Mam pewien problem z dodanie serwera www do nagiosa,
Dodałem wstępną konfigurację do nagiosa:
- utworzyłem plik web.cfg i dodałem go do nagios.cfg.
Podczas restartu nagiosa pojawia mi się taki błąd:
Starting nagios:CONFIG ERROR! Start aborted. Check your Nagios configuration.
Mój plik web.cfg:
# LOCALHOST.CFG - SAMPLE OBJECT CONFIG FILE FOR MONITORING THIS MACHINE
# Last Modified: 05-31-2007
# NOTE: This config file is intended to serve as an *extremely* simple
# example of how you can create configuration entries to monitor
# the local (Linux) machine.
# HOST DEFINITION
# Define a host for the local machine
define host{
use linux-server ; Name of host template to use
; This host definition will inherit all variables that are defined
; in (or inherited by) the linux-server host template definition.
host_name WWW
alias web
address 10.10.100.2
# HOST GROUP DEFINITION
# Define an optional hostgroup for Linux machines
define hostgroup{
hostgroup_name linux-servers ; The name of the hostgroup
alias Linux Servers ; Long name of the group
members web ; Comma separated list of hosts that belong to this group
# SERVICE DEFINITIONS
# Define a service to "ping" the local machine
define service{
use local-service ; Name of service template to use
host_name WWW
service_description PING
check_command check_ping!100.0,20%!500.0,60%
# Define a service to check the disk space of the root partition
# on the local machine. Warning if < 20% free, critical if
# < 10% free space on partition.
define service{
host_name WWW
service_description Root Partition
check_command check_local_disk!20%!10%!/
# Define a service to check the number of currently running procs
# on the local machine. Warning if > 250 processes, critical if
# > 400 users.
define service{
host_name localhost
service_description Total Processes
check_command check_local_procs!250!400!RSZDT
# Define a service to check the load on the local machine.
define service{
host_name WWW
service_description Current Load
check_command check_local_load!5.0,4.0,3.0!10.0,6.0,4.0
# Define a service to check the swap usage the local machine.
# Critical if less than 10% of swap is free, warning if less than 20% is free
define service{
host_name WWW
service_description Swap Usage
check_command check_local_swap!20!10
# Define a service to check SSH on the local machine.
# Disable notifications for this service by default, as not all users may have SSH enabled.
define service{
host_name WWW
service_description SSH
check_command check_ssh
notifications_enabled 0
# Define a service to check HTTP on the local machine.
# Disable notifications for this service by default, as not all users may have HTTP enabled.
define service{
host_name WWW
service_description HTTP
check_command check_http
Od razu zapytam do komunikacji między serwerem a klientem używacie ssh czy nrpe?
[ Dodano: 2009-10-27, 11:45 ]
czy ktoś może mi pomóc lub naprowadzić na rozwiązanie mojego problemu
[ Dodano: |1 Lis 2009|, 2009 17:22 ]
A czy może ktoś zna fajnego how-to jak dodać nową maszynę do nagiosa
