Zainstalowałem wczoraj program Stellarium. Niestety z powodu braku akceleracji 3D program nie działał płynnie. Postanowiłem uruchomić akcelerację 3D. Wybór padł na ten poradnik. W moim Debianie nie ma pliku /etx/X11/xorg.conf, więc pominąłem tę część poradnika. Wydałem tylko dwa polecenia:
aptitude install firmware-linux-nonfree
aptitude install libgl1-mesa-driKod: Zaznacz cały
glxgears -infoOto co zwraca:
arek@debian:~$ glxgears -info
GL_RENDERER = Mesa DRI R200 (RV280 5960) 20090101 AGP 8x x86/MMX+/3DNow!+/SSE2 TCL
GL_VERSION = 1.3 Mesa 7.7.1
GL_VENDOR = Tungsten Graphics, Inc.
GL_EXTENSIONS = GL_EXT_compiled_vertex_array GL_EXT_texture_env_add GL_ARB_draw_buffers GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_convolution GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_APPLE_packed_pixels GL_ATI_blend_equation_separate GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_ATI_fragment_shader GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_texgen_reflection GL_OES_read_format GL_SGI_color_matrix GL_SGI_color_table GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
8023 frames in 5.0 seconds = 1604.564 FPS
8025 frames in 5.0 seconds = 1604.926 FPS
8028 frames in 5.0 seconds = 1605.514 FPS
8004 frames in 5.0 seconds = 1600.770 FPS
7979 frames in 5.0 seconds = 1595.682 FPSKod: Zaznacz cały
arek@debian:~$ glxinfo | grep render
direct rendering: Yes
OpenGL renderer string: Mesa DRI R200 (RV280 5960) 20090101 AGP 8x x86/MMX+/3DNow!+/SSE2 TCLWynik całego polecenia:
name of display: :0.0
display: :0 screen: 0
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL version string: 1.3 Mesa 7.7.1
OpenGL extensions:
GL_EXT_compiled_vertex_array, GL_EXT_texture_env_add, GL_ARB_draw_buffers,
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_convolution, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_histogram,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_APPLE_packed_pixels, GL_ATI_blend_equation_separate,
GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once,
GL_ATI_fragment_shader, GL_IBM_multimode_draw_arrays,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_packed_depth_stencil, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_OES_read_format, GL_SGI_color_matrix,
GL_SGI_color_table, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
8 GLX Visuals
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x75 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x76 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x77 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x78 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x79 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x6c 32 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 Ncon
8 GLXFBConfigs:
0x6d 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x6e 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x6f 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x70 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x71 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x72 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x73 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x74 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 SlowKod: Zaznacz cały
root@debian:/home/arek# cat /var/log/Xorg.0.log | grep -E "WW|EE"
(WW) Falling back to old probe method for vesa
(WW) Falling back to old probe method for fbdev
(EE) open /dev/fb0: No such file or directory
(WW) RADEON(0): DRI init changed memory map, adjusting ...
(WW) RADEON(0): MC_FB_LOCATION was: 0xefffe800 is: 0xefffe800
(WW) RADEON(0): MC_AGP_LOCATION was: 0xffffffc0 is: 0xf07ff000
(EE) RADEON(0): Unable to reserve offscreen area for back buffer, you might experience screen corruption
(EE) RADEON(0): Unable to reserve offscreen area for back buffer, you might experience screen corruptionKod: Zaznacz cały
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
X.Org X Server 1.7.6.901 (1.7.7 RC 1)
Release Date: 2010-04-12
Build Operating System: Linux 2.6.26-2-amd64 i686 Debian
Current Operating System: Linux debian 2.6.32-3-686 #1 SMP Thu Feb 25 06:14:20 UTC 2010 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-3-686 root=UUID=a249fd34-d305-4b7a-9d6e-64b306f61beb ro quiet
Build Date: 19 April 2010 06:12:31PM
xorg-server 2:1.7.6.901-3 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 14 09:36:37 2010
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(II) The server relies on udev to provide the list of input devices.
