', 'type' => 'netflow' },
# Low water mark: When expiring files, delete files until
# size = $low_water % of max_size
# typically 90
$low_water = 90;
# syslog facility for periodic jobs
# nfsen uses level 'debug', 'info', 'warning' and 'err'
# Note: nfsen is very chatty for level 'debug' and 'info'
# For normal operation, you may set the logging level in syslog.conf
# to warning or error unless you want to debug NfSen
$syslog_facility = 'local3';
# SYSLOG mess
# Log socket type: Most *NIX such as LINUX and *BSD are fine with 'unix'
# which is the default. You need to change that to 'stream' or 'inet' for
# some Solaris version 8/9, AIX and others ..
# You may set it to undef to prevent calling Sys::Syslog::setlogsock at all
# ( works for Solaris 10 and newer Sys::Syslog module
# If not defined at all, 'unix' is assumed unless for Solaris, which defaults to 'stream'
# $LogSocket = 'unix';
# Plugins
# Plugins extend NfSen for the purpose of:
# Periodic data processing, alerting-condition and alerting-action
# For data processing a plugin may run for any profile or for a specific profile only.
# Syntax: [ 'profile list', 'module' ]
# profile list: ',' separated list of profiles ( 'profilegroup/profilename' ),
# or '*' for any profile, '!' for no profile
# module: Perl Module name, equal to plugin name
# The profile list '!' make sense for plugins, which only provide alerting functions
# The module follows the standard Perl module conventions, with at least one
# function: Init(). See demoplugin.pm for a simple template.
# A file with the same name in the FRONTEND_PLUGINDIR and .php extension is automatically
# recongized as frontend plugin.
# Plugins are installed under
# $BACKEND_PLUGINDIR and $FRONTEND_PLUGINDIR
@plugins = (
# profile # module
# [ '*', 'demoplugin' ],
%PluginConf = (
# For plugin demoplugin
demoplugin => {
# scalar
param2 => 42,
# hash
param1 => { 'key' => 'value' },
# for plugin otherplugin
otherplugin => [
# array
'mary had a little lamb'
# Alert module: email alerting:
# Use this from address
$MAIL_FROM = [EMAIL="'service@smslowianin.pl'"]'service@smslowianin.pl'[/EMAIL];
# Use this SMTP server
$SMTP_SERVER = '192.168.0.1';
# Use this email body:
# You may have multiple lines of text.
# Var substitution:
# @alert@ replaced by alert name
# @timeslot@ replaced by timeslot alert triggered
$MAIL_BODY = q{
Alert [EMAIL="'@alert@'"]'@alert@'[/EMAIL] triggered at timeslot @timeslot@
# For the NfSen simulator include the section below.
# Nfsen Simulator
# The simulator requires, that you have already installed
# and configured NfSen. The simulation is based on already
# pre-colleted data, which you may get from another live
# NfSen system.
# Steps to setup the NfSen simulator:
# 1. Configure the sources of the live profile with the
# same names of the NfSen system, you take netflow data
# for the simulation. Set the port for each netflow source
# to 0 to prevent a collector to be started.
# Install NfSen with this config in a seperate directory
# 2. Copy the pre-collected data into the appropriate
# netflow directory of the live profile.
# 3. Configure the simulator using the parameters below
# Enable Simulation mode => $SIMmode = 1
# Configure the time window of the pre-collected data.
# tstart => Start of time window. yyyymmddhhmm
# tbegin => Optional parameter. Start of simulation
# profile exists already between tstart - tbegin
# tend => End of time window. yyyymmddhhmm
# cycletime => simulation time in seconds of a 5min slot
# Setting cycletime = 0 processes the cycles as fast as
# possible. Please note, if you test plugings, your
# cycletime needs to be at least the time required to
# process all plugins.
# 4. Start nfsen: ../nfsen start
# Simulation starts
# The simulator runs from tstart to tend and stops when tend
# is reached. You may stop the simulation at any given time
# using ./nfsen stop. To continue the simulation start NfSen
# again: ./nfsen start. You may reset the simulator at any
# given time using ./nfsen abort-reset. This stops the sumulation
# and rolls back to tstart. All profiles/alerts are deleted,
# so you may start from scratch again.
# Configure simulator parameters
# $SIMmode = 1;
# %sim = (
# 'tstart' => '200707100000', # Simulation data available from July 10th 2007 00:00
# 'tbegin' => '200707110000', # Simulation begins at July 11th 2007 00:00
# 'tend' => '200707112355', # Simulation ends at July 11th 2007 23:55
# 'cycletime' => '30', # 30s per 5min slot
1;Proszę o Pomoc.
