VLC - wy
vader
VLC - wyłącza się przy odtwarzaniu muzyki
Post autor: vader »
Włączam VLC, wybieram katalog z plikami ogg/mp3 i program wyłącza się albo od razu po tym, albo przy wybraniu konkretnego utworu.
Oto co wyświetla się w konsoli przy ogg:
VLC media player 1.1.2 The Luggage (revision exported)
Blocked: call to unsetenv("DBUS_ACTIVATION_ADDRESS")
Blocked: call to unsetenv("DBUS_ACTIVATION_BUS_TYPE")
Warning: call to signal(13, 0x1)
Blocked: call to setlocale(6, "")
Blocked: call to sigaction(17, 0x7fae30124b50, 0x7fae30124ab0)
Blocked: call to setenv("ORBIT_SOCKETDIR", "/tmp/orbit-vader", 1)
Warning: call to srand(1282112338)
Warning: call to rand()
(process:2650): Gtk-WARNING **: Locale not supported by C library.
    Using the fallback 'C' locale.
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Using libdvdcss version 1.2.10 for DVD access
libdvdread: Couldn't find device name.
libdvdnav: Can't read name block. Probably not a DVD-ROM device.
libdvdnav: Unable to find map file '/home/vader/.dvdnav/.map'
libdvdnav :D VDOpenFilePath:findDVDFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav :D VDOpenFilePath:findDVDFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[0x22b5550] main playlist: stopping playback
Blocked: call to setlocale(1, "C")
Blocked: call to setlocale(1, "pl_PL.UTF-8")
*** glibc detected *** vlc: munmap_chunk(): invalid pointer: 0x00000000028efd80 ***
======= Backtrace: =========
/lib/libc.so.6(+0x71b16)[0x7fae34be6b16]
/usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so(+0x136e)[0x7fae1312b36e]
/usr/lib/libvlccore.so.4(module_unneed+0x22)[0x7fae3537f772]
/usr/lib/libvlccore.so.4(+0x75473)[0x7fae3536b473]
/usr/lib/libvlccore.so.4(+0x77c64)[0x7fae3536dc64]
/usr/lib/libvlccore.so.4(+0x74bda)[0x7fae3536abda]
/usr/lib/libvlccore.so.4(+0x42b21)[0x7fae35338b21]
/usr/lib/libvlccore.so.4(+0x46d55)[0x7fae3533cd55]
/usr/lib/libvlccore.so.4(+0x4891c)[0x7fae3533e91c]
/usr/lib/libvlccore.so.4(+0x499e4)[0x7fae3533f9e4]
/usr/lib/libvlccore.so.4(+0x4ea1e)[0x7fae35344a1e]
/usr/lib/libvlccore.so.4(+0x4f52e)[0x7fae3534552e]
/usr/lib/libvlccore.so.4(+0x513ee)[0x7fae353473ee]
/usr/lib/libvlccore.so.4(+0x51965)[0x7fae35347965]
/usr/lib/libvlccore.so.4(+0x57d2d)[0x7fae3534dd2d]
/usr/lib/libvlccore.so.4(+0x8fdc4)[0x7fae35385dc4]
/lib/libpthread.so.0(+0x68ba)[0x7fae350e08ba]
/lib/libc.so.6(clone+0x6d)[0x7fae34c4401d]
======= Memory map: ========
00400000-00403000 r-xp 00000000 08:01 358639                             /usr/bin/vlc
00602000-00603000 rw-p 00002000 08:01 358639                             /usr/bin/vlc
021a1000-0355a000 rw-p 00000000 00:00 0                                  [heap]
7fae122ca000-7fae122d0000 r-xp 00000000 08:01 467833                     /usr/lib/vlc/plugins/audio_filter/libbandlimited_resampler_plugin.so
7fae122d0000-7fae124cf000 ---p 00006000 08:01 467833                     /usr/lib/vlc/plugins/audio_filter/libbandlimited_resampler_plugin.so
7fae124cf000-7fae124d0000 rw-p 00005000 08:01 467833                     /usr/lib/vlc/plugins/audio_filter/libbandlimited_resampler_plugin.so
7fae124d0000-7fae124f7000 r-xp 00000000 08:01 1292258                    /usr/lib/libdca.so.0.0.0
7fae124f7000-7fae126f7000 ---p 00027000 08:01 1292258                    /usr/lib/libdca.so.0.0.0
7fae126f7000-7fae126f8000 rw-p 00027000 08:01 1292258                    /usr/lib/libdca.so.0.0.0
7fae126f8000-7fae126fa000 r-xp 00000000 08:01 467827                     /usr/lib/vlc/plugins/audio_filter/libdtstofloat32_plugin.so
7fae126fa000-7fae128f9000 ---p 00002000 08:01 467827                     /usr/lib/vlc/plugins/audio_filter/libdtstofloat32_plugin.so
7fae128f9000-7fae128fa000 rw-p 00001000 08:01 467827                     /usr/lib/vlc/plugins/audio_filter/libdtstofloat32_plugin.so
