Tak, zależny mi na poprawnie skonfigurowanym systemie. System uruchamia się bezproblemowo aż do samego logowania, z konsolą też nie mam żadnych problemów. Podałeś mi odnośnik:
dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-486 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 Debian 3.2.51-1
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009e800 (usable)
[ 0.000000] BIOS-e820: 000000000009e800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000c0000 - 00000000000cc000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d8000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001fcf0000 (usable)
[ 0.000000] BIOS-e820: 000000001fcf0000 - 000000001fcff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001fcff000 - 000000001fd00000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001fd00000 - 000000001fe80000 (usable)
[ 0.000000] BIOS-e820: 000000001fe80000 - 0000000020000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff800000 - 00000000ffc00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Sony Corporation PCG-FX101(GB) , BIOS WXP04U0 08/15/02
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x1fe80 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 01FE80000 mask FFFF80000 uncachable
[ 0.000000] 2 base 01FF00000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 12288
[ 0.000000] init_memory_mapping: 0000000000000000-000000001fe80000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001fe80000 page 4k
[ 0.000000] kernel direct mapping tables up to 1fe80000 @ 17f8000-1800000
[ 0.000000] RAMDISK: 1f38e000 - 1fcf0000
[ 0.000000] ACPI: RSDP 000f6c70 00014 (v00 SONY )
[ 0.000000] ACPI: RSDT 1fcfa617 0002C (v01 SONY U0 20020815 PTL 00000000)
[ 0.000000] ACPI: FACP 1fcfef64 00074 (v01 SONY U0 20020815 PTL 01000000)
[ 0.000000] ACPI: DSDT 1fcfa643 04921 (v01 SONY U0 20020815 PTL 0100000E)
[ 0.000000] ACPI: FACS 1fcfffc0 00040
[ 0.000000] ACPI: BOOT 1fcfefd8 00028 (v01 SONY U0 20020815 PTL 00000001)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 510MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1fe80000
[ 0.000000] low ram: 0 - 1fe80000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001fe80
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x0001fcf0
[ 0.000000] 0: 0x0001fd00 -> 0x0001fe80
[ 0.000000] On node 0 totalpages: 130558
[ 0.000000] free_area_init_node: node 0, pgdat c13c5a78, node_mem_map def8e200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 989 pages used for memmap
[ 0.000000] Normal zone: 125587 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] APIC: switched to apic NOOP
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000c0000
[ 0.000000] PM: Registered nosave memory: 00000000000c0000 - 00000000000cc000
[ 0.000000] PM: Registered nosave memory: 00000000000cc000 - 00000000000d8000
[ 0.000000] PM: Registered nosave memory: 00000000000d8000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 000000001fcf0000 - 000000001fcff000
[ 0.000000] PM: Registered nosave memory: 000000001fcff000 - 000000001fd00000
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:df800000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129537
[ 0.000000] Kernel command line: auto BOOT_IMAGE=Linux ro root=UUID=5c9cb65c-c2ec-4be0-a73d-06d9f28cfb98
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 503200k/522752k available (2596k kernel code, 19032k reserved, 1292k data, 452k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfffa1000 - 0xfffff000 ( 376 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe0680000 - 0xff7fe000 ( 497 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfe80000 ( 510 MB)
[ 0.000000] .init : 0xc13cd000 - 0xc143e000 ( 452 kB)
[ 0.000000] .data : 0xc128936c - 0xc13cc6c0 (1292 kB)
[ 0.000000] .text : 0xc1000000 - 0xc128936c (2596 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=de806000 soft=de808000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 596.193 MHz processor.
[ 0.004007] Calibrating delay loop (skipped), value calculated using timer frequency.. 1192.38 BogoMIPS (lpj=2384772)
[ 0.004149] pid_max: default: 32768 minimum: 301
[ 0.004387] Security Framework initialized
[ 0.004480] AppArmor: AppArmor disabled by boot time parameter
[ 0.004602] Mount-cache hash table entries: 512
[ 0.005077] Initializing cgroup subsys cpuacct
[ 0.005176] Initializing cgroup subsys memory
[ 0.005261] Initializing cgroup subsys devices
[ 0.005329] Initializing cgroup subsys freezer
[ 0.005396] Initializing cgroup subsys net_cls
[ 0.005462] Initializing cgroup subsys blkio
[ 0.005546] Initializing cgroup subsys perf_event
[ 0.005756] CPU: Intel Celeron (Coppermine) stepping 06
[ 0.008434] ACPI: Core revision 20110623
[ 0.020306] Performance Events:
[ 0.020375] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.020498] no hardware sampling interrupt available.
