Iceweasel - niestabilne dzia
Iceweasel - niestabilne działanie
Witam serdecznie,
mam taki problem zainstalowałem firefoxa no i bach.. chce go uruchomić.. i pojawia się i znika... gdzie może być problem bo już przegrzebałem wszystko i nie mogę nic znaleść.
bardzo proszę o pomoc
Error: Cairo does not yet support the requested image format:
Depth: 8
Alpha mask: 0x00000000
Red mask: 0x00000007
Greenmask: 0x00000038
Blue mask: 0x000000c0
Please file an enhacement request (quoting the above) at:
[url]http://bugs.freedesktop.org/enter_bug.cgi?product=cairo[/url]
firefox-bin: /build/buildd/libcairo-1.2.4/scr/cairo-image-surface.c:155: _cairo_
format_from_pixman_format: Warunek zapewnienia 'NOT_REACHED' nie został spełniony.
cat /etc/X11/xorg.conf
glxinfo |grep direct
uname -r
ks36207:~# uname -r
2.6.27.10-grsec-xxxx-grs-ipv4-32
ks36207:~# cat /etc/X11/xorg.conf
# package.
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbVariant" "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "vesa"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-51
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
EndSection
Section "DRI"
Mode 0666
EndSection
-bash: glxinfo: command not found
Firefox co prawda mówi że to bug i żebyś to zgłosił odpowiednim władzom, ale nie podejmowałbym tak radykalnych działań. Na moje oko problem tkwi w wersji biblioteki libcairo; moja wersja to 1.6.4, ale ja korzystam z Debiana unstable. Dorzuć jeszcze
Offtopem zapytam: wygodnie CI używać francuskiego układu klawiatury?
cat /etc/apt/sources.list
deb [url]ftp://mir1.ovh.net/debian/[/url] etch main
deb-src [url]ftp://mir1.ovh.net/debian/[/url] etch main
deb [url]http://security.debian.org/[/url] etch/updates main
deb-src [url]http://security.debian.org/[/url] etch/updates main
Tak czułem że Etch. Uzupełnij dane w profilu na forum, na przyszłość oszczędzi to dociekań ;-). Spróbuj dodać backporty
i spróbuj podnieść wersję libcairo. Swoją drogą Lenny chyba rozwiązałby ten problem.deb http://www.backports.org/debian etch-backports main contrib non-free
