Jak odinstalowa
nieobecny
Jak odinstalować sendmail bez połowy Gnome?
Post autor: nieobecny »
Witam. Chciałbym odinstalować pakiet sendmail, lecz gdy próbuję to zrobić system zabiera się za odinstalowanie prawie całego Gnome:
Następujące pakiety zostaną USUNIÊTE:
  alacarte{u} bzip2{u} capplets-data{u} deskbar-applet{u}
  desktop-file-utils{u} dmz-cursor-theme{u} eog{u} evince{u}
  evolution-common{u} evolution-data-server-common{u}
  fast-user-switch-applet{u} file-roller{u} finger{u} gcalctool{u}
  gconf-editor{u} gdm{u} gedit{u} gedit-common{u} gnome-about{u}
  gnome-applets{u} gnome-applets-data{u} gnome-backgrounds{u}
  gnome-control-center{u} gnome-core{u} gnome-desktop-data{u}
  gnome-media-common{u} gnome-menus{u} gnome-netstatus-applet{u}
  gnome-nettool{u} gnome-network-admin{u} gnome-panel{u}
  gnome-panel-data{u} gnome-power-manager{u} gnome-screensaver{u}
  gnome-session{u} gnome-settings-daemon{u} gnome-system-monitor{u}
  gnome-system-tools{u} gnome-themes{u} gnome-user-guide{u} gnome-utils{u}
  gnome-volume-manager{u} gstreamer0.10-alsa{u} gstreamer0.10-gnomevfs{u}
  gstreamer0.10-plugins-base{u} gstreamer0.10-tools{u} gstreamer0.10-x{u}
  gtk2-engines{u} gtkhtml3.14{u} gucharmap{u} libapm1{u} libavahi-ui0{u}
  libbluetooth2{u} libcairomm-1.0-1{u} libcamel1.2-11{u}
  libcompress-raw-zlib-perl{u} libcompress-zlib-perl{u} libcpufreq0{u}
  libdmx1{u} libdv4{u} libebook1.2-9{u} libecal1.2-7{u}
  libedata-book1.2-2{u} libedata-cal1.2-6{u} libedataserver1.2-9{u}
  libedataserverui1.2-8{u} libexempi3{u} libffi5{u} libgalago3{u}
  libglibmm-2.4-1c2a{u} libgmyth0{u} libgnome-media0{u} libgnome-pilot2{u}
  libgnome-window-settings1{u} libgnomecups1.0-1{u} libgnomekbd-common{u}
  libgnomekbd2{u} libgnomekbdui2{u} libgnomeprint2.2-0{u}
  libgnomeprint2.2-data{u} libgnomeprintui2.2-0{u}
  libgnomeprintui2.2-common{u} libgnomevfs2-bin{u} libgpgme11{u}
  libgstreamer-plugins-base0.10-0{u} libgstreamer0.10-0{u}
  libgtk-vnc-1.0-0{u} libgtkhtml3.14-19{u} libgtkmm-2.4-1c2a{u}
  libgtksourceview-common{u} libgtksourceview1.0-0{u}
  libgtksourceview2.0-0{u} libgtksourceview2.0-common{u} libgucharmap6{u}
  libgweather-common{u} libgweather1{u} libhtml-parser-perl{u}
  libhtml-tagset-perl{u} libhtml-tree-perl{u} libio-compress-base-perl{u}
  libio-compress-zlib-perl{u} libkpathsea4{u} libmailtools-perl{u}
  libmetacity0{u} libmysqlclient15off{u} libnautilus-burn4{u}
  libnet-dbus-perl{u} libnm-glib0{u} liboobs-1-4{u} libopal-2.2{u}
  libpanel-applet2-0{u} libpisock9{u} libpisync1{u} libpoppler-glib3{u}
  libpt-1.10.10{u} libpt-1.10.10-plugins-alsa{u}
  libpt-1.10.10-plugins-v4l{u} libpth20{u} libshout3{u} libslab0{u}
  libspectre1{u} libspeexdsp1{u} libtimedate-perl{u} libtotem-plparser10{u}
  libtrackerclient0{u} liburi-perl{u} libvisual-0.4-0{u} libwww-perl{u}
  libxklavier12{u} libxml-parser-perl{u} libxml-twig-perl{u} libxss1{u}
  metacity{u} metacity-common{u} mysql-common{u} nautilus{u}
  nautilus-cd-burner{u} nautilus-data{u} pkg-config{u} python-cairo{u}
  python-dbus{u} python-gdata{u} python-glade2{u} python-gmenu{u}
  python-gnome2{u} python-gnome2-desktop{u} python-gobject{u}
  python-gtk2{u} python-gtksourceview2{u} python-numeric{u}
  python-pyorbit{u} system-tools-backends{u} totem-common{u} vinagre{u}
  vino{u} zenity{u} zip{u}
Następujące pakiety zostaną zaktualizowane:
  libssl0.9.8 openssl
2 pakietów aktualizowanych, 0 instalowanych, 157 do usunięcia i 0 nie aktualizowanych.