[ 0.020569] p6 PMU driver.
[ 0.020637] ... version: 0
[ 0.020701] ... bit width: 32
[ 0.020764] ... generic registers: 2
[ 0.020828] ... value mask: 00000000ffffffff
[ 0.020894] ... max period: 000000007fffffff
[ 0.020960] ... fixed-purpose events: 0
[ 0.021023] ... event mask: 0000000000000003
[ 0.024083] NMI watchdog disabled (cpu0): not supported (no LAPIC?)
[ 0.024959] devtmpfs: initialized
[ 0.025593] PM: Registering ACPI NVS region at 1fcff000 (4096 bytes)
[ 0.026457] print_constraints: dummy:
[ 0.026754] NET: Registered protocol family 16
[ 0.027236] EISA bus registered
[ 0.027463] ACPI: bus type pci registered
[ 0.029199] PCI: PCI BIOS revision 2.10 entry at 0xfd9b0, last bus=1
[ 0.029278] PCI: Using configuration type 1 for base access
[ 0.032812] bio: create slab <bio-0> at 0
[ 0.033349] ACPI: Added _OSI(Module Device)
[ 0.033432] ACPI: Added _OSI(Processor Device)
[ 0.033502] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.033575] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.035892] ACPI: EC: Look up EC in DSDT
[ 0.046430] ACPI: Interpreter enabled
[ 0.046546] ACPI: (supports S0 S3 S4 S5)
[ 0.046809] ACPI: Using PIC for interrupt routing
[ 0.093304] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 0.093965] ACPI: No dock devices found.
[ 0.094039] HEST: Table not found.
[ 0.094112] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.098059] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.105588] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.105606] pci_root PNP0A03:00: host bridge window [mem 0x000cc000-0x000cffff] (ignored)
[ 0.105620] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000d3fff] (ignored)
[ 0.105634] pci_root PNP0A03:00: host bridge window [mem 0x000d4000-0x000d7fff] (ignored)
[ 0.105649] pci_root PNP0A03:00: host bridge window [mem 0x20000000-0xfebfffff] (ignored)
[ 0.105663] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.105676] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.105728] pci 0000:00:00.0: [8086:1130] type 0 class 0x000600
[ 0.105849] pci 0000:00:02.0: [8086:1132] type 0 class 0x000300
[ 0.105880] pci 0000:00:02.0: reg 10: [mem 0xf8000000-0xfbffffff pref]
[ 0.105901] pci 0000:00:02.0: reg 14: [mem 0xf4000000-0xf407ffff]
[ 0.106051] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
[ 0.106137] pci 0000:00:1f.0: [8086:244c] type 0 class 0x000601
[ 0.106243] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH4 ACPI/GPIO/TCO
[ 0.106351] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH4 GPIO
[ 0.106463] pci 0000:00:1f.1: [8086:244a] type 0 class 0x000101
[ 0.106534] pci 0000:00:1f.1: reg 20: [io 0x1800-0x180f]
[ 0.106607] pci 0000:00:1f.2: [8086:2442] type 0 class 0x000c03
[ 0.106679] pci 0000:00:1f.2: reg 20: [io 0x1820-0x183f]
[ 0.106752] pci 0000:00:1f.3: [8086:2443] type 0 class 0x000c05
[ 0.106824] pci 0000:00:1f.3: reg 20: [io 0x1810-0x181f]
[ 0.106897] pci 0000:00:1f.4: [8086:2444] type 0 class 0x000c03
[ 0.106969] pci 0000:00:1f.4: reg 20: [io 0x2400-0x241f]
[ 0.107044] pci 0000:00:1f.5: [8086:2445] type 0 class 0x000401
[ 0.107074] pci 0000:00:1f.5: reg 10: [io 0x1c00-0x1cff]
[ 0.107097] pci 0000:00:1f.5: reg 14: [io 0x1840-0x187f]
[ 0.107199] pci 0000:00:1f.6: [8086:2446] type 0 class 0x000703
[ 0.107228] pci 0000:00:1f.6: reg 10: [io 0x2000-0x20ff]
[ 0.107251] pci 0000:00:1f.6: reg 14: [io 0x1880-0x18ff]