7fae128fa000-7fae12918000 r-xp 00000000 08:01 357069                     /usr/lib/libmad.so.0.2.1
7fae12918000-7fae12b18000 ---p 0001e000 08:01 357069                     /usr/lib/libmad.so.0.2.1
7fae12b18000-7fae12b19000 rw-p 0001e000 08:01 357069                     /usr/lib/libmad.so.0.2.1
7fae12b19000-7fae12b1b000 r-xp 00000000 08:01 467828                     /usr/lib/vlc/plugins/audio_filter/libmpgatofixed32_plugin.so
7fae12b1b000-7fae12d1a000 ---p 00002000 08:01 467828                     /usr/lib/vlc/plugins/audio_filter/libmpgatofixed32_plugin.so
7fae12d1a000-7fae12d1b000 rw-p 00001000 08:01 467828                     /usr/lib/vlc/plugins/audio_filter/libmpgatofixed32_plugin.so
7fae12d1b000-7fae12d27000 r-xp 00000000 08:01 358918                     /usr/lib/liba52-0.7.4.so
7fae12d27000-7fae12f26000 ---p 0000c000 08:01 358918                     /usr/lib/liba52-0.7.4.so
7fae12f26000-7fae12f27000 rw-p 0000b000 08:01 358918                     /usr/lib/liba52-0.7.4.so
7fae12f27000-7fae12f28000 rw-p 00000000 00:00 0
7fae12f28000-7fae12f2a000 r-xp 00000000 08:01 467826                     /usr/lib/vlc/plugins/audio_filter/liba52tofloat32_plugin.so
7fae12f2a000-7fae13129000 ---p 00002000 08:01 467826                     /usr/lib/vlc/plugins/audio_filter/liba52tofloat32_plugin.so
7fae13129000-7fae1312a000 rw-p 00001000 08:01 467826                     /usr/lib/vlc/plugins/audio_filter/liba52tofloat32_plugin.so
7fae1312a000-7fae1312d000 r-xp 00000000 08:01 468081                     /usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so
7fae1312d000-7fae1332c000 ---p 00003000 08:01 468081                     /usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so
7fae1332c000-7fae1332d000 rw-p 00002000 08:01 468081                     /usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so
7fae1332d000-7fae1332f000 r-xp 00000000 08:01 450305                     /usr/lib/vlc/plugins/audio_mixer/libfloat32_mixer_plugin.so
7fae1332f000-7fae1352e000 ---p 00002000 08:01 450305                     /usr/lib/vlc/plugins/audio_mixer/libfloat32_mixer_plugin.so
7fae1352e000-7fae1352f000 rw-p 00001000 08:01 450305                     /usr/lib/vlc/plugins/audio_mixer/libfloat32_mixer_plugin.so
7fae1352f000-7fae1354f000 rw-s 00000000 00:04 5537804                    /SYSV0056a4d6 (deleted)
7fae1354f000-7fae13567000 rw-s 00000000 00:05 3669                       /dev/snd/pcmC0D0p
7fae13567000-7fae13568000 rw-s 81000000 00:05 3669                       /dev/snd/pcmC0D0p
7fae13568000-7fae13569000 r--s 80000000 00:05 3669                       /dev/snd/pcmC0D0p
7fae13569000-7fae1356a000 rw-s 00000000 00:04 5505035                    /SYSV0056a4d5 (deleted)
7fae1356a000-7fae1356b000 ---p 00000000 00:00 0
7fae1356b000-7fae1366b000 rw-p 00000000 00:00 0
7fae1366b000-7fae1391e000 r-xp 00000000 08:01 354514                     /usr/lib/libvorbisenc.so.2.0.7
7fae1391e000-7fae13b1d000 ---p 002b3000 08:01 354514                     /usr/lib/libvorbisenc.so.2.0.7
7fae13b1d000-7fae13b39000 rw-p 002b2000 08:01 354514                     /usr/lib/libvorbisenc.so.2.0.7
7fae13b39000-7fae13b3f000 r-xp 00000000 08:01 469157                     /usr/lib/vlc/plugins/codec/libvorbis_plugin.so
7fae13b3f000-7fae13d3e000 ---p 00006000 08:01 469157                     /usr/lib/vlc/plugins/codec/libvorbis_plugin.so
7fae13d3e000-7fae13d3f000 rw-p 00005000 08:01 469157                     /usr/lib/vlc/plugins/codec/libvorbis_plugin.soPrzerwane
To przy mp3:
Blocked: call to sigaction(17, 0x7fc6201f7b50, 0x7fc6201f7ab0)
Warning: call to srand(1281711063)
(process:2871): Gtk-WARNING **: Locale not supported by C library.
