aero2 + modem wewn
kodama
[+] aero2 + modem wewnętrzny
Post autor: kodama »
Witajcie
Mam sobie aero2, próbuję się połączyć poprzez wvdial, ale cosik nie wychodzi:
kodama@jupiter:~$ sudo wvdial aero2
--> WvDial: Internet dialer version 1.61
--> Initializing modem.
--> Sending: AT+CGDCONT=1,"IP","darmowy","",0,0
OK
--> Modem initialized.
--> Sending: ATDT*99#
--> Waiting for carrier.
CONNECT
~[7f]}#@!}!}!} }9}#}%B#}%}(}"}'}"}"}&} } } } }%}&^2%1N}-~
--> Carrier detected.  Waiting for prompt.
~[7f]}#@!}!}"} }9}#}%B#}%}(}"}'}"}"}&} } } } }%}&^2%1}"`~
--> PPP negotiation detected.
--> Starting pppd at Mon Jul 20 21:43:17 2015
--> Pid of pppd: 3328
--> Using interface ppp0
--> pppd: x[02]�[08]
--> Disconnecting at Mon Jul 20 21:43:20 2015
--> The PPP daemon has died: A modem hung up the phone (exit code = 16)
--> man pppd explains pppd error codes in more detail.
--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.
--> Auto Reconnect will be attempted in 5 seconds
OK
wvdial.conf
[Dialer aero2]
Modem = /dev/ttyACM1
Phone = *99#
 Username =;
 Password =;
 Init1 = AT+CGDCONT=1,"IP","darmowy","",0,0
 Auto DNS = on
Testowałem kilka różnych konfiguracji wvdiala, za każdym razem jest exit code 16, i za nic nie wiem o co chodzi.
Przez network managera śmiga wyśmienicie, a wvdial nie gada.
Linux jupiter 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt11-1 (2015-05-24) i686 GNU/Linux
DODANE:
Tutaj jeszcze log z /var/log/messages
Jul 21 09:55:40 jupiter pppd[2223]: pppd 2.4.6 started by kodama, uid 0
Jul 21 09:55:40 jupiter pppd[2223]: Using interface ppp0
Jul 21 09:55:40 jupiter pppd[2223]: Connect: ppp0 <--> /dev/ttyACM1
Jul 21 09:55:40 jupiter pppd[2223]: CHAP authentication succeeded: Congratulations!
Jul 21 09:55:40 jupiter pppd[2223]: LCP terminated by peer
Jul 21 09:55:43 jupiter pppd[2223]: Connection terminated.
Jul 21 09:55:43 jupiter pppd[2223]: Modem hangup
Jul 21 09:55:43 jupiter pppd[2223]: Exit.
Pewnie chodzi o to LCP terminated by peer. Tylko jak to użreć?
DODANE
Ok, to z tym już sobie poradziłem. Wygląda na to, że wystarczyło dodać siebie do grupy dialout[/b]. Mam za to jeszcze jeden problem, ale może o nim w innym wątku napiszę.
