Wynik fdisk -l
Disk /dev/sde: 320.0 GB, 320071851520 bytes
255 heads, 63 sectors/track, 38913 cylinders
/dev/sde1 * 1 6274 50395873+ 7 HPFS/NTFS
/dev/sde2 6275 38913 262172767+ 7 HPFS/NTFS
Disk /dev/sdf: 320.0 GB, 320072933376 bytes
/dev/sdf1 1 38913 312568641 42 SFS
Disk /dev/hdb: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders
/dev/hdb1 1 1824 14651248+ 83 Linux
/dev/hdb2 1825 4865 24426832+ 5 Extended
/dev/hdb5 1825 4742 23438803+ 83 Linux
/dev/hdb6 4743 4865 987966 82 Linux swap / Solaris
debian:/home/omen# ntfs-3g /dev/sde2 /mnt/dysk1a
WARNING: Deficient Linux kernel detected. Some driver features are
not available (swap file on NTFS, boot from NTFS by LILO), and
unmount is not safe unless it's made sure the ntfs-3g process
naturally terminates after calling 'umount'. If you wish this
message to disappear then you should upgrade to at least kernel
version 2.6.20, or request help from your distribution to fix
the kernel problem. The below web page has more information:
[url]http://ntfs-3g.org/support.html#fuse26[/url]
O co chodzi w tej informacji?
Głównie chodzi mi o to abym miał wszystkie te partycje NTFS w "moim komputerze" i żebym miał do nich dostęp tam, a nie tylko poprzez katalog /mnt.
Pomożecie?
