rozumiem ze ponizszy plik jest powodem zamieszania ale nie potrafie stwierdzic do jakiego pakietu nalezy??
scripts/kconfig/lxdialog/dialog.h:31:20: curses.h: Nie ma takiego pliku ani katalogu
/usr/src/linux# make menuconfig
HOSTCC scripts/kconfig/lxdialog/checklist.o
In file included from scripts/kconfig/lxdialog/checklist.c:24:
scripts/kconfig/lxdialog/dialog.h:128: error: syntax error before "use_colors"
scripts/kconfig/lxdialog/dialog.h:128: warning: type defaults to `int' in declaration of `use_colors'
scripts/kconfig/lxdialog/dialog.h:128: warning: data definition has no type or storage class
scripts/kconfig/lxdialog/dialog.h:129: error: syntax error before "use_shadow"
scripts/kconfig/lxdialog/dialog.h:129: warning: type defaults to `int' in declaration of `use_shadow'
scripts/kconfig/lxdialog/dialog.h:129: warning: data definition has no type or storage class
scripts/kconfig/lxdialog/dialog.h:131: error: syntax error before "attributes"
scripts/kconfig/lxdialog/dialog.h:131: warning: type defaults to `int' in declaration of `attributes'
scripts/kconfig/lxdialog/dialog.h:131: warning: data definition has no type or storage class
scripts/kconfig/lxdialog/dialog.h:143: error: syntax error before '*' token
scripts/kconfig/lxdialog/dialog.h:143: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/dialog.h:146: error: syntax error before '*' token
scripts/kconfig/lxdialog/dialog.h:146: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/dialog.h:147: error: syntax error before '*' token
scripts/kconfig/lxdialog/dialog.h:147: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/dialog.h:148: error: syntax error before '*' token
scripts/kconfig/lxdialog/dialog.h:148: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/dialog.h:149: error: syntax error before '*' token
scripts/kconfig/lxdialog/dialog.h:150: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/dialog.h:151: error: syntax error before '*' token
scripts/kconfig/lxdialog/dialog.h:151: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/checklist.c:31: error: syntax error before '*' token
scripts/kconfig/lxdialog/checklist.c:33: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/checklist.c: In function `print_item':
scripts/kconfig/lxdialog/checklist.c:37: warning: implicit declaration of function `wattrset'
scripts/kconfig/lxdialog/checklist.c:37: error: `win' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:37: error: (Each undeclared identifier is reported only once
scripts/kconfig/lxdialog/checklist.c:37: error: for each function it appears in.)
scripts/kconfig/lxdialog/checklist.c:38: warning: implicit declaration of function `wmove'
scripts/kconfig/lxdialog/checklist.c:38: error: `choice' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:40: warning: implicit declaration of function `waddch'
scripts/kconfig/lxdialog/checklist.c:43: error: `selected' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:44: warning: implicit declaration of function `wprintw'
scripts/kconfig/lxdialog/checklist.c:44: error: `status' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:47: warning: implicit declaration of function `mvwaddch'
scripts/kconfig/lxdialog/checklist.c:47: error: `item' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:49: warning: implicit declaration of function `waddstr'
scripts/kconfig/lxdialog/checklist.c:52: warning: implicit declaration of function `wrefresh'
scripts/kconfig/lxdialog/checklist.c: At top level:
scripts/kconfig/lxdialog/checklist.c:59: error: syntax error before '*' token
scripts/kconfig/lxdialog/checklist.c:61: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/checklist.c: In function `print_arrows':
scripts/kconfig/lxdialog/checklist.c:62: error: `win' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:62: error: `y' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:62: error: `x' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:64: error: `scroll' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:76: error: `height' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:79: error: `item_no' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:79: error: `choice' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:95: error: syntax error before '*' token
scripts/kconfig/lxdialog/checklist.c:96: warning: function declaration isn't a prototype
scripts/kconfig/lxdialog/checklist.c: In function `print_buttons':
scripts/kconfig/lxdialog/checklist.c:97: error: `width' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:98: error: `height' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:100: error: `dialog' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:100: error: `selected' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c: In function `dialog_checklist':
scripts/kconfig/lxdialog/checklist.c:117: error: `WINDOW' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:117: error: `dialog' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:117: error: `list' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:117: warning: left-hand operand of comma expression has no effect
scripts/kconfig/lxdialog/checklist.c:121: warning: implicit declaration of function `endwin'
scripts/kconfig/lxdialog/checklist.c:122: warning: implicit declaration of function `fprintf'
scripts/kconfig/lxdialog/checklist.c:122: error: `stderr' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:140: error: `COLS' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:141: error: `LINES' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:143: error: `stdscr' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:145: warning: implicit declaration of function `newwin'
scripts/kconfig/lxdialog/checklist.c:146: warning: implicit declaration of function `keypad'
scripts/kconfig/lxdialog/checklist.c:146: error: `TRUE' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:166: warning: implicit declaration of function `subwin'
scripts/kconfig/lxdialog/checklist.c:199: warning: implicit declaration of function `wnoutrefresh'
scripts/kconfig/lxdialog/checklist.c:201: warning: implicit declaration of function `doupdate'
scripts/kconfig/lxdialog/checklist.c:204: warning: implicit declaration of function `wgetch'
scripts/kconfig/lxdialog/checklist.c:211: error: `KEY_UP' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:211: error: `KEY_DOWN' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:221: error: `FALSE' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:222: warning: implicit declaration of function `scrollok'
scripts/kconfig/lxdialog/checklist.c:223: warning: implicit declaration of function `wscrl'
scripts/kconfig/lxdialog/checklist.c:283: warning: implicit declaration of function `delwin'
scripts/kconfig/lxdialog/checklist.c:287: error: `KEY_LEFT' undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:288: error: `KEY_RIGHT' undeclared (first use in this function)
scripts/kconfig/lxdialog/dialog.h:131: warning: array `attributes' assumed to have one element
make[2]: *** [scripts/kconfig/lxdialog/checklist.o] Bd 1
make[1]: *** [menuconfig] Bd 2
make: *** [menuconfig] Bd 2
[ Dodano: 2007-03-07, 19:18 ]
Doszedlem prawdy gdyby komus sie podobny problem przytrafil to :
apt-get install libncurses5-dev
[ Komentarz dodany przez: Debian: 2007-03-08, 02:10 ]
Wyszukiwarka to dobre narzędzie
