kopia zapasowa PostgreSQL za pomoc
pracochlik
kopia zapasowa PostgreSQL za pomocą Baculi
Post autor: pracochlik »
Witam. W poszukiwaniu sposobu wykonania kopi zapasowej PostgreSQL za pomocą Baculi, trafiłem na poniższy poradnik:
Kopia zapasowa PostgreSQL
I mam pewien problem z dodaniem ,,joba'' do ,,baculi''.
bacula-dir:
Job {
  Name = "cc-db"
  JobDefs = "cc-pgsql"
  Level = Full
  FileSet="cc-db"
  Client = cc-fd
  Schedule = "WeeklyCycledb"
  # This creates a backup of the databases with pg_dump to fifos
  Client Run Before Job = "su - postgres -c \"/etc/bacula/make_database_backup\""
  # This deletes the backup and fifo files
  Client Run After Job  = "su - postgres -c \"/etc/bacula/delete_database_backup\""
  Priority = 17                   # run after main backup
FileSet {
  Name = "cc-db"
  Include {
     Options {
        signature = MD5
        readfifo = yes
       File = "/var/lib/pgsql/data/dump/globalobjects.dump"
       File = "|/etc/bacula/listdbdump 192.168.11.11 5432"
JobDefs {
    Name = "cc-pgsql"
    Type = Backup
    Level = Full
    Client = cc-fd
    FileSet = "cc-db"
    Schedule = "WeeklyCycle"
    Storage = bacula-sd
    Messages = Standard
    Pool = cc-db
Client {
    Name = cc-sd
  Address = 192.168.11.11
    FDPort = 9102
    Catalog = MyCatalog
    Password = "password"
Pool {
    Name = cc-db
    Pool Type = Backup
    Recycle = yes
    AutoPrune = yes
    LabelFormat = "BackupCCpgsql"
    Maximum Volume Bytes = 2000M
    Volume Retention = 365 days
    #Accept Any Volume = yes;
Storage {
    Name = bacula-sd
    Address = 192.168.11.13
    SDPort = 9103
    Device = cc-db
  Media Type = File
Wyskakuje mi błąd:
17-Aug 16:12 bacula-dir JobId 174: Start Backup JobId 174, Job=cc-db.2009-08-17_16.12.03.05
17-Aug 16:12 bacula-dir JobId 174: Using Device "cc-db"
17-Aug 16:12 bacula-dir JobId 174: Fatal error: Error running program: /etc/bacula/listdbdump 192.168.11.11 5432. ERR=No such file or directory
17-Aug 16:12 bacula-dir JobId 174: Error: Bacula bacula-dir 2.4.4 (28Dec08): 17-Aug-2009 16:12:05
Plik istnieje na kliencie. Może coś źle zrozumiałem w przedstawionym opisie.
Oryginalna zawartość z poradnika bacula-dir:
Job {
  Name = "hymost-db"
  JobDefs = "DefaultJob"
  Level = Full
  FileSet="myhost-db"
  Client = myhost-fd
  Schedule = "WeeklyCycleAfterBackup"
FileSet {
  Name = "myhost-db"
  Include {
     Options {
        signature = MD5
        readfifo = yes
       File = "|/etc/bacula/listdbdump myhost-or-ip.mynet.lan 5432"
I w miejsce:
Wstawiłem swój adres ip klienta.
Więc co mogę robić nie tak?
timor
Re: kopia zapasowa PostgreSQL za pomocą Baculi
Post autor: timor »
A ma ten skrypt atrybut do wykonywania? (wiem - głupie, ale czasem właśnie na takich pierdołach świat staje :) )
