Robie wszystko zgodnie z how to Kaki i podczas konfiguracji taki bład
nagłówki instalowałem bo przecież bym sterowników od grafiki nie zainstalował bez nich.hat is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.26-1-amd64/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Wejście do katalogu `/tmp/vmware-config0/vmmon-only'
make -C /lib/modules/2.6.26-1-amd64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Wejście do katalogu `/usr/src/linux-headers-2.6.26-1-amd64'
/tmp/vmware-config0/vmmon-only/Makefile:89: *** Inappropriate build environment: you wanted to use gcc version 4.3.3 while kernel attempts to use gcc version 4.1.3.
/tmp/vmware-config0/vmmon-only/Makefile:91: *** For proper build you'll have to replace gcc-4.1 with symbolic link to /usr/bin/gcc. Stop.
make[1]: *** [_module_/tmp/vmware-config0/vmmon-only] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/linux-headers-2.6.26-1-amd64'
make: *** [vmmon.ko] Błąd 2
make: Opuszczenie katalogu `/tmp/vmware-config0/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference ... linux.html".
Execution aborted.