(II) Loader magic: 0x81eacc0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(--) PCI:*(0:1:0:0) 1002:5960:1fd3:5960 ATI Technologies Inc RV280 [Radeon 9200 PRO] rev 1, Mem @ 0xe8000000/134217728, 0xfdff0000/65536, I/O @ 0x0000bc00/256, BIOS @ 0x????????/131072
(--) PCI: (0:1:0:1) 1002:5940:1fd3:5961 ATI Technologies Inc RV280 [Radeon 9200 PRO] (Secondary) rev 1, Mem @ 0xe0000000/134217728, 0xfdfe0000/65536
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
compiled for 1.7.6.901, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.6.901, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 1.1.0
(II) Loading extension DRI2
(==) Matched ati as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "ati"
(II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
(II) Module ati: vendor="X.Org Foundation"
compiled for 1.7.5, module version = 6.12.6
ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: "radeon"
(II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.4, module version = 2.3.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.7.6, module version = 0.4.2
(II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
ATI Radeon 8500 AIW BB (AGP), ATI Radeon 8500 AIW BC (AGP),
ATI Radeon IGP320M (U1) 4336, ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
ATI Radeon X800 VE (R420) JT (AGP), ATI Radeon X850 (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
ATI Radeon 9800XT NJ (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835,
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE),
ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE),
ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
ATI Mobility Radeon X1700, ATI Radeon X2300HD,
ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI FireGL V7400,
ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600,
ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon 4800 Series, ATI Radeon HD 4850 x2,
ATI FirePro V8750 (FireGL), ATI FirePro V7760 (FireGL),
ATI Mobility RADEON HD 4850, ATI Mobility RADEON HD 4850 X2,
ATI Radeon 4800 Series, ATI FirePro RV770, AMD FireStream 9270,
AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI Radeon 4800 Series, ATI Radeon 4800 Series, ATI FirePro M7750,
ATI M98, ATI M98, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI Radeon RV730 (AGP),
ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI Radeon HD 4770,
ATI FirePro M5750, ATI RV610, ATI Radeon HD 2400 XT,
ATI Radeon HD 2400 Pro, ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000,
ATI RV610, ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610,
ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI RV670,
ATI Mobility Radeon HD 3870, ATI Mobility Radeon HD 3870 X2,
ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850,
ATI Radeon HD3690, AMD Firestream 9170, ATI Radeon HD 4550,
ATI Radeon RV710, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI Mobility Radeon 4500 Series, ATI FirePro RG220, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon RV710,
ATI Radeon HD 3470, ATI Mobility Radeon HD 3430,
ATI Mobility Radeon HD 3400 Series, ATI Radeon HD 3450,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI Radeon HD 3450,
ATI FirePro V3700, ATI FireMV 2450, ATI FireMV 2260, ATI FireMV 2260,
ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Radeon HD 3600 PRO, ATI Mobility Radeon HD 3650,
ATI Mobility Radeon HD 3670, ATI Mobility FireGL V5700,
ATI Mobility FireGL V5725, ATI Radeon HD 3200 Graphics,
ATI Radeon 3100 Graphics, ATI Radeon HD 3200 Graphics,
ATI Radeon 3100 Graphics, ATI Radeon HD 3300 Graphics,
ATI Radeon HD 3200 Graphics, ATI Radeon 3000 Graphics,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4290
(II) VESA: driver for VESA chipsets: vesa
(II) FBDEV: driver for framebuffer: fbdev
(II) Primary Device is: PCI 01@00:00:0
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.0.2
(II) RADEON(0): TOTO SAYS 00000000fdff0000
