Zainstalowałem właśnie Debiana w wersji testowej x64 i gdy wykonuję polecenie
aptitude updateKod: Zaznacz cały
aptitude upgradeKod: Zaznacz cały
root@Bartek-Komputer:/home/bartek# aptitude upgrade
Następujące pakiety zostaną USUNIĘTE:
bsh{u} bsh-gcj{u} ca-certificates-java{u} default-jre{u}
default-jre-headless{u} desktop-file-utils{u} foomatic-db-gutenprint{u}
gcj-4.4-base{u} gcj-4.4-jre{u} gcj-4.4-jre-headless{u} gcj-4.4-jre-lib{u}
gcj-jre{u} gcj-jre-headless{u} ghostscript-x{u} gs{u} ijsgutenprint{u}
imagemagick{u} java-common{u} libaccess-bridge-java{u}
libaccess-bridge-java-jni{u} libcdt4{u} libcolamd2.7.1{u}
libcommons-beanutils-java{u} libcommons-collections3-java{u}
libcommons-compress-java{u} libcommons-digester-java{u}
libcommons-logging-java{u} libdb-je-java{u} libdb4.7-java{u}
libdb4.7-java-gcj{u} libdjvulibre-text{u} libdjvulibre21{u} libeet1{u}
libeina-svn-05{u} libgcj-bc{u} libgcj-common{u} libgcj10{u}
libgcj10-awt{u} libgd2-noxpm{u} libglade2-0{u} libgle3{u} libgraph4{u}
libgraphite3{u} libgtkimageview0{u} libgvc5{u} libhsqldb-java{u}
libhsqldb-java-gcj{u} libhyphen0{u} libicu4j-java{u} libjaxp1.3-java{u}
libjline-java{u} libjtidy-java{u} libkde4-ruby1.8{u} liblucene2-java{u}
libmagickcore3-extra{u} libmythes-1.2-0{u} libneon27-gnutls{u}
libpathplan4{u} libplasma-ruby{u} libplasma-ruby1.8{u} libpython2.6{u}
libqedje0a{u} libqt4-assistant{u} libqt4-help{u} libqt4-ruby1.8{u}
libqt4-scripttools{u} libqt4-test{u} libqtruby4shared2{u} libqzion0a{u}
libregexp-java{u} libruby1.8{u} libservlet2.5-java{u}
libsmokekdecore4-3{u} libsmokekdeui4-3{u} libsmokekfile3{u}
libsmokekhtml3{u} libsmokekio3{u} libsmokeknewstuff2-3{u}
libsmokeknewstuff3-3{u} libsmokekparts3{u} libsmokektexteditor3{u}
libsmokekutils3{u} libsmokenepomuk3{u} libsmokephonon3{u}
libsmokeplasma3{u} libsmokeqtcore4-3{u} libsmokeqtdbus4-3{u}
libsmokeqtgui4-3{u} libsmokeqtnetwork4-3{u} libsmokeqtopengl4-3{u}
libsmokeqtscript4-3{u} libsmokeqtsql4-3{u} libsmokeqtsvg4-3{u}
libsmokeqttest4-3{u} libsmokeqtuitools4-3{u} libsmokeqtwebkit4-3{u}
libsmokeqtxml4-3{u} libsmokesolid3{u} libsmokesoprano3{u}
libtextcat-data-utf8{u} libtidy-0.99-0{u} libvirtodbc0{u} libwpd8c2a{u}
libwpg-0.1-1{u} libwps-0.1-1{u} libxdot4{u} lp-solve{u} openjdk-6-jre{u}
openjdk-6-jre-headless{u} openjdk-6-jre-lib{u}
openoffice.org-base-core{u} openoffice.org-calc{u}
openoffice.org-common{u} openoffice.org-core{u} openoffice.org-draw{u}
openoffice.org-emailmerge{u} openoffice.org-impress{u}
openoffice.org-java-common{u} openoffice.org-math{u}
openoffice.org-style-galaxy{u} openoffice.org-writer{u} python-uno{u}
ruby1.8{u} ttf-liberation{u} ttf-opensymbol{u} tzdata-java{u}
uno-libs3{u} ure{u} virtuoso-opensource-6.1-common{u}
0 pakietów aktualizowanych, 0 instalowanych, 129 do usunięcia i 0 nie aktualizowanych.
Do pobrania 0B archiwów. Zwolnione po rozpakowaniu: 637MB.Te dwa polecenia to były pierwsze rzeczy jakie zrobiłem w nowym systemie, więc nic nie było instalowane.