[0xfe4550] main playlist: stopping playback
*** glibc detected *** vlc: double free or corruption (!prev): 0x00007fc61c21c600 ***
/lib/libc.so.6(+0x71b16)[0x7fc626e01b16]
/lib/libc.so.6(cfree+0x6c)[0x7fc626e0688c]
/usr/lib/libasound.so.2(+0x6bdbc)[0x7fc6261bddbc]
/usr/lib/libasound.so.2(snd_pcm_hw_free+0x30)[0x7fc6261a88a0]
00ed0000-0209a000 rw-p 00000000 00:00 0                                  [heap]
7fc5ff8d4000-7fc5ff8da000 r-xp 00000000 08:01 467833                     /usr/lib/vlc/plugins/audio_filter/libbandlimited_resampler_plugin.so
7fc5ff8da000-7fc5ffad9000 ---p 00006000 08:01 467833                     /usr/lib/vlc/plugins/audio_filter/libbandlimited_resampler_plugin.so
7fc5ffad9000-7fc5ffada000 rw-p 00005000 08:01 467833                     /usr/lib/vlc/plugins/audio_filter/libbandlimited_resampler_plugin.so
7fc5ffada000-7fc5ffb01000 r-xp 00000000 08:01 1292258                    /usr/lib/libdca.so.0.0.0
7fc5ffb01000-7fc5ffd01000 ---p 00027000 08:01 1292258                    /usr/lib/libdca.so.0.0.0
7fc5ffd01000-7fc5ffd02000 rw-p 00027000 08:01 1292258                    /usr/lib/libdca.so.0.0.0
7fc5ffd02000-7fc5ffd04000 r-xp 00000000 08:01 467827                     /usr/lib/vlc/plugins/audio_filter/libdtstofloat32_plugin.so
7fc5ffd04000-7fc5fff03000 ---p 00002000 08:01 467827                     /usr/lib/vlc/plugins/audio_filter/libdtstofloat32_plugin.so
7fc5fff03000-7fc5fff04000 rw-p 00001000 08:01 467827                     /usr/lib/vlc/plugins/audio_filter/libdtstofloat32_plugin.so
7fc5fff04000-7fc5fff22000 r-xp 00000000 08:01 357069                     /usr/lib/libmad.so.0.2.1
7fc5fff22000-7fc600122000 ---p 0001e000 08:01 357069                     /usr/lib/libmad.so.0.2.1
7fc600122000-7fc600123000 rw-p 0001e000 08:01 357069                     /usr/lib/libmad.so.0.2.1
7fc600123000-7fc600125000 r-xp 00000000 08:01 467828                     /usr/lib/vlc/plugins/audio_filter/libmpgatofixed32_plugin.so
7fc600125000-7fc600324000 ---p 00002000 08:01 467828                     /usr/lib/vlc/plugins/audio_filter/libmpgatofixed32_plugin.so
7fc600324000-7fc600325000 rw-p 00001000 08:01 467828                     /usr/lib/vlc/plugins/audio_filter/libmpgatofixed32_plugin.so
7fc600325000-7fc600331000 r-xp 00000000 08:01 358918                     /usr/lib/liba52-0.7.4.so
7fc600331000-7fc600530000 ---p 0000c000 08:01 358918                     /usr/lib/liba52-0.7.4.so
7fc600530000-7fc600531000 rw-p 0000b000 08:01 358918                     /usr/lib/liba52-0.7.4.so
7fc600531000-7fc600532000 rw-p 00000000 00:00 0
7fc600532000-7fc600534000 r-xp 00000000 08:01 467826                     /usr/lib/vlc/plugins/audio_filter/liba52tofloat32_plugin.so
7fc600534000-7fc600733000 ---p 00002000 08:01 467826                     /usr/lib/vlc/plugins/audio_filter/liba52tofloat32_plugin.so
7fc600733000-7fc600734000 rw-p 00001000 08:01 467826                     /usr/lib/vlc/plugins/audio_filter/liba52tofloat32_plugin.so
7fc600734000-7fc600737000 r-xp 00000000 08:01 468081                     /usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so