(II) RADEON(0): MMIO registers at 0x00000000fdff0000: size 64KB
(II) RADEON(0): PCI bus 1 card 0 func 0
(II) RADEON(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
(==) RADEON(0): Depth 24, (--) framebuffer bpp 32
(II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) RADEON(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.1.0
(II) RADEON(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(==) RADEON(0): RGB weight 888
(II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
(--) RADEON(0): Chipset: "ATI Radeon 9250 5960 (AGP)" (ChipID = 0x5960)
(--) RADEON(0): Linear framebuffer at 0x00000000e8000000
(II) RADEON(0): AGP card detected
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) RADEON(0): initializing int10
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(II) RADEON(0): Legacy BIOS detected
drmOpenDevice: node name is /dev/dri/card0
drmOpenByBusid: Searching for BusID pci:0000:01:00.0
drmOpenDevice: open result is 11, (OK)
drmOpenByBusid: drmOpenMinor returns 11
drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
(II) RADEON(0): [dri] Found DRI library version 1.3.0 and kernel module version 1.31.0
(==) RADEON(0): Page Flipping disabled
(II) RADEON(0): Will try to use DMA for Xv image transfers
(II) RADEON(0): Generation 2 PCI interface, using max accessible memory
(II) RADEON(0): Detected total video RAM=131072K, accessible=131072K (PCI BAR=131072K)
(--) RADEON(0): Mapped VideoRAM: 131072 kByte (64 bit DDR SDRAM)
(II) RADEON(0): Color tiling enabled by default
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) RADEON(0): ref_freq: 2700, min_out_pll: 20000, max_out_pll: 40000, min_in_pll: 40, max_in_pll: 3000, xclk: 20000, sclk: 240.000000, mclk: 200.000000
(II) RADEON(0): PLL parameters: rf=2700 rd=12 min=20000 max=40000; xclk=20000
(II) RADEON(0): Output VGA-1 has no monitor section
(II) RADEON(0): I2C bus "VGA-1" initialized.
(II) RADEON(0): Output VGA-0 has no monitor section
(II) RADEON(0): I2C bus "VGA-0" initialized.
(II) RADEON(0): Output S-video has no monitor section
(II) RADEON(0): Default TV standard: PAL
(II) RADEON(0): TV standards supported by chip: NTSC PAL
(II) RADEON(0): Port0:
XRANDR name: VGA-1
Connector: VGA
CRT1: INTERNAL_DAC1
DDC reg: 0x60
(II) RADEON(0): Port1:
XRANDR name: VGA-0
Connector: VGA
CRT2: INTERNAL_DAC2
DDC reg: 0x6c
(II) RADEON(0): Port2:
XRANDR name: S-video
Connector: S-video
TV1: INTERNAL_DAC2
DDC reg: 0x0
(II) RADEON(0): I2C device "VGA-1:ddc2" registered at address 0xA0.
(II) RADEON(0): I2C device "VGA-1:DDC control interface" registered at address 0x6E.
(II) RADEON(0): EDID for output VGA-1
(II) RADEON(0): Manufacturer: SAM Model: 108 Serial#: 1279602999
(II) RADEON(0): Year: 2004 Week: 27
(II) RADEON(0): EDID Version: 1.3
(II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) RADEON(0): Sync: Separate
(II) RADEON(0): Max Image Size [cm]: horiz.: 31 vert.: 23
(II) RADEON(0): Gamma: 2.20
(II) RADEON(0): DPMS capabilities: Off; RGB/Color Display
(II) RADEON(0): Default color space is primary color space
(II) RADEON(0): First detailed timing is preferred mode
(II) RADEON(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
(II) RADEON(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
(II) RADEON(0): Supported established timings:
(II) RADEON(0): 720x400@70Hz
(II) RADEON(0): 640x480@60Hz
(II) RADEON(0): 640x480@67Hz
(II) RADEON(0): 640x480@72Hz
(II) RADEON(0): 640x480@75Hz
(II) RADEON(0): 800x600@56Hz
(II) RADEON(0): 800x600@60Hz
(II) RADEON(0): 800x600@72Hz
(II) RADEON(0): 800x600@75Hz
(II) RADEON(0): 832x624@75Hz
(II) RADEON(0): 1024x768@60Hz
(II) RADEON(0): 1024x768@70Hz
(II) RADEON(0): 1024x768@75Hz
(II) RADEON(0): 1280x1024@75Hz
(II) RADEON(0): 1152x864@75Hz
(II) RADEON(0): Manufacturer's mask: 0
(II) RADEON(0): Supported standard timings:
