Zainstalowałem sobie nxclient, nxnode, nxserver na vpsie na Debianie. Instalacja przebiegła bezproblemowo. Chciałem się połączyć za pomocą windowsowego klienta, a tu się pojawia błąd:
The remote proxy closed he connection while negotiating the session. this may be due to wrong authentication credentials passed to the server.Kod: Zaznacz cały
Jul 7 11:32:47 ziemiaobiecana NXSERVER-3.4.0-12[21558]: Selected node host:localhost with port:22 'main::selectNode'
Jul 7 11:32:47 ziemiaobiecana NXSERVER-3.4.0-12[21558]: Current selected node: localhost is in status: running 'main::selectNode'
Jul 7 11:32:47 ziemiaobiecana NXSERVER-3.4.0-12[21558]: Selected session type: unix-kde allowed in the profile of user: test 'NXShell::Static'
Jul 7 11:32:50 ziemiaobiecana NXNODE-3.4.0-13[21595]: ERROR: Unexpected termination of nxagent because of signal: 11 Logger::log nxnode 3921
Jul 7 11:32:50 ziemiaobiecana NXNODE-3.4.0-13[21595]: ERROR: run command: process: 21623 died because of signal: 11 Logger::log nxnode 3928
Jul 7 11:32:50 ziemiaobiecana NXSERVER-3.4.0-12[21558]: Session '142AC2E9C996CC68B557618FF71AA8AA' started by user 'test'. 'NXShell::handler_session_start'
Jul 7 11:32:50 ziemiaobiecana NXNODE-3.4.0-13[21595]: Using port '1010' on node '94.76.254.248' for session 'unix-kde'. Logger::log nxnode 6244
Jul 7 11:32:50 ziemiaobiecana NXNODE-3.4.0-13[21595]: Using host from available host list: '94.76.254.248'. Logger::log nxnode 6245
Jul 7 11:32:52 ziemiaobiecana NXSERVER-3.4.0-12[21558]: User 'test' from '83.10.125.105' logged out. 'NXLogin::reset'
Jul 7 11:33:01 ziemiaobiecana NXSERVER-3.4.0-12[21558]: ERROR: nxssh process exit with exit status: 255 and flag connected set to: [0] 'NXShell::handler_bye'
Jul 7 11:33:01 ziemiaobiecana NXSERVER-3.4.0-12[21558]: ERROR: Cannot establish ssh tunnel between nxserver and nxnode 'NXShell::handler_bye'
Jul 7 11:33:01 ziemiaobiecana NXSERVER-3.4.0-12[21558]: ERROR: Please check permissions of user's home directory on the 'NXShell::handler_bye'
Jul 7 11:33:01 ziemiaobiecana NXSERVER-3.4.0-12[21558]: ERROR: node host and file name for authorized keys set in the NX 'NXShell::handler_bye'
Jul 7 11:33:01 ziemiaobiecana NXSERVER-3.4.0-12[21558]: ERROR: node and SSHD configurations. 'NXShell::handler_bye'
Jul 7 11:33:20 ziemiaobiecana NXNODE-3.4.0-13[21629]: ERROR: Session angent timeout: session is in status: 'Initial' since too much time 'NXSessionMonitor::__handleSessionTimeout'
Jul 7 11:33:20 ziemiaobiecana NXNODE-3.4.0-13[21629]: ERROR: Error when monitoring session: Cannot handle timeout with agent pid: 0 not valid 'NXSessionMonitor::__setSessionStatus'
Jul 7 11:33:20 ziemiaobiecana NXNODE-3.4.0-13[21629]: Directory '/home/test/.nx/C-94.76.254.248-1010-142AC2E9C996CC68B557618FF71AA8AA' renamed into '/home/test/.nx/F-C-94.76.254.248-1010-142AC2E9C996CC68B557618FF71AA8AA' for further investigation Logger::log nxnode 6433
Jul 7 11:33:21 ziemiaobiecana NXNODE-3.4.0-13[21595]: Session 'unix-kde' on port '1010' failed. Logger::log nxnode 6514
Jul 7 11:33:27 ziemiaobiecana NXSERVER-3.4.0-12[21625]: ERROR: NXNodeExec: Cannot kill nxssh process: No such process 'NXNodeExec::exec'
Jul 7 11:33:27 ziemiaobiecana NXSERVER-3.4.0-12[21625]: User 'test' from '83.10.125.105' logged out. 'NXLogin::reset'pozdrawiam.
