[+]Zbyt czuły panel dotykowy
hsurim
Post autor: hsurim »
Nettop NTT Corrino w100l
hsurim@corrino100l:~$ lspci00:00.0 Host bridge: Intel Corporation Mobile 945GSE Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GSE Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 02)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 02)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 02)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 02)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 02)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7-M Family) SATA Controller [IDE mode] (rev 02)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 02)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
02:00.0 Ethernet controller: Atheros Communications Inc. AR242x / AR542x Wireless Network Adapter (PCI-Express) (rev 01)
Po zainstalowaniu jakiejkolwiek dystrybucji, korzystanie z panela dotykowego, najczęściej nie jest możliwe.
Jego dotykanie, powoduje niekontrolowane przeskakiwanie kursora w przeróżne strony i zaczynają się tworzyć na pulpicie katalogi, otwierać rożne aplikacje a czasami powoduje częściowe zawieszenie systemu i wówczas dalsze korzystanie z komputerka nie jest możliwe, aż do jego restartu.
Czasami zdarza się, że po podłączeniu myszy (na usb) zaczyna pracować normalnie.
Czasami też i bez podłączenia myszki, pracuje poprawnie, ale to 'rzadka rzadkość'.
Sam panel raczej jest sprawny, gdyż na dołączonym WinXP, do jego działania, nie można się przyczepić.
Niekiedy zdarza się, że na Linuksie w wersjach live, cały czas działa dobrze.
Do systemu, doinstalowałem paczki firmware do realteka, oraz atherosa - tyle, że to są karty sieciowe.
Czy jest szansa, na jakąś ingerencję, która to może przynieść oczekiwana poprawę ?
ryba84
Post autor: ryba84 »
A pokaż jeszcze lsusb i najlepiej lsmod po uruchomieniu X. Powinno dać się ustawić jego czułość.
hsurim
Wyniki obydwu komend, bez podłączonej zewnętrznej myszy.
hsurim@corrino100l:~$ [B]lsusb[/B]
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 0ac8:3343 Z-Star Microelectronics Corp. Sirius USB 2.0 Camera
hsurim@corrino100l:~$ [B]lsmod[/B]
Module                  Size  Used by
cryptd                 14125  0
aes_i586               16647  2
aes_generic            32970  1 aes_i586
parport_pc             22036  0
ppdev                  12651  0
lp                     12797  0
parport                31254  3 lp,ppdev,parport_pc
bnep                   17288  2
rfcomm                 28626  0
bluetooth             103791  10 rfcomm,bnep
cpufreq_stats          12762  0
cpufreq_powersave      12422  0
cpufreq_userspace      12520  0
cpufreq_conservative    12987  0
loop                   17810  0
uvcvideo               56896  0
videodev               61658  1 uvcvideo
media                  13692  2 videodev,uvcvideo
snd_hda_codec_realtek   142267  1
arc4                   12418  2
hid_a4tech             12468  0
ath5k                 115240  0
snd_hda_intel          21786  1
ath                    17114  1 ath5k
snd_hda_codec          63477  2 snd_hda_intel,snd_hda_codec_realtek
i915                  317419  3
snd_hwdep              12943  1 snd_hda_codec
snd_pcm                53461  2 snd_hda_codec,snd_hda_intel
snd_page_alloc         12867  2 snd_pcm,snd_hda_intel
mac80211              171389  1 ath5k
cfg80211              113445  3 mac80211,ath,ath5k
psmouse                59609  0
evdev                  17225  14
drm_kms_helper         22738  1 i915
i2c_i801               12670  0
snd_seq                39512  0
rfkill                 18516  4 cfg80211,bluetooth
snd_seq_device         13016  1 snd_seq
pcspkr                 12515  0
serio_raw              12803  0
iTCO_wdt               16945  0
iTCO_vendor_support    12632  1 iTCO_wdt
drm                   146387  4 drm_kms_helper,i915
coretemp               12770  0
snd_timer              22356  2 snd_seq,snd_pcm
rng_core               12580  0
snd                    42722  10 snd_timer,snd_seq_device,snd_seq,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek
acpi_cpufreq           12807  0
battery                12986  0
mperf                  12421  1 acpi_cpufreq
i2c_algo_bit           12713  1 i915
i2c_core               19116  6 i2c_algo_bit,drm,i2c_i801,drm_kms_helper,i915,videodev
processor              27565  1 acpi_cpufreq
soundcore              12921  1 snd
ac                     12552  0
video                  17459  1 i915
power_supply           13283  2 ac,battery
button                 12817  1 i915
ext4                  306996  2
crc16                  12327  2 ext4,bluetooth
jbd2                   52330  1 ext4
mbcache                12938  1 ext4
usbhid                 31554  0
hid                    64284  2 usbhid,hid_a4tech
sg                     21476  0
sd_mod                 35425  4
crc_t10dif             12332  1 sd_mod
ata_generic            12439  0
ata_piix               25271  3
libata                125014  2 ata_piix,ata_generic
scsi_mod              135037  3 libata,sd_mod,sg
uhci_hcd               22337  0
thermal                13103  0
ehci_hcd               39631  0
thermal_sys            17752  3 thermal,video,processor
usbcore               104555  5 ehci_hcd,uhci_hcd,usbhid,uvcvideo
usb_common             12338  1 usbcore
r8169                  41830  0
mii                    12595  1 r8169
hsurim
Tym razem - nie wiedziec czemu - panel dotykowy działa bez zarzutu (bez podłączonej myszy)
root@corrino100l:/home/hsurim# lsmod
Module                  Size  Used by
cryptd                 14125  0
aes_i586               16647  1
parport_pc             22036  0
ppdev                  12651  0
lp                     12797  0
bnep                   17288  2
rfcomm                 28626  0
loop                   17810  0
uvcvideo               56896  0
arc4                   12418  2
ath5k                 115240  0
ath                    17114  1 ath5k
i915                  317419  3
snd_seq                39512  0
psmouse                59609  0
pcspkr                 12515  0
evdev                  17225  14
serio_raw              12803  0
i2c_i801               12670  0
coretemp               12770  0
iTCO_wdt               16945  0
rng_core               12580  0
video                  17459  1 i915
ac                     12552  0
battery                12986  0
button                 12817  1 i915
i2c_core               19116  6 i2c_i801,i2c_algo_bit,drm,drm_kms_helper,i915,videodev
power_supply           13283  2 battery,ac
ext4                  306996  2
jbd2                   52330  1 ext4
sg                     21476  0
sd_mod                 35425  4
ata_generic            12439  0
ata_piix               25271  3
thermal                13103  0
uhci_hcd               22337  0
ehci_hcd               39631  0
usbcore               104555  4 ehci_hcd,uhci_hcd,uvcvideo
r8169                  41830  0
mii                    12595  1 r8169
ryba84
To jeszcze mógłbyś podrzucić /var/log/Xorg.0.log. Tam będzie info co to za touchpad. Możesz spojrzeć na to: http://superuser.com/questions/229839/r ... -in-ubuntu
hsurim
Re: Zbyt czuły panel dotykowy
Dla potomnych :
W opisywanym sprzęcie, skończyła się bateryjka podtrzymująca BIOS.
Po jej wymianie, nieoczekiwanie, wyżej opisywany problem ustąpił.