[ 0.107393] pci 0000:01:00.0: [104c:8021] type 0 class 0x000c00
[ 0.107429] pci 0000:01:00.0: reg 10: [mem 0xf4104000-0xf41047ff]
[ 0.107453] pci 0000:01:00.0: reg 14: [mem 0xf4100000-0xf4103fff]
[ 0.107556] pci 0000:01:00.0: supports D2
[ 0.107568] pci 0000:01:00.0: PME# supported from D2 D3hot
[ 0.107620] pci 0000:01:02.0: [1180:0476] type 2 class 0x000607
[ 0.107650] pci 0000:01:02.0: proprietary Ricoh MMC controller disabled (via cardbus function)
[ 0.107751] pci 0000:01:02.0: MMC cards are now supported by standard SDHCI controller
[ 0.107860] pci 0000:01:02.0: reg 10: [mem 0x00000000-0x00000fff]
[ 0.107908] pci 0000:01:02.0: supports D1 D2
[ 0.107919] pci 0000:01:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.107970] pci 0000:01:02.1: [1180:0476] type 2 class 0x000607
[ 0.108051] pci 0000:01:02.1: reg 10: [mem 0x00000000-0x00000fff]
[ 0.108102] pci 0000:01:02.1: supports D1 D2
[ 0.108114] pci 0000:01:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.108195] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.108281] pci 0000:00:1e.0: bridge window [mem 0xf4100000-0xf41fffff]
[ 0.108301] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.108315] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.108332] pci 0000:01:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.108434] pci 0000:01:02.1: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.108581] pci_bus 0000:02: [bus 02-05] partially hidden behind transparent bridge 0000:01 [bus 01-01]
[ 0.108726] pci_bus 0000:06: [bus 06-09] partially hidden behind transparent bridge 0000:01 [bus 01-01]
[ 0.108837] pci_bus 0000:00: on NUMA node 0
[ 0.108864] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.109147] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB_._PRT]
[ 0.109589] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e)
[ 0.118141] ACPI: PCI Interrupt Link [LNKA] (IRQs *9)
[ 0.118765] ACPI: PCI Interrupt Link [LNKB] (IRQs *9)
[ 0.119365] ACPI: PCI Interrupt Link [LNKC] (IRQs 9) *0
[ 0.120049] ACPI: PCI Interrupt Link [LNKD] (IRQs 9) *0
[ 0.120704] ACPI: PCI Interrupt Link [LNKE] (IRQs *9)
[ 0.121303] ACPI: PCI Interrupt Link [LNKH] (IRQs *9)
[ 0.121921] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.122044] vgaarb: loaded
[ 0.122105] vgaarb: bridge control possible 0000:00:02.0
[ 0.122380] PCI: Using ACPI for IRQ routing
[ 0.122453] PCI: pci_cache_line_size set to 32 bytes
[ 0.122578] reserve RAM buffer: 000000000009e800 - 000000000009ffff
[ 0.122591] reserve RAM buffer: 000000001fcf0000 - 000000001fffffff
[ 0.122602] reserve RAM buffer: 000000001fe80000 - 000000001fffffff
[ 0.123126] Switching to clocksource pit
[ 0.126957] pnp: PnP ACPI init
[ 0.127130] ACPI: bus type pnp registered
[ 0.131130] pnp 00:00: [bus 00-ff]
[ 0.131147] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.131160] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.131173] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.131186] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.131198] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.131211] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.131224] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.131249] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.131263] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.131275] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.131288] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.131300] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.131313] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.131326] pnp 00:00: [mem 0x20000000-0xfebfffff window]