(II) RADEON(0): #0: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) RADEON(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) RADEON(0): #2: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) RADEON(0): #3: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) RADEON(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) RADEON(0): #5: hsize: 1600 vsize 1200 refresh: 65 vid: 17833
(II) RADEON(0): Supported detailed timing:
(II) RADEON(0): clock: 94.5 MHz Image Size: 312 x 234 mm
(II) RADEON(0): h_active: 1024 h_sync: 1072 h_sync_end 1168 h_blank_end 1376 h_border: 0
(II) RADEON(0): v_active: 768 v_sync: 769 v_sync_end 772 v_blanking: 808 v_border: 0
(II) RADEON(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 85 kHz, PixClock max 180 MHz
(II) RADEON(0): Monitor name: SyncMaster
(II) RADEON(0): Serial No: H9KX668022
(II) RADEON(0): EDID (in hex):
(II) RADEON(0): 00ffffffffffff004c2d08013731454c
(II) RADEON(0): 1b0e0103681f17782eee91a3544c9926
(II) RADEON(0): 0f5054bfef80315945596159714f8180
(II) RADEON(0): a94501010101ea240060410028303060
(II) RADEON(0): 130038ea1000001e000000fd0032a01e
(II) RADEON(0): 5512000a202020202020000000fc0053
(II) RADEON(0): 796e634d61737465720a2020000000ff
(II) RADEON(0): 0048394b583636383032320a20200017
(II) RADEON(0): EDID vendor "SAM", prod id 264
(II) RADEON(0): Using EDID range info for horizontal sync
(II) RADEON(0): Using EDID range info for vertical refresh
(II) RADEON(0): Printing DDC gathered Modelines:
(II) RADEON(0): Modeline "1024x768"x0.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) RADEON(0): Modeline "1600x1200"x0.0 175.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (81.2 kHz)
(II) RADEON(0): Output: VGA-1, Detected Monitor Type: 1
(II) RADEON(0): EDID data from the display on output: VGA-1 ----------------------
finished output detect: 0
(II) RADEON(0): I2C device "VGA-0:ddc2" registered at address 0xA0.
(II) RADEON(0): Output: VGA-0, Detected Monitor Type: 0
finished output detect: 1
(II) RADEON(0): Output: S-video, Detected Monitor Type: 0
finished output detect: 2
finished all detect
before xf86InitialConfiguration
(II) RADEON(0): Using hsync ranges from config file
(II) RADEON(0): Using vrefresh ranges from config file
(II) RADEON(0): Printing probed modes for output VGA-1
(II) RADEON(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(II) RADEON(0): Modeline "1600x1200"x65.0 175.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (81.2 kHz)
(II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) RADEON(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) RADEON(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) RADEON(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) RADEON(0): Modeline "800x600"x85.1 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(II) RADEON(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) RADEON(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) RADEON(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) RADEON(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) RADEON(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) RADEON(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) RADEON(0): EDID for output VGA-0
(II) RADEON(0): EDID for output S-video
(II) RADEON(0): Output VGA-1 connected
(II) RADEON(0): Output VGA-0 disconnected
(II) RADEON(0): Output S-video disconnected
(II) RADEON(0): Using exact sizes for initial modes
(II) RADEON(0): Output VGA-1 using initial mode 1024x768
(II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
after xf86InitialConfiguration
(**) RADEON(0): Display dimensions: (310, 230) mm
(**) RADEON(0): DPI set to (131, 176)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(==) RADEON(0): Using XAA acceleration architecture
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules/libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 1.2.1
(==) RADEON(0): Assuming overlay scaler buffer width is 1536
(II) RADEON(0): No MM_TABLE found - assuming CARD is not TV-in capable.