7fc600737000-7fc600936000 ---p 00003000 08:01 468081                     /usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so
7fc600936000-7fc600937000 rw-p 00002000 08:01 468081                     /usr/lib/vlc/plugins/audio_filter/libscaletempo_plugin.so
7fc600937000-7fc600939000 r-xp 00000000 08:01 450305                     /usr/lib/vlc/plugins/audio_mixer/libfloat32_mixer_plugin.so
7fc600939000-7fc600b38000 ---p 00002000 08:01 450305                     /usr/lib/vlc/plugins/audio_mixer/libfloat32_mixer_plugin.so
7fc600b38000-7fc600b39000 rw-p 00001000 08:01 450305                     /usr/lib/vlc/plugins/audio_mixer/libfloat32_mixer_plugin.so
7fc600b39000-7fc600b3a000 ---p 00000000 00:00 0
7fc600b3a000-7fc600c3a000 rw-p 00000000 00:00 0
7fc600c3a000-7fc600c3b000 ---p 00000000 00:00 0
7fc600c3b000-7fc600d3b000 rw-p 00000000 00:00 0
7fc600d3b000-7fc600d79000 r-xp 00000000 08:01 1291950                    /usr/lib/libfaad.so.2.0.0
7fc600d79000-7fc600f79000 ---p 0003e000 08:01 1291950                    /usr/lib/libfaad.so.2.0.0
7fc600f79000-7fc600f7c000 rw-p 0003e000 08:01 1291950                    /usr/lib/libfaad.so.2.0.0
7fc600f7c000-7fc600f7e000 r-xp 00000000 08:01 468096                     /usr/lib/vlc/plugins/codec/libfaad_plugin.so
7fc600f7e000-7fc60117e000 ---p 00002000 08:01 468096                     /usr/lib/vlc/plugins/codec/libfaad_plugin.so
7fc60117e000-7fc60117f000 rw-p 00002000 08:01 468096                     /usr/lib/vlc/plugins/codec/libfaad_plugin.so
7fc60117f000-7fc6011ca000 r-xp 00000000 08:01 355695                     /usr/lib/libFLAC.so.8.2.0
7fc6011ca000-7fc6013c9000 ---p 0004b000 08:01 355695                     /usr/lib/libFLAC.so.8.2.0
7fc6013c9000-7fc6013cb000 rw-p 0004a000 08:01 355695                     /usr/lib/libFLAC.so.8.2.0
7fc6013cb000-7fc6013ce000 r-xp 00000000 08:01 468099                     /usr/lib/vlc/plugins/codec/libflac_plugin.so
7fc6013ce000-7fc6015ce000 ---p 00003000 08:01 468099                     /usr/lib/vlc/plugins/codec/libflac_plugin.so
7fc6015ce000-7fc6015cf000 rw-p 00003000 08:01 468099                     /usr/lib/vlc/plugins/codec/libflac_plugin.so
7fc6015cf000-7fc6015fc000 r-xp 00000000 08:01 353825                     /usr/lib/libenca.so.0.5.1
7fc6015fc000-7fc6017fb000 ---p 0002d000 08:01 353825                     /usr/lib/libenca.so.0.5.1
7fc6017fb000-7fc601801000 rw-p 0002c000 08:01 353825                     /usr/lib/libenca.so.0.5.1
7fc601801000-7fc601819000 r-xp 00000000 08:01 355954                     /usr/lib/libass.so.4.0.0Przerwane
Chociaż wydawało mi się, że jeszcze przedtem jak próbowałem uruchamiać mp3 na VLC, to przy "Przerwane" był jakiś plik od lame.
Używam Debiana Sid.
Czy można coś z tym zrobić? Naprawdę zależy mi na VLC.
Odświeżenie tematu.
vader
Post autor: vader »
Chyba zidentyfikowałem przyczynę problemu. Mam dwie karty dźwiękowe - zintegrowane AC'97 i zewnętznego Creative E-MU 0404. Wyżej opisane problemy występują tylko przy tej drugiej karcie. Z innymi programami raczej nie ma takich problemów.
