cat: /etc/rc.conf: No such file or directory
All Checks have passed, continuing with install...
Can't open /etc/rc.conf: No such file or directory.
chown: `diradmin:diradmin': invalid user
mkdir: cannot create directory `/etc/virtual/usage': File exists
Checking quotas...
Bad number of arguments.
quotaoff: Usage:
quotaoff [-guvp] [-F quotaformat] [-x state] -a
quotaoff [-guvp] [-F quotaformat] [-x state] filesys ...
-a, --all turn quotas on for all filesystems
-f, --off turn quotas off
-u, --user operate on user quotas
-g, --group operate on group quotas
-p, --print-state print whether quotas are on or off
-x, --xfs-command=cmd perform XFS quota command
-F, --format=formatname operate on specific quota format
-v, --verbose print more messages
-h, --help display this help text and exit
-V, --version display version information and exit
Doesn't look like you have newsyslog installed
./install.sh: line 145: fetch: command not found
./install.sh: line 148: fetch: command not found
Error downloading the services file
chown: invalid user: `diradmin:diradmin'
Checking quotas...
quotaoff: Usage:
