uruchomienie gry Vega Strike
snevill
Post autor: snevill »
Witam. Mam problem z uruchomieniem gry Vega Strike. Instalowałem ją z repozytorium. Po wpisaniu w konsoli vegastrike wyskakuje mi:
Vega Strike
See [url]http://www.gnu.org/copyleft/gpl.html[/url] for license details.
GOT SUBDIR ARG =
Found data in /usr/share/games/vegastrike
Using /usr/share/games/vegastrike as data directory
Using .vegastrike-0.4.x as the home directory
Found MODDIR = /usr/share/games/vegastrike/mods
USING HOMEDIR : /home/snevill/.vegastrike-0.4.x As the home directory
CONFIGFILE - Found a config file in home directory, using : /home/snevill/.vegastrike-0.4.x/vegastrike.config
DATADIR - No datadir specified in config file, using ; /usr/share/games/vegastrike
SIMULATION_ATOM: 0.06
MISSION_NAME is empty using : explore_universe.mission
running import sys
print sys.path
sys.path = [r"/usr/share/games/vegastrike/modules/builtin",r"/usr/share/games/vegastrike/modules",r"/usr/share/games/vegastrike/bases"]
['/usr/lib/python2.5', '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk', '/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages', '/usr/lib/python2.5/site-packages', '/usr/lib/python2.5/site-packages/Numeric', '/usr/lib/python2.5/site-packages/gst-0.10', '/var/lib/python-support/python2.5', '/var/lib/python-support/python2.5/gtk-2.0']
testing VS randomrunning import sys
print sys.path
['/usr/share/games/vegastrike/modules/builtin', '/usr/share/games/vegastrike/modules', '/usr/share/games/vegastrike/bases']
Naruszenie ochrony pamięci
Niestety ja nie mam pomysłu co mam dalej począć sterowniki do grafiki są dobrze zainstalowane, sprawdzałem.
