Jest dobrze. resolv.conf na drugim komputerze ma trzy dnsy z moim włącznie i działa - query-time skraca się do 0ms.
Pogadałem sobie z dpgk -l
 ale
lis6502@Nexus:/var/cache/bind$ ls -la
razem 1
drwxrwxr-x  2 root bind  48 gru  8 05:19 .
drwxr-xr-x 19 root root 504 sty  2 15:01 ..
lis6502@Nexus:/var/cache/bind$ sudo ls
Ta lista będzie gdzieś indziej. Logicznie myśląc
lis6502@Nexus:/etc/bind$ ls -l |grep db
-rw-r--r-- 1 root root  237 gru  8 05:19 db.0
-rw-r--r-- 1 root root  271 gru  8 05:19 db.127
-rw-r--r-- 1 root root  237 gru  8 05:19 db.255
-rw-r--r-- 1 root root  353 gru  8 05:19 db.empty
-rw-r--r-- 1 root root  270 gru  8 05:19 db.local
-rw-r--r-- 1 root root 2878 gru  8 05:19 db.root
ale znowu żaden z tych plików nie zawiera ip
http://www.debian.org, czy
http://www.xnxx.com:Kod: Zaznacz cały
lis6502@Nexus:/etc/bind$ cat db.*
; BIND reverse data file for broadcast zone
$TTL    604800
@       IN      SOA     localhost. root.localhost. (
                              1         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
                         604800 )       ; Negative Cache TTL
@       IN      NS      localhost.
; BIND reverse data file for local loopback interface
$TTL    604800
                              1         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
@       IN      NS      localhost.
1.0.0   IN      PTR     localhost.
$TTL    604800
                              1         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
@       IN      NS      localhost.
; BIND reverse data file for empty rfc1918 zone
; DO NOT EDIT THIS FILE - it is used for multiple zones.
; Instead, copy it, edit named.conf, and use that copy.
$TTL    86400
                              1         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
                          86400 )       ; Negative Cache TTL
@       IN      NS      localhost.
; BIND data file for local loopback interface
$TTL    604800
                              2         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
@       IN      NS      localhost.
@       IN      A       127.0.0.1
@       IN      AAAA    ::1
;       This file holds the information on root name servers needed to
;       initialize cache of Internet domain name servers
;       (e.g. reference this file in the "cache  .  <file>"
;       configuration file of BIND domain name servers).
;       This file is made available by InterNIC
;       under anonymous FTP as
;           file                /domain/named.root
;           on server           FTP.INTERNIC.NET
;       -OR-                    RS.INTERNIC.NET
;       last update:    Feb 04, 2008
;       related version of root zone:   2008020400
; formerly NS.INTERNIC.NET
.                        3600000  IN  NS    A.ROOT-SERVERS.NET.
A.ROOT-SERVERS.NET.      3600000      A     198.41.0.4
A.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:BA3E::2:30
; formerly NS1.ISI.EDU
.                        3600000      NS    B.ROOT-SERVERS.NET.
B.ROOT-SERVERS.NET.      3600000      A     192.228.79.201
; formerly C.PSI.NET
.                        3600000      NS    C.ROOT-SERVERS.NET.
C.ROOT-SERVERS.NET.      3600000      A     192.33.4.12
; formerly TERP.UMD.EDU
.                        3600000      NS    D.ROOT-SERVERS.NET.
D.ROOT-SERVERS.NET.      3600000      A     128.8.10.90
; formerly NS.NASA.GOV
.                        3600000      NS    E.ROOT-SERVERS.NET.
E.ROOT-SERVERS.NET.      3600000      A     192.203.230.10
; formerly NS.ISC.ORG
.                        3600000      NS    F.ROOT-SERVERS.NET.
F.ROOT-SERVERS.NET.      3600000      A     192.5.5.241
F.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2f::f
; formerly NS.NIC.DDN.MIL
.                        3600000      NS    G.ROOT-SERVERS.NET.
G.ROOT-SERVERS.NET.      3600000      A     192.112.36.4
; formerly AOS.ARL.ARMY.MIL
.                        3600000      NS    H.ROOT-SERVERS.NET.
H.ROOT-SERVERS.NET.      3600000      A     128.63.2.53
H.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:1::803f:235
; formerly NIC.NORDU.NET
.                        3600000      NS    I.ROOT-SERVERS.NET.
I.ROOT-SERVERS.NET.      3600000      A     192.36.148.17
; operated by VeriSign, Inc.
.                        3600000      NS    J.ROOT-SERVERS.NET.
J.ROOT-SERVERS.NET.      3600000      A     192.58.128.30
J.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:C27::2:30
; operated by RIPE NCC
.                        3600000      NS    K.ROOT-SERVERS.NET.
K.ROOT-SERVERS.NET.      3600000      A     193.0.14.129
K.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fd::1
; operated by ICANN
.                        3600000      NS    L.ROOT-SERVERS.NET.
L.ROOT-SERVERS.NET.      3600000      A     199.7.83.42
; operated by WIDE
.                        3600000      NS    M.ROOT-SERVERS.NET.
M.ROOT-SERVERS.NET.      3600000      A     202.12.27.33
M.ROOT-SERVERS.NET.      3600000      AAAA  2001:dc3::35
; End of File
Z cache'owaniem to jest jakaś lipa moim zdaniem.
lis6502@Nexus:~/programy/openarena-0.8.1$ date && dig [url]www.debian.org[/url]
pią, 2 sty 2009, 21:16:21 CET
; <<>> DiG 9.5.0-P2 <<>> [url]www.debian.org[/url]
;; global options:  printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 58995
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 3, ADDITIONAL: 0
;; QUESTION SECTION:
;[url]www.debian.org[/url].                        IN      A
;; ANSWER SECTION:
[url]www.debian.org[/url].         300     IN      A       194.109.137.218
;; AUTHORITY SECTION:
debian.org.             3600    IN      NS      klecker.debian.org.
debian.org.             3600    IN      NS      rietz.debian.org.
debian.org.             3600    IN      NS      raff.debian.org.
;; Query time: 172 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Fri Jan  2 21:16:22 2009
;; MSG SIZE  rcvd: 109
pią, 2 sty 2009, 21:16:37 CET
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 55113
;; ANSWER SECTION:
[url]www.debian.org[/url].         285     IN      A       194.109.137.218
debian.org.             3585    IN      NS      raff.debian.org.
debian.org.             3585    IN      NS      rietz.debian.org.
debian.org.             3585    IN      NS      klecker.debian.org.
;; Query time: 1 msec
;; WHEN: Fri Jan  2 21:16:37 2009
 Tutaj widać że działa. Poszedłem coś zjeść, wracam
pią, 2 sty 2009, 22:00:44 CET
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14661
;; ANSWER SECTION:
debian.org.             938     IN      NS      raff.debian.org.
debian.org.             938     IN      NS      klecker.debian.org.
debian.org.             938     IN      NS      rietz.debian.org.
;; Query time: 235 msec
;; WHEN: Fri Jan  2 22:00:44 2009
 Chyba że ja coś źle robię.
