[+] LibTorrent 0.12.5 kompiacja - Lenny
Mi$^
Post autor: Mi$^ »
Witam. Mam problem z biblioteką LibTorrent 0.12.5.
Mój system to Debian 5.0 Lenny.
Wpisuje:
./autogen.sh
Wszystko Dobrze
./configure
Wszystko Dobrze.
Dochodzę do make i:
host426:/usr/src/libtorrent-0.12.5# make
make  all-recursive
make[1]: Wejście do katalogu `/usr/src/libtorrent-0.12.5'
Making all in src
make[2]: Wejście do katalogu `/usr/src/libtorrent-0.12.5/src'
Making all in torrent
make[3]: Wejście do katalogu `/usr/src/libtorrent-0.12.5/src/torrent'
Making all in data
make[4]: Wejście do katalogu `/usr/src/libtorrent-0.12.5/src/torrent/data'
/bin/sh ../../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../.. -I. -I./.. -I./../.. -I../../..    -g -O2 -g -DDEBUG -fvisibility=hidden   -I/usr/local/include/sigc++-2.0 -I/usr/local/lib/sigc++-2.0/include   -MT block.lo -MD -MP -MF .deps/block.Tpo -c -o block.lo block.cc
../../../libtool: line 841: X--tag=CXX: command not found
../../../libtool: line 874: libtool: ignoring unknown tag : command not found
../../../libtool: line 841: X--mode=compile: command not found
../../../libtool: line 1008: *** Warning: inferring the mode of operation is deprecated.: command not found
../../../libtool: line 1009: *** Future versions of Libtool will require --mode=MODE be specified.: command not found
../../../libtool: line 1152: Xg++: command not found
../../../libtool: line 1152: X-DHAVE_CONFIG_H: command not found
../../../libtool: line 1152: X-I.: command not found
../../../libtool: line 1152: X-I../../..: No such file or directory
../../../libtool: line 1152: X-I./..: No such file or directory
../../../libtool: line 1152: X-I./../..: No such file or directory
../../../libtool: line 1152: X-g: command not found
../../../libtool: line 1152: X-O2: command not found
../../../libtool: line 1152: X-DDEBUG: command not found
../../../libtool: line 1152: X-fvisibility=hidden: command not found
../../../libtool: line 1152: X-I/usr/local/include/sigc++-2.0: No such file or directory
../../../libtool: line 1152: X-I/usr/local/lib/sigc++-2.0/include: No such file or directory
../../../libtool: line 1152: X-MT: command not found
../../../libtool: line 1152: Xblock.lo: command not found
../../../libtool: line 1152: X-MD: command not found
../../../libtool: line 1152: X-MP: command not found
../../../libtool: line 1152: X-MF: command not found
../../../libtool: line 1152: X.deps/block.Tpo: No such file or directory
../../../libtool: line 1152: X-c: command not found
../../../libtool: line 1205: Xblock.lo: command not found
../../../libtool: line 1210: libtool: compile: cannot determine name of library object from `': command not found
make[4]: *** [block.lo] Błąd 1
make[4]: Opuszczenie katalogu `/usr/src/libtorrent-0.12.5/src/torrent/data'
make[3]: *** [all-recursive] Błąd 1
make[3]: Opuszczenie katalogu `/usr/src/libtorrent-0.12.5/src/torrent'
make[2]: *** [all-recursive] Błąd 1
make[2]: Opuszczenie katalogu `/usr/src/libtorrent-0.12.5/src'
make[1]: *** [all-recursive] Błąd 1
make[1]: Opuszczenie katalogu `/usr/src/libtorrent-0.12.5'
make: *** [all] Błąd 2
Tadam, milion błędów, jeśli ktoś wie jak to naprawić to bardzo proszę o pomoc.
iria
Post autor: iria »
Może po prostu pobierz ją z repozytorium? Tak, wiem, że nie ma tej wersji w Lennym.
Mi$^
Post autor: Mi$^ »
iria, niestety nie mogę ponieważ potrzebuje tą wersje aby zainstalować rtorrenta 0.8.5 a poza tym ten tracker na którym "siedzę" od jutro dopuszcza tylko rotrrenta w wersji 0.8.5 (tak to bym siedział na 0.8.0 z web-interfejsem ;p)
iria
Post autor: iria »
Ehhh... Myślałem, że się domyślisz, że masz spróbować pobrać pakiet z innej gałęzi Debiana.
Mi$^, przejrzałbyś wcześniej forum. Dzisiaj napisałem w jednym temacie, jak najprościej przygotować system do kompilacji.
Mi$^
Post autor: Mi$^ »
Temat do zamknięcia. Dziękuję iria i fnmirk za pomoc.