Do pobrania 2019kB archiwów. Zwolnione po rozpakowaniu: 476MB.
Kontynuować? [T/n/?] n
Przerwane.
Potem mi się to pojawiało za każdym razem gdy chciałem zaktualizować system. Ale sobie z tym poradziłem wpisując apt-get update, upgrade i następnie aptitude już działało normalnie. Lecz nadal nie wiem jak ten pakiet usunąć "sendmail" bez usuwania większości Gnome? Za odpowiedź z góry dziękuję. Pozdrawiam :)
ArnVaker
Post autor: ArnVaker »
Zlituj się, ile razy można tłumaczyć czym są metapakiety?
Na początek wydaj polecenie:
aptitude install alacarte dmz-cursor-theme evince file-roller gcalctool gconf-editor gdm gedit gnome-applets gnome-control-center gnome-core gnome-power-manager gnome-screensaver gnome-utils
lub takie:
aptitude unmarkauto alacarte dmz-cursor-theme evince file-roller gcalctool gconf-editor gdm gedit gnome-applets gnome-control-center gnome-core gnome-power-manager gnome-screensaver gnome-utils
Potem pokaż cały wynik:
aptitude purge sendmail -s
nieobecny
ArnVaker pisze:Potem pokaż cały wynik:
# aptitude purge sendmail -s
Budowanie drzewa zależności
Odczyt opisów zadań... Gotowe
Nie zostaną zainstalowane, zaktualizowane ani usunięte żadne pakiety.
0 pakietów aktualizowanych, 0 instalowanych, 0 do usunięcia i 0 nie aktualizowanych.
Pakiety zostałyby pobrane/zainstalowane/usunięte.
ArnVaker
Założyłeś temat o odinstalowaniu pakietu, którego nie masz?
apt-cache policy sendmail
nieobecny
Chciałem to usunąć
sendmail: /usr/sbin/sendmail /usr/lib/sendmail /usr/lib64/sendmail /usr/share/man/man8/sendmail.8.gz
ArnVaker
Te pliki dostarczane są przez kilka różnych pakietów: http://packages.debian.org/search?searc ... e&arch=any
Sprawdź z jakiego pochodzą u Ciebie:
dpkg -S /usr/sbin/sendmail
nieobecny
ArnVaker pisze:Te pliki dostarczane są przez kilka różnych pakietów: http://packages.debian.org/search?searc ... e&arch=any
# dpkg -S /usr/sbin/sendmail
exim4-daemon-light: /usr/sbin/sendmail
A poprzez wpisanie:
apt-cache depends pakiet
lub:
apt-cache unmet pakiet
i zobaczenie z jakich zależności korzysta ten pakiet i usunięcie ich z tym pakietem pewnie spowoduje jakieś szkody? Bo np. w Fluxbox to nie ma takich problemów, usuwam co mi nie pasuje, a w tym Gnome to jest tak wszystko pogmatwane.
ArnVaker
Ja nie mam exim4 i żyję... Chcąc się go pozbyć w Twojej sytuacji zrobiłbym tak:
dpkg -P $(dpkg -l | grep exim4 | awk '{print $2}')
To usunie wszystkie paczki z exim4 w nazwie bez zważania na zależności.
Trzeba by potem zrobić z nimi porządek w oparciu o:
aptitude dist-upgrade -s
Dla świętego spokoju możesz sprawdzić co powie polecenie:
aptitude purge ~nexim4 -s
nieobecny pisze:w Fluxbox to nie ma takich problemów, usuwam co mi nie pasuje
Fluxbox to jeden pakiet, a gnome dziesiątki... Gdybyś instalował gnome po kawałku bez używania metapaczek, a nie np. wraz z systemem nie byłoby problemu.
nieobecny
Dziękuję usunęło się, ale jak teraz usunąć sendmaila, bo chcę aby nie był otwarty ten port 25, najlepiej go usunąć. Ale ktoś mi mówił, że muszę się pozbyć wszystkich plików sendmail:
PORT    STATE SERVICE
25/tcp  open  smtp
631/tcp open  ipp
Bo już sprawdzałem i nie da się go tak normalnie zamknąć z konsoli poleceniem lub dopisaniem do reguł.
ArnVaker
Przyznaję bez bicia, że nie wiem już o co Ci właściwie chodzi.
