Zainstalowałem poprawnie javę:
aptitude install sun-java6-jre sun-java6-plugin flashplugin-nonfree
Java Plug-in 1.6.0_16
Using JRE version 1.6.0_16-b01 Java HotSpot(TM) 64-Bit Server VM
User home directory = /home/scip
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class games.multi.card.thousand.Thousand not found.
java.lang.ClassNotFoundException: games.multi.card.thousand.Thousand
at sun.plugin2.applet.Applet2ClassLoader.findClass(Applet2ClassLoader.java:152)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Plugin2ClassLoader.java:445)
at sun.plugin2.applet.Plugin2Manager.createApplet(Plugin2Manager.java:2880)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Plugin2Manager.java:1397)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.net.ConnectException: Network is unreachable
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:525)
at sun.net.NetworkClient.doConnect(NetworkClient.java:161)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:394)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:529)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:233)
at sun.net.www.http.HttpClient.New(HttpClient.java:306)
at sun.net.www.http.HttpClient.New(HttpClient.java:323)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:860)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:801)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:726)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1049)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:373)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Applet2ClassLoader.java:458)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Applet2ClassLoader.java:46)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Applet2ClassLoader.java:126)
at java.security.AccessController.doPrivileged(Native Method)
at sun.plugin2.applet.Applet2ClassLoader.findClass(Applet2ClassLoader.java:123)
... 6 more
Exception: java.lang.ClassNotFoundException: games.multi.card.thousand.Thousand
2010-01-08 11:24:34 sun.awt.X11.XToolkit processException
WARNING: Exception on Toolkit thread
java.lang.StackOverflowError
at sun.awt.X11.XlibWrapper.CallErrorHandler(Native Method)
at sun.awt.X11.XToolkit.SAVED_ERROR_HANDLER(XToolkit.java:125)
at sun.awt.X11.XToolkit.GlobalErrorHandler(XToolkit.java:136)
at sun.awt.X11.XlibWrappJava Plug-in 1.6.0_16http://groups.google.com/group/pl.comp. ... fe32cea0d4
Czyli dodałem do:
~/.java/deployment/deployment.propertiesKod: Zaznacz cały
deployment.javaws.jre.0.args=-Djava.net.preferIPv4Stack\=trueKod: Zaznacz cały
#deployment.properties
#Fri Jan 08 11:24:29 CET 2010
deployment.version=6.0
deployment.capture.mime.types=true
deployment.browser.path=/usr/bin/mozilla
#Java Deployment jre's
deployment.javaws.jre.0.registered=true
deployment.javaws.jre.0.platform=1.6
deployment.javaws.jre.0.osname=Linux
deployment.javaws.jre.0.path=/usr/lib/jvm/java-6-sun-1.6.0.16/jre/bin/java
deployment.javaws.jre.0.product=1.6.0_16
deployment.javaws.jre.0.osarch=amd64
deployment.javaws.jre.0.location=http\://java.sun.com/products/autodl/j2se
deployment.javaws.jre.0.enabled=true
deployment.javaws.jre.0.args=- Djava.net.p referIPv4Stack\=true referIPv4Stack \= true
