W logach mam taki dziwny wpis:
dmesg
[602900.730889] NETDEV WATCHDOG: eth1 (e1000e): transmit queue 0 timed out
[602900.730891] Modules linked in: ipt_MASQUERADE ipt_REDIRECT xt_iprange xt_state xt_multiport xt_mac ipt_LOG xt_limit xt_tcpudp iptable_mangle iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables nf_conntrack_ftp ipt_ULOG nf_conntrack x_tables loop usbhid snd_pcm snd_timer snd hid button soundcore snd_page_alloc i2c_i801 processor pcspkr evdev container i2c_core ext3 jbd mbcache sg sr_mod cdrom hpsa cciss ahci tg3 libata libphy scsi_mod e1000e ehci_hcd thermal usbcore nls_base thermal_sys [last unloaded: scsi_wait_scan]
[602900.730920] Pid: 0, comm: swapper Not tainted 2.6.32-5-amd64 #1
[602900.730922] Call Trace:
[602900.730923] <IRQ> [<ffffffff812632da>] ? dev_watchdog+0xe2/0x194
[602900.730928] [<ffffffff812632da>] ? dev_watchdog+0xe2/0x194
[602900.730932] [<ffffffff8104df38>] ? warn_slowpath_common+0x77/0xa3
[602900.730934] [<ffffffff812631f8>] ? dev_watchdog+0x0/0x194
[602900.730937] [<ffffffff8104dfc0>] ? warn_slowpath_fmt+0x51/0x59
[602900.730941] [<ffffffff8104a44f>] ? try_to_wake_up+0x289/0x29b
[602900.730943] [<ffffffff812631cc>] ? netif_tx_lock+0x3d/0x69
[602900.730948] [<ffffffff8124dff8>] ? netdev_drivername+0x3b/0x40
[602900.730950] [<ffffffff812632da>] ? dev_watchdog+0xe2/0x194
[602900.730952] [<ffffffff8103f9ca>] ? __wake_up+0x30/0x44
[602900.730957] [<ffffffff8105a6c7>] ? run_timer_softirq+0x1c9/0x268
[602900.730960] [<ffffffff81053d73>] ? __do_softirq+0xdd/0x1a6
[602900.730964] [<ffffffff81011cac>] ? call_softirq+0x1c/0x30
[602900.730966] [<ffffffff8101322b>] ? do_softirq+0x3f/0x7c
[602900.730969] [<ffffffff81053be3>] ? irq_exit+0x36/0x76
[602900.730971] [<ffffffff81012922>] ? do_IRQ+0xa0/0xb6
[602900.730973] [<ffffffff810114d3>] ? ret_from_intr+0x0/0x11
[602900.730974] <EOI> [<ffffffff8102b03e>] ? hpet_msi_next_event+0x0/0x4b
[602900.730980] [<ffffffff810176a4>] ? mwait_idle+0x72/0x7d
[602900.730983] [<ffffffff81017654>] ? mwait_idle+0x22/0x7d
[602900.730986] [<ffffffff8100fe97>] ? cpu_idle+0xa2/0xda
[602900.730989] [<ffffffff8151c140>] ? early_idt_handler+0x0/0x71
[602900.730992] [<ffffffff8151ccdd>] ? start_kernel+0x3dc/0x3e8
[602900.730994] [<ffffffff8151c3b7>] ? x86_64_start_kernel+0xf9/0x106
[602900.730996] ---[ end trace f209b4f07c516f54 ]---
[602900.731004] e1000e 0000:10:00.0: eth1: Reset adapter
[602901.003008] e1000e 0000:10:00.0: eth1: Reset adapter
[602902.572548] e1000e: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[602902.572553] e1000e 0000:10:00.0: eth1: 10/100 speed: disabling TSO
[603372.962778] e1000e: eth1 NIC Link is Down
[603376.844584] e1000e: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[603376.844589] e1000e 0000:10:00.0: eth1: 10/100 speed: disabling TSO
[603391.824304] e1000e 0000:10:00.0: eth1: Reset adapter
[603392.105129] e1000e 0000:10:00.0: eth1: Reset adapter
[603393.649971] e1000e: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[603393.649976] e1000e 0000:10:00.0: eth1: 10/100 speed: disabling TSO
[603428.530163] tg3 0000:1e:00.0: eth0: Link is down
[603434.610832] tg3 0000:1e:00.0: eth0: Link is up at 100 Mbps, full duplex
[603434.610835] tg3 0000:1e:00.0: eth0: Flow control is on for TX and on for RX
[603437.593046] e1000e: eth1 NIC Link is Down
[603438.768428] tg3 0000:1e:00.0: eth0: Link is down
[603441.615032] tg3 0000:1e:00.0: eth0: Link is up at 100 Mbps, full duplex
[603441.615035] tg3 0000:1e:00.0: eth0: Flow control is on for TX and on for RX
[603441.810240] e1000e: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[603441.810245] e1000e 0000:10:00.0: eth1: 10/100 speed: disabling TSO
[603575.886128] e1000e: eth1 NIC Link is Down
[603581.683446] e1000e: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[603581.683451] e1000e 0000:10:00.0: eth1: 10/100 speed: disabling TSO
Może wiecie co się dzieje i czy to coś poważnego. eth1 to interfejs LAN.
lspci
10:00.0 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (rev 06)
10:00.1 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (rev 06)
Więcej informacji o karcie:
Subsystem: Intel Corporation PRO/1000 PT Dual Port Server Adapter
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 34
Region 0: Memory at de920000 (32-bit, non-prefetchable) [size=128K]
Region 1: Memory at de900000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at 2000 [size=200]
[virtual] Expansion ROM at c0000000 [disabled] [size=128K]
Capabilities: [c8] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee0f00c Data: 415a
Capabilities: [e0] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE- FLReset-
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr+ FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x4, ASPM L0s, Latency L0 <4us, L1 <64us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr-
AERCap: First Error Pointer: 14, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 00-1b-21-ff-ff-d4-12-0a
Kernel driver in use: e1000e
