Mam network managera 0.7.1 i nie mogę go zmusić do realizacji połączenia vpn. Tzn. łączy się na chwile ale później rozłącza.
Ale nawet przez tę chwilę tunel nie działa.
Natomiast w konsoli działa dobrze.
Miał ktoś podobny problem?
Jedyne co znalazłem w logach to:
Jul 9 23:19:16 tomideb nm-openvpn[5755]: TCP connection established with xxxx
Jul 9 23:19:16 tomideb nm-openvpn[5755]: TCPv4_CLIENT link local: [undef]
Jul 9 23:19:16 tomideb nm-openvpn[5755]: TCPv4_CLIENT link remote: xxxx
Jul 9 23:19:16 tomideb nm-openvpn[5755]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Jul 9 23:19:17 tomideb nm-openvpn[5755]: [xxxx.pl] Peer Connection Initiated with xxxxx
Jul 9 23:19:18 tomideb nm-openvpn[5755]: Preserving previous TUN/TAP instance: tap0
Jul 9 23:19:18 tomideb nm-openvpn[5755]: /usr/lib/NetworkManager/nm-openvpn-service-openvpn-helper tap0 1500 1576 10.15.16.10 255.255.255.0 restart
Jul 9 23:19:18 tomideb NetworkManager: <info> VPN plugin failed: 2
Jul 9 23:19:18 tomideb nm-openvpn[5755]: script failed: external program exited with error status: 1
Jul 9 23:19:18 tomideb nm-openvpn[5755]: Exiting
Jul 9 23:19:18 tomideb avahi-daemon[3844]: Withdrawing address record for 10.15.16.10 on tap0.
Jul 9 23:19:18 tomideb nm-system-settings: SCPlugin-Ifupdown: devices removed (udi: /org/freedesktop/Hal/devices/net_00_ff_d0_cf_5c_96)
Jul 9 23:19:18 tomideb NetworkManager: <info> VPN plugin failed: 1
Jul 9 23:19:18 tomideb NetworkManager: <info> VPN plugin state changed: 6
Jul 9 23:19:18 tomideb NetworkManager: <info> VPN plugin state change reason: 0
Jul 9 23:19:18 tomideb NetworkManager: <WARN> connection_state_changed(): Could not process the request because no VPN connection was active.
Jul 9 23:19:18 tomideb NetworkManager: nm_system_device_flush_ip4_routes_with_iface: assertion `iface_idx >= 0' failed
Jul 9 23:19:18 tomideb NetworkManager: nm_system_device_flush_ip4_addresses_with_iface: assertion `iface_idx >= 0' failed
Jul 9 23:19:18 tomideb NetworkManager: <info> (tap0): writing resolv.conf to /sbin/resolvconfPs. Używam aktualnego Squeeze
