Mam openssl, mogę wysyłać i odbierać pocztę na serwerze, na outlooku jednak nie działa wysyłanie.
W punkcie 2.1 Instalacja masz
# aptitude install postfix postfix-doc openssl
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
command_directory = /usr/sbin
mail_owner = postfix
mydomain = mojadomena.org
myhostname = mojadomena.org
mydestination = $mydomain, $myhostname, localhost, localhost.localdomain,
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
#SASL
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain = $myhostname
smtpd_recipient_restrictions =
permit_sasl_authenticated
permit_mynetworks
reject_unauth_destination
#TLS
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/smtpd.pem
smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.pem
smtpd_tls_CAfile = /etc/postfix/ssl/smtpd.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
mailbox_command = procmail -a "$EXTENSION"
Czy może ktoś mi pomóc? Dopiero od niedawna zgłębiam tajniki dystrybucji Linuksa i chyba sam sobie nie poradzę.
Udało mi się wysłać bez problemu wiadomość z serwera przez telnet localhost 25 na gmaila, z outlooka nadal nic nie mogę przesłać.
Mogę też odbierać bez problemu wiadomości poprzez openssl s_client -connect localhost:995 jaki i outlooka.