(!!) RADEON(0): For information on using the multimedia capabilities
of this adapter, please see http://gatos.sf.net.
(!!) RADEON(0): MergedFB support has been removed and replaced with xrandr 1.2 support
(II) UnloadModule: "vesa"
(II) Unloading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) RADEON(0): RADEONScreenInit e8000000 0 0
Entering TV Save
Save TV timing tables
saveTimingTables: reading timing tables
TV Save done
disable primary dac
(==) RADEON(0): Using 24 bit depth buffer
(II) RADEON(0): RADEONInitMemoryMap() :
(II) RADEON(0): mem_size : 0x08000000
(II) RADEON(0): MC_FB_LOCATION : 0xefffe800
(II) RADEON(0): MC_AGP_LOCATION : 0xffffffc0
(II) RADEON(0): Depth moves disabled by default
(II) RADEON(0): Using 8 MB GART aperture
(II) RADEON(0): Using 1 MB for the ring buffer
(II) RADEON(0): Using 2 MB for vertex/indirect buffers
(II) RADEON(0): Using 5 MB for GART textures
(II) RADEON(0): Memory manager initialized to (0,0) (1600,8191)
(II) RADEON(0): Reserved area from (0,1600) to (1600,1602)
(II) RADEON(0): Largest offscreen area available: 1600 x 6589
(II) RADEON(0): Will use front buffer at offset 0x0
(II) RADEON(0): Will use back buffer at offset 0x286e000
(II) RADEON(0): Will use depth buffer at offset 0x3232000
(II) RADEON(0): Will use 69632 kb for textures at offset 0x3bf6000
(II) [drm] DRM interface version 1.3
(II) [drm] DRM open master succeeded.
(II) RADEON(0): [drm] Using the DRM lock SAREA also for drawables.
(II) RADEON(0): [drm] framebuffer handle = 0xe8000000
(II) RADEON(0): [drm] added 1 reserved context for kernel
(II) RADEON(0): X context handle = 0x1
(II) RADEON(0): [drm] installed DRM signal handler
(==) RADEON(0): Using AGP 8x
(II) RADEON(0): [agp] Mode 0x1f00420a [AGP 0x10de/0x00e1; Card 0x1002/0x5960 0x1fd3/0x5960]
(II) RADEON(0): [agp] 8192 kB allocated with handle 0x00000001
(II) RADEON(0): [agp] ring handle = 0xf0000000
(II) RADEON(0): [agp] Ring mapped at 0xb7256000
(II) RADEON(0): [agp] ring read ptr handle = 0xf0101000
(II) RADEON(0): [agp] Ring read ptr mapped at 0xb7255000
(II) RADEON(0): [agp] vertex/indirect buffers handle = 0xf0102000
(II) RADEON(0): [agp] Vertex/indirect buffers mapped at 0xaef78000
(II) RADEON(0): [agp] GART texture map handle = 0xf0302000
(II) RADEON(0): [agp] GART Texture map mapped at 0xaea98000
(II) RADEON(0): [drm] register handle = 0x2fbfe000
(II) RADEON(0): [dri] Visual configs initialized
(II) RADEON(0): RADEONRestoreMemMapRegisters() :
(II) RADEON(0): MC_FB_LOCATION : 0xefffe800 0x1fff0000
(==) RADEON(0): Backing store disabled
(II) RADEON(0): [DRI] installation complete
(II) RADEON(0): [drm] Added 32 65536 byte vertex/indirect buffers
(II) RADEON(0): [drm] Mapped 32 vertex/indirect buffers
(II) RADEON(0): [drm] dma control initialized, using IRQ 16
(II) RADEON(0): [drm] Initialized kernel GART heap manager, 5111808
(II) RADEON(0): MC_FB_LOCATION : 0xefffe800 0xefffe800
(II) RADEON(0): MC_AGP_LOCATION : 0xf07ff000
(II) RADEON(0): Direct rendering enabled
(II) RADEON(0): Render acceleration enabled
(II) RADEON(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Horizontal and Vertical Lines
Scanline Image Writes
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(II) RADEON(0): Acceleration enabled
(==) RADEON(0): DPMS enabled
(==) RADEON(0): Silken mouse enabled
