Serwer przestał przyjmować pocztę wysyłaną z wp.
Jeszcze dzisiaj działało:
ep 18 16:32:12 debian postfix/smtpd[3239]: connect from mx1.wp.pl[212.77.101.5]
Sep 18 16:32:12 debian postfix-policyd: connection from: 127.0.0.1 port: 37838 slots: 0 of 4096 used
Sep 18 16:32:12 debian postfix-policyd: rcpt=2, greylist=update, host=212.77.101.5 (mx1.wp.pl), from=zzz@wp.pl, to=zzz@sp206-kl2a.waw.pl, size=1340
Sep 18 16:32:12 debian postfix-policyd: rcpt=2, throttle_rcpt=clear(a), host=212.77.101.5, from=zzzz@wp.pl, to=zzzzi@sp206-kl2a.waw.pl, count=0/64(2), threshold=0%
Sep 18 16:32:12 debian postfix/smtpd[3239]: EF480C61DB: client=mx1.wp.pl[212.77.101.5]
Sep 18 16:32:13 debian postfix/cleanup[3242]: EF480C61DB: message-id=<4c94cd6b5d7502.96310430@wp.pl>
Sep 18 16:32:13 debian postfix/qmgr[2989]: EF480C61DB: from=<dzzzz@wp.pl>, size=1594, nrcpt=1 (queue active)
Sep 18 16:32:13 debian postfix/smtpd[3239]: disconnect from mx1.wp.pl[212.77.101.5]
Sep 18 16:32:13 debian postfix/smtpd[3249]: connect from localhost[127.0.0.1]
Sep 18 16:32:13 debian postfix/smtpd[3249]: 745E8C61DC: client=localhost[127.0.0.1]
Sep 18 16:32:13 debian postfix/cleanup[3242]: 745E8C61DC: message-id=<4c94cd6b5d7502.96310430@wp.pl>
Sep 18 16:32:13 debian postfix/qmgr[2989]: 745E8C61DC: from=<dzzzz@wp.pl>, size=2107, nrcpt=1 (queue active)
Sep 18 16:32:13 debian postfix/smtpd[3249]: disconnect from localhost[127.0.0.1]
Sep 18 16:32:13 debian amavis[2622]: (02622-02) Passed CLEAN, LOCAL [212.77.101.5] [212.77.101.240] <zzzz@wp.pl> -> <zzzz@sp206-kl2a.waw.pl>, Message-ID: <4c94cd6b5d7502.96310430@wp.p
l>, mail_id: x+86qLm3M6nd, Hits: -8.101, size: 1593, queued_as: 745E8C61DC, 406 ms
Sep 18 16:32:13 debian postfix/smtp[3246]: EF480C61DB: to=<zzzzi@sp206-kl2a.waw.pl>, relay=127.0.0.1[127.0.0.1]:10024, delay=0.61, delays=0.18/0.01/0.01/0.41, dsn=2.0.0, status=sent (250 2
.0.0 Ok, id=02622-02, from MTA([127.0.0.1]:10025): 250 2.0.0 Ok: queued as 745E8C61DC)
Sep 18 16:32:13 debian postfix/qmgr[2989]: EF480C61DB: removed
Sep 18 16:32:13 debian postfix/pipe[3250]: 745E8C61DC: to=<zzzzz@sp206-kl2a.waw.pl>, relay=dovecot, delay=0.09, delays=0.01/0.02/0/0.06, dsn=2.0.0, status=sent (delivered via dovecot servi
ce)Kod: Zaznacz cały
Sep 18 20:26:59 debian postfix/qmgr[3014]: 7E6CDC61DA: removed
Sep 18 20:27:26 debian postfix/smtpd[3828]: connect from mx1.wp.pl[212.77.101.5]
Sep 18 20:27:27 debian postfix/smtpd[3828]: NOQUEUE: reject: RCPT from mx1.wp.pl[212.77.101.5]: 554 5.7.1 <dzz@zzz.no-ip.pl>: Relay access denied; from=<dzzz@wp.pl> to=<dzzzz@dzzzo.no
-ip.pl> proto=ESMTP helo=<mx1.wp.pl>
Sep 18 20:27:27 debian postfix/smtpd[3828]: disconnect from mx1.wp.pl[212.77.101.5]
Sep 18 20:28:44 debian postfix/smtpd[3828]: connect from mx2.wp.pl[212.77.101.6]
Sep 18 20:28:44 debian postfix/smtpd[3828]: NOQUEUE: reject: RCPT from mx2.wp.pl[212.77.101.6]: 554 5.7.1 <zzzi@dzzz.no-ip.pl>: Relay access denied; from=<dzzz@wp.pl> to=<apoloniu
szzz@zzo.no-ip.pl> proto=ESMTP helo=<mx2.wp.pl>
Sep 18 20:28:44 debian postfix/smtpd[3828]: disconnect from mx2.wp.pl[212.77.101.6]
