Brak p
meewosh88
Brak płynnego odtwarzania z Youtube - Intel 945GM, Lenny
Post autor: meewosh88 »
Mam problem z grafiką mianowicie np. podczas oglądania filmów na youtube ekran mi "czka", "klatkuje", innymi słowy nie jest płynny.
lspci:
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 01)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
03:00.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
03:01.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller
03:01.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 19)
03:01.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 0a)
03:01.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 05)
0b:00.0 Network controller: Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01)
Zawartość pliku xorg.conf -prawie nic nie ma:
milosz@debian:~$ cat /etc/X11/xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
EndSection
Section "Device"
	Identifier	"Configured Video Device"
EndSection
Section "Monitor"
	Identifier	"Configured Monitor"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Monitor		"Configured Monitor"
EndSection
Próbowałem skonfigurować go samemu poprzez wywołanie komendy:
 dpkg-reconfigure xserver-xorg
ale zaczął mi od kroku 6 według tego http://debian.linux.pl/viewtopic.php?t=492 i się wysypał po kroku 12 z błędem
milosz@debian:~$ sudo dpkg-reconfigure xserver-xorg
[sudo] password for milosz:
xserver-xorg postinst warning: overwriting possibly-customised configuration
   file; backup in /etc/X11/xorg.conf.20090322153621
Próbowałem również wpisać:
ale również to samo
milosz@debian:~$ sudo dpkg-reconfigure -phigh xserver-xorg
   file; backup in /etc/X11/xorg.conf.20090322154949
Wszelka pomoc mile widziana :)
iria
Post autor: iria »
Zamień sekcję "device":
Section "Device"
	Driver		"intel"
	BoardName	"Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller"
	BusID		"PCI:0:2:0"
	Option        "ExaNoComposite"    "false"
    	Option         "AccelMethod"         "exa"
    	Option        "MigrationHeuristic"     "greedy"
    	Option        "FramebufferCompression" "false"
    	Option 		"XvPreferOverlay" 	"boolean"
EndSection
,oraz sprawdź czy masz zainstalowane, te pakiety:
  • libgl1-mesa-dri
    libgl1-mesa-glx
meewosh88
po podmianie sekcji 'device' jest o niebo lepiej, ale to jeszcze nie to co na windows'ie. Flashe jeszcze troche "tną"
Pakiety chyba mam, bo coś takiego jest
milosz@debian:~$ sudo aptitude install libgl1-mesa-dri
Budowanie drzewa zależności
Odczyt opisów zadań... Gotowe
Nie zostaną zainstalowane, zaktualizowane ani usunięte żadne pakiety.
0 pakietów aktualizowanych, 0 instalowanych, 0 do usunięcia i 0 nie aktualizowanych.
iria
Post autor: iria »
Więcej na razie nie uzyskasz.
Masz najnowszą wersję flasha? 10?
Pewnie oglądasz HD i to na pełnym ekranie, bo u mnie, tylko takie się tną.
Zawsze możesz otworzyć flasha np. w mplayerze. Gdy otwierasz stonkę z flashem, on zapisuje się w '/tmp' , lub używając Iceweasel z rozszerzeniem 'mediaplayerconnectivity', w którym można ustawić zewnetrzne programy do otwierania multimediów. Dla Opery też widziałem, jakiś sposób, ale już go nie pamiętam (pewnie do znalezienia w Google).
Dla pewności sprawdź, jak ten sam flash odtwarza pod Iceweasel, ponieważ może to być problem jedynie z Operą.
meewosh88
Tak jak mówisz HD ja pelnym ekranie tną, ale mimo wszystko wydaje mi sie, ze pod IceWeasel lepiej wyświetla.
Dzięki wielkie za pomoc!
P.S powoli konfiguracja debiana dobiega do końca mam nadzieję :p