[ 0.131339] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.131351] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.131363] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.131623] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.132288] pnp 00:01: [mem 0x1ff00000-0x1fffffff]
[ 0.132513] system 00:01: [mem 0x1ff00000-0x1fffffff] has been reserved
[ 0.132603] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.133363] pnp 00:02: [io 0x0010-0x001f]
[ 0.133376] pnp 00:02: [io 0x0024-0x0025]
[ 0.133387] pnp 00:02: [io 0x0028-0x0029]
[ 0.133399] pnp 00:02: [io 0x002c-0x002d]
[ 0.133410] pnp 00:02: [io 0x0030-0x0031]
[ 0.133421] pnp 00:02: [io 0x0034-0x0035]
[ 0.133432] pnp 00:02: [io 0x0038-0x0039]
[ 0.133443] pnp 00:02: [io 0x003c-0x003d]
[ 0.133454] pnp 00:02: [io 0x0050-0x0053]
[ 0.133465] pnp 00:02: [io 0x0072-0x0077]
[ 0.133476] pnp 00:02: [io 0x0080]
[ 0.133486] pnp 00:02: [io 0x0090-0x009f]
[ 0.133498] pnp 00:02: [io 0x00a4-0x00a5]
[ 0.133509] pnp 00:02: [io 0x00a8-0x00a9]
[ 0.133520] pnp 00:02: [io 0x00ac-0x00ad]
[ 0.133531] pnp 00:02: [io 0x00b0-0x00b5]
[ 0.133542] pnp 00:02: [io 0x00b8-0x00b9]
[ 0.133553] pnp 00:02: [io 0x00bc-0x00bd]
[ 0.133564] pnp 00:02: [io 0x1000-0x107f]
[ 0.133575] pnp 00:02: [io 0x1180-0x11bf]
[ 0.133587] pnp 00:02: [io 0x002e-0x002f]
[ 0.133598] pnp 00:02: [io 0x004e-0x004f]
[ 0.133609] pnp 00:02: [io 0x0600-0x060f]
[ 0.133620] pnp 00:02: [io 0x04d0-0x04d1]
[ 0.133631] pnp 00:02: [io 0xfe00-0xfe01]
[ 0.133643] pnp 00:02: [mem 0xff800000-0xffffffff]
[ 0.133954] system 00:02: [io 0x1000-0x107f] has been reserved
[ 0.134039] system 00:02: [io 0x1180-0x11bf] has been reserved
[ 0.134114] system 00:02: [io 0x0600-0x060f] has been reserved
[ 0.134189] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.134263] system 00:02: [io 0xfe00-0xfe01] has been reserved
[ 0.134340] system 00:02: [mem 0xff800000-0xffffffff] could not be reserved
[ 0.134421] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.134538] pnp 00:03: [io 0x0000-0x000f]
[ 0.134551] pnp 00:03: [io 0x0081-0x008f]
[ 0.134563] pnp 00:03: [io 0x00c0-0x00df]
[ 0.134575] pnp 00:03: [dma 4]
[ 0.134727] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.134823] pnp 00:04: [io 0x00f0-0x00ff]
[ 0.134839] pnp 00:04: [irq 13]
[ 0.134987] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.135116] pnp 00:05: [io 0x0070-0x0071]
[ 0.135131] pnp 00:05: [irq 8]
[ 0.135276] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.135368] pnp 00:06: [io 0x0061]
[ 0.135521] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.135651] pnp 00:07: [io 0x0060]
[ 0.135664] pnp 00:07: [io 0x0064]
[ 0.135676] pnp 00:07: [irq 1]
[ 0.135827] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.135893] pnp 00:08: [irq 12]
[ 0.136041] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.139303] pnp 00:09: Plug and Play ACPI device, IDs SNY6001 (disabled)
[ 0.150661] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.150692] pnp 00:0a: [irq 4]
[ 0.154232] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.168904] pnp 00:0b: [io 0x0378-0x037f]
[ 0.168922] pnp 00:0b: [io 0x0778-0x077f]
