lspci-v
00:00.0 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a1)
Subsystem: Giga-byte Technology Unknown device 5001
Flags: bus master, 66MHz, fast devsel, latency 0
Capabilities: [44] HyperTransport: Slave or Primary Interface
Capabilities: [dc] HyperTransport: MSI Mapping
00:01.0 ISA bridge: nVidia Corporation MCP61 LPC Bridge (rev a2)
Subsystem: Giga-byte Technology Unknown device 0c11
00:01.1 SMBus: nVidia Corporation MCP61 SMBus (rev a2)
Flags: 66MHz, fast devsel, IRQ 10
I/O ports at c800 [size=200]
I/O ports at 1c00 [size=200]
I/O ports at c400 [size=200]
Capabilities: [44] Power Management version 2
00:01.2 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3) (prog-if 10 [OHCI])
Subsystem: Giga-byte Technology Unknown device 5004
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 17
Memory at f7006000 (32-bit, non-prefetchable) [size=4K]
00:02.1 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 16
Memory at f7007000 (32-bit, non-prefetchable) [size=200]
Capabilities: [44] Debug port
Capabilities: [80] Power Management version 2
00:04.0 PCI bridge: nVidia Corporation MCP61 PCI bridge (rev a1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: f5000000-f6ffffff
Prefetchable memory behind bridge: 88000000-880fffff
Capabilities: [b8] Subsystem: nVidia Corporation Unknown device cb84
Capabilities: [8c] HyperTransport: MSI Mapping
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
Subsystem: Giga-byte Technology Unknown device a002
Memory at f7000000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [50] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/0 Enable-
Capabilities: [6c] HyperTransport: MSI Mapping
00:06.0 IDE interface: nVidia Corporation MCP61 IDE (rev a2) (prog-if 8a [Master SecP PriP])
Subsystem: Giga-byte Technology Unknown device 5002
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=200]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=75]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=200]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=75]
I/O ports at f000 [size=200]
00:07.0 Bridge: nVidia Corporation MCP61 Ethernet (rev a2)
Subsystem: Giga-byte Technology Unknown device e000
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 18
Memory at f7004000 (32-bit, non-prefetchable) [size=4K]
I/O ports at cc00 [size=200]
Capabilities: [50] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/3 Enable-
00:08.0 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2) (prog-if 85 [Master SecO PriO])
Subsystem: Giga-byte Technology Unknown device b002
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 19
I/O ports at 09f0 [size=200]
I/O ports at 0bf0 [size=134]
I/O ports at 0970 [size=200]
I/O ports at 0b70 [size=134]
I/O ports at e000 [size=200]
Memory at f7005000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [b0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/2 Enable-
Capabilities: [cc] HyperTransport: MSI Mapping
00:09.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: f2000000-f4ffffff
Prefetchable memory behind bridge: 00000000e0000000-00000000efffffff
Capabilities: [40] Subsystem: nVidia Corporation Unknown device 0000
Capabilities: [48] Power Management version 2
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit+ Queue=0/1 Enable+
Capabilities: [60] HyperTransport: MSI Mapping
Capabilities: [80] Express Root Port (Slot+) IRQ 0
Capabilities: [100] Virtual Channel
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Capabilities: [f0] #0f [0010]
01:06.0 Network controller: RaLink RT2500 802.11g Cardbus/mini-PCI (rev 01)
Subsystem: CNet Technology Inc CWP-854 Wireless-G PCI Adapter
Flags: bus master, slow devsel, latency 32, IRQ 21
Memory at f6000000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [40] Power Management version 2
01:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RT8139
Flags: bus master, medium devsel, latency 64, IRQ 20
I/O ports at b000 [size=200]
Memory at f6002000 (32-bit, non-prefetchable) [size=200]
[virtual] Expansion ROM at 88000000 [disabled] [size=64K]
Capabilities: [50] Power Management version 2
02:00.0 VGA compatible controller: nVidia Corporation G72 [GeForce 7300 LE] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f2000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f3000000 (64-bit, non-prefetchable) [size=16M]
[virtual] Expansion ROM at f4000000 [disabled] [size=128K]
Capabilities: [60] Power Management version 2
Capabilities: [68] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [78] Express Endpoint IRQ 0
Capabilities: [128] Power Budgeting
Muszę przkompilować właśnie to jądro tylko... jak przekompiluję na to obsługujące więcej ramu, to procesor zostanie wykryty?(teraz działa 1 rdzeń, mam wersje i386)...
To proszę o jakieś podpowiedzi, czy coś takiego, chce aby to i to ruszyło bez problemów...
Z góry dzięki
[ Dodano: 2007-12-28, 09:56 ]
właśnie chce mieć system 32-bit obsłogujący 2 rdzenie mojego Athlona 4200+ x2
[ Dodano: 2007-12-28, 10:00 ]
szukam i686 do pobrania, ale nie widzę go tutaj:
http://cdimage.debian.org/cdimage/weekly-builds/
[ Dodano: 2007-12-28, 10:03 ]
hmm, a to ?
http://packages.debian.org/lenny/linux- ... 686-bigmem to jest jąderko, jak je odpale to pójdzie?
[ Dodano: 2007-12-28, 10:35 ]
ok, zainstalowałem to i poszło, dzięki
tylko jest teraz 1 problem... nie mam zainstalowanego sterownika karty wifi w jajku i podczas kompilacji wyskakuje mi takie coś:
polecenie: module-assistant install rt2500-source
Bad luck, the kernel headers for the target kernel version could ▒
│ not be found ▒
│ and you did not specify other valid kernel headers to use.
[ Dodano: 2007-12-28, 10:54 ]
ok, już działa, musiałem wywalić pliki starej konfiguracji jądra beż bigmema i teraz kompliacja odpaliła DZIÊKI
