Witam wszystkich ponieważ jestem tu pierwszy raz.
Może pomogę zakończyć temat z instalacją i uruchomieniem karty Zoltrix'a, którą z powodzeniem używam i instalowałem pod wieloma dystrybucjami.
Mój konfig:
Linux version 2.6.18-3-686 (Debian 2.6.18-7) (waldi@debian.org) (gcc version 4.1
.2 20061115 (prerelease) (Debian 4.1.1-20)) #1 SMP Mon Dec 4 16:41:14 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fffb000 (usable)
BIOS-e820: 000000001fffb000 - 000000001ffff000 (ACPI data)
BIOS-e820: 000000001ffff000 - 0000000020000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
511MB LOWMEM available.
On node 0 totalpages: 131067
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 126971 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 ASUS ) @ 0x000f5e30
ACPI: RSDT (v001 ASUS A7V600-X 0x42302e31 MSFT 0x31313031) @ 0x1fffb000
ACPI: FADT (v001 ASUS A7V600-X 0x42302e31 MSFT 0x31313031) @ 0x1fffb0b2
ACPI: BOOT (v001 ASUS A7V600-X 0x42302e31 MSFT 0x31313031) @ 0x1fffb030
ACPI: MADT (v001 ASUS A7V600-X 0x42302e31 MSFT 0x31313031) @ 0x1fffb058
ACPI: DSDT (v001 ASUS A7V600-X 0x00001000 MSFT 0x0100000b) @ 0x00000000
ACPI: PM-Timer IO Port: 0xe408
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:8 APIC version 16
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Detected 1833.216 MHz processor.
Built 1 zonelists. Total pages: 131067
Kernel command line: root=/dev/hda1 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512056k/524268k available (1543k kernel code, 11580k reserved, 574k data
, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 3669.61 BogoMIPS (lpj=7339228)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383fbff c1cbfbff 00000000 00000000 00000000
00000000 00000000
CPU: After vendor identify, caps: 0383fbff c1cbfbff 00000000 00000000 00000000 0
0000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1cbfbff 00000000 00000420 00000000 0000000
0 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
CPU0: AMD Sempron(TM) 2600+ stepping 01
Total of 1 processors activated (3669.61 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 4410k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf1970, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 9 10 11 12)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 7 9 10 11 12)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11 12) *15, disabled.
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
PCI: enabled onboard AC97/MC97 devices
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 15 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:02: ioport range 0xe400-0xe47f could not be reserved
pnp: 00:02: ioport range 0xe800-0xe81f has been reserved
pnp: 00:0e: ioport range 0x290-0x297 has been reserved
pnp: 00:0e: ioport range 0x370-0x375 has been reserved
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: ee000000-eeffffff
PREFETCH window: eff00000-f7ffffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
Simple Boot Flag at 0x3a set to 0x1
audit: initializing netlink socket (disabled)
audit(1168780994.804:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: Bypassing VIA 8237 APIC De-Assert Message
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
Time: tsc clocksource has been installed.
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 196k freed
input: AT Translated Set 2 keyboard as /class/input/input0
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
8139cp 0000:00:0a.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
8139cp 0000:00:0a.0: Try the "8139too" driver instead.
8139too Fast Ethernet driver 0.9.27
PCI: Enabling device 0000:00:0a.0 (0004 -> 0007)
ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 16 (level, low) -> IRQ 169
eth0: RealTek RTL8139 at 0xd800, 00:50:fc:a6:d2:91, IRQ 169
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:0f.1, from 14 to 1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0xa400-0xa407, BIOS settings: hda :D MA, hdb :p io
ide1: BM-DMA at 0xa408-0xa40f, BIOS settings: hdc :D MA, hdd :D MA
Probing IDE interface ide0...
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
SCSI subsystem initialized
libata version 2.00 loaded.