(II) RADEON(0): Will use 32 kb for hardware cursor 0 at offset 0x009c7200
(II) RADEON(0): Will use 32 kb for hardware cursor 1 at offset 0x009cbd00
(II) RADEON(0): Largest offscreen area available: 1600 x 6583
(II) RADEON(0): No video input capabilities detected and no information is provided - disabling multimedia i2c
(II) Loading sub module "theatre_detect"
(II) LoadModule: "theatre_detect"
(II) Loading /usr/lib/xorg/modules/multimedia/theatre_detect_drv.so
(II) Module theatre_detect: vendor="X.Org Foundation"
compiled for 1.7.5, module version = 1.0.0
(II) RADEON(0): no multimedia table present, disabling Rage Theatre.
(II) RADEON(0): Set up overlay video
(II) RADEON(0): Set up textured video
disable primary dac
disable TVDAC
disable TV
disable primary dac
init memmap
init common
init crtc1
init pll1
freq: 94500000
best_freq: 94500000
best_feedback_div: 21
best_ref_div: 2
best_post_div: 3
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
set RMX
set primary dac
enable primary dac
disable TVDAC
disable TV
(II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: Screen 0 is not DRI2 capable
drmOpenDevice: open result is 12, (OK)
drmOpenByBusid: drmOpenMinor returns 12
(II) AIGLX: enabled GLX_MESA_copy_sub_buffer
(II) AIGLX: enabled GLX_SGI_make_current_read
(II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
(II) AIGLX: enabled GLX_texture_from_pixmap with driver support
(II) AIGLX: Loaded and initialized /usr/lib/dri/r200_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) RADEON(0): Setting screen physical size to 270 x 203
(II) config/udev: Adding input device Power Button (/dev/input/event2)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event2"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "pl"
(II) config/udev: Adding input device Power Button (/dev/input/event1)
(**) Power Button: Device: "/dev/input/event1"
(II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/event3)
(**) PS/2+USB Mouse: Applying InputClass "evdev pointer catchall"
(**) PS/2+USB Mouse: always reports core events
(**) PS/2+USB Mouse: Device: "/dev/input/event3"
(II) PS/2+USB Mouse: Found 9 mouse buttons
(II) PS/2+USB Mouse: Found scroll wheel(s)
(II) PS/2+USB Mouse: Found relative axes
(II) PS/2+USB Mouse: Found x and y relative axes
(II) PS/2+USB Mouse: Configuring as mouse
(**) PS/2+USB Mouse: YAxisMapping: buttons 4 and 5
(**) PS/2+USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "PS/2+USB Mouse" (type: MOUSE)
(II) PS/2+USB Mouse: initialized for relative axes.
(II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/mouse0)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
(**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device PC Speaker (/dev/input/event4)
disable primary dac
disable primary dac
enable primary dac
disable primary dac
disable TVDAC
disable TV
disable primary dac
init memmap
init common
init crtc1
init pll1
freq: 108000000
best_freq: 108000000
best_feedback_div: 16
best_ref_div: 2
best_post_div: 2
restore memmap
restore common
restore crtc1
restore pll1
finished PLL1
set RMX
set primary dac
enable primary dac
disable TVDAC
disable TV
(EE) RADEON(0): Unable to reserve offscreen area for back buffer, you might experience screen corruptionPS. Zauważyłem jeszcze, że kiedy przesuwam to okno to na czarnym tle pojawiają się kropki w kolorach tych trybików.