hda: WDC WD1600JB-00REA0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: ASUS DVD-E616P3, ATAPI CD/DVD-ROM drive
hdd: SONY CD-RW CRX210E1, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.0, from 0 to 9
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 185, io base 0x0000a000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.1, from 0 to 9
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 185, io base 0x00009800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.2, from 0 to 9
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 185, io base 0x00009400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.3, from 0 to 9
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:10.3: irq 185, io base 0x00009000
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
sata_via 0000:00:0f.0: version 2.0
ACPI: PCI Interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 177
sata_via 0000:00:0f.0: routed to hard irq line 0
ata1: SATA max UDMA/133 cmd 0xD400 ctl 0xD002 bmdma 0xB000 irq 177
ata2: SATA max UDMA/133 cmd 0xB800 ctl 0xB402 bmdma 0xB008 irq 177
scsi0 : sata_via
ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xD407
scsi1 : sata_via
ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xB807
ACPI: PCI Interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.4, from 0 to 9
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:10.4: irq 185, io mem 0xed000000
ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
hda: max request size: 512KiB
hda: 312581808 sectors (160041 MB) w/8192KiB Cache, CHS=19457/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 hda10 hda11 hda12 >
hdc: ATAPI 48X DVD-ROM drive, 512kB Cache
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA KT400/KT400A/KT600 chipset
agpgart: AGP aperture is 64M @ 0xf8000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Linux video capture interface: v2.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
PCI: Enabling device 0000:00:0e.0 (0004 -> 0006)
ACPI: PCI Interrupt 0000:00:0e.0[A] -> GSI 17 (level, low) -> IRQ 193
bttv0: Bt848 (rev 18) at 0000:00:0e.0, irq: 193, latency: 32, mmio: 0xef000000
bttv0: using: Zoltrix TV-Max [card=15,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
i2c-algo-bit.o: (0) scl=1, sda=1
i2c-algo-bit.o: (1) scl=1, sda=0
i2c-algo-bit.o: (2) scl=1, sda=1
i2c-algo-bit.o: (3) scl=0, sda=1
i2c-algo-bit.o: (4) scl=1, sda=1
i2c-algo-bit.o: bt848 #0 [sw] passed test.
bttv0: using tuner=0
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
tuner 0-0060: All bytes are equal. It is not a TEA5767
tuner 0-0060: chip found @ 0xc0 (bt848 #0 [sw])
tuner 0-0060: type set to 0 (Temic PAL (4002 FH5))
tuner 0-0061: chip found @ 0xc2 (bt848 #0 [sw])
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
input: PC Speaker as /class/input/input1
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:11.5 to 64
Real Time Clock Driver v1.12ac
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
input: ImExPS/2 Generic Explorer Mouse as /class/input/input2
ts: Compaq touchscreen protocol output
codec_read: codec 0 is not valid [0xfe0000]
PCI: Enabling device 0000:00:11.6 (0000 -> 0001)
ACPI: PCI Interrupt 0000:00:11.6[C] -> GSI 22 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:11.6 to 64
ACPI: PCI interrupt for device 0000:00:11.6 disabled
VIA 82xx Modem: probe of 0000:00:11.6 failed with error -13
Adding 522072k swap on /dev/hda5. Priority:-1 extents:1 across:522072k
EXT3 FS on hda1, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: [email]dm-devel@redhat.com[/email]
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
nvidia: module license 'NVIDIA' taints kernel.
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 169
NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-8776 Mon Oct 16 21:56:04 PDT 2006
agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
agpgart: Device is in legacy mode, falling back to 2.x
agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
eth0: no IPv6 routers present
sprzęt:
00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge (rev 80)
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI Bridge
00:0a.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0e.0 Multimedia video controller: Brooktree Corporation Bt848 Video Capture (rev 12)
00:0f.0 RAID bus controller: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:11.6 Communication controller: VIA Technologies, Inc. AC'97 Modem Controller (rev 80)
01:00.0 VGA compatible controller: nVidia Corporation NV11 [GeForce2 MX/MX 400] (rev b2)
i kernel
2.6.18-3-686
Po zainstalowaniu 'TVtime' trzeba jeszcze dodać odpowiednie aliasy. Ja dodałem do
/etc/modprobe.d/aliases taki wpis:
#i2c
alias char-major-89 i2c-devb
options i2c-algo-bit bit_test=1
# bttv
alias char-major-81 videodev
alias char-major-81-0 bttv
# Askey TV Capturer
#options bttv card=15 tuner=0 radio=0 pll=1 adc_crush=0
i w tym samym katalogu utworzyłem plik 'bttv' o zawartości
Dla pewności wykonuję jeszcze ładowanie modułu 'bttv' z parametrami karty:
i przeładowuję system:
oraz skanuję kanały poprzez:
co wcześniej ustalam podczas instalacji 'tvtime'a'. Nie ma sensu podawać tu listy, gdyż jej ustalenie jest zależne od częstotliwości nadawania w danej miejscowości.
Powinno wszystko "grać".
Może zajść potrzeba dopisania usera do grupy 'audio' oraz nadania praw plikom konfiguracyjnym tvime'a.
Powodzenia.