[ 0.168936] pnp 00:0b: [irq 7]
[ 0.168948] pnp 00:0b: [dma 3]
[ 0.176635] pnp 00:0b: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.182208] pnp 00:0c: [io 0x03f0-0x03f5]
[ 0.182223] pnp 00:0c: [io 0x03f7]
[ 0.182239] pnp 00:0c: [irq 6]
[ 0.182250] pnp 00:0c: [dma 2]
[ 0.185398] pnp 00:0c: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.186005] pnp: PnP ACPI: found 13 devices
[ 0.186088] ACPI: ACPI bus type pnp unregistered
[ 0.186161] PnPBIOS: Disabled by ACPI PNP
[ 0.231932] Switching to clocksource acpi_pm
[ 0.232083] PCI: max bus depth: 2 pci_try_num: 3
[ 0.232187] pci 0000:00:1e.0: BAR 15: assigned [mem 0x20000000-0x27ffffff pref]
[ 0.234893] pci 0000:00:1e.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.234985] pci 0000:01:02.0: BAR 0: assigned [mem 0x28000000-0x28000fff]
[ 0.235075] pci 0000:01:02.1: BAR 0: assigned [mem 0x2c000000-0x2c000fff]
[ 0.235158] pci 0000:01:02.1: BAR 16: assigned [mem 0x30000000-0x33ffffff]
[ 0.235237] pci 0000:01:02.1: BAR 15: assigned [mem 0x20000000-0x23ffffff pref]
[ 0.235332] pci 0000:01:02.1: BAR 14: assigned [io 0x3000-0x30ff]
[ 0.235407] pci 0000:01:02.1: BAR 13: assigned [io 0x3400-0x34ff]
[ 0.235486] pci 0000:01:02.0: BAR 16: assigned [mem 0x34000000-0x37ffffff]
[ 0.235564] pci 0000:01:02.0: BAR 15: assigned [mem 0x24000000-0x27ffffff pref]
[ 0.235659] pci 0000:01:02.0: BAR 14: assigned [io 0x3800-0x38ff]
[ 0.235735] pci 0000:01:02.0: BAR 13: assigned [io 0x3c00-0x3cff]
[ 0.235812] pci 0000:01:02.0: CardBus bridge to [bus 02-05]
[ 0.235885] pci 0000:01:02.0: bridge window [io 0x3c00-0x3cff]
[ 0.235961] pci 0000:01:02.0: bridge window [io 0x3800-0x38ff]
[ 0.236075] pci 0000:01:02.0: bridge window [mem 0x24000000-0x27ffffff pref]
[ 0.236172] pci 0000:01:02.0: bridge window [mem 0x34000000-0x37ffffff]
[ 0.236250] pci 0000:01:02.1: CardBus bridge to [bus 06-09]
[ 0.236321] pci 0000:01:02.1: bridge window [io 0x3400-0x34ff]
[ 0.236397] pci 0000:01:02.1: bridge window [io 0x3000-0x30ff]
[ 0.236473] pci 0000:01:02.1: bridge window [mem 0x20000000-0x23ffffff pref]
[ 0.236568] pci 0000:01:02.1: bridge window [mem 0x30000000-0x33ffffff]
[ 0.236645] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[ 0.236718] pci 0000:00:1e.0: bridge window [io 0x3000-0x3fff]
[ 0.236796] pci 0000:00:1e.0: bridge window [mem 0xf4100000-0xf41fffff]
[ 0.236873] pci 0000:00:1e.0: bridge window [mem 0x20000000-0x27ffffff pref]
[ 0.236994] pci 0000:00:1e.0: setting latency timer to 64
[ 0.237032] pci 0000:01:02.0: power state changed by ACPI to D0
[ 0.237112] pci 0000:01:02.0: power state changed by ACPI to D0
[ 0.237945] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 9
[ 0.238020] PCI: setting IRQ 9 as level-triggered
[ 0.238053] pci 0000:01:02.1: power state changed by ACPI to D0
[ 0.238132] pci 0000:01:02.1: power state changed by ACPI to D0
[ 0.238844] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
[ 0.238929] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.238942] pci_bus 0000:00: resource 1 [mem 0x00000000-0xffffffff]
[ 0.238956] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.238968] pci_bus 0000:01: resource 1 [mem 0xf4100000-0xf41fffff]
[ 0.238982] pci_bus 0000:01: resource 2 [mem 0x20000000-0x27ffffff pref]
[ 0.238994] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.239007] pci_bus 0000:01: resource 5 [mem 0x00000000-0xffffffff]
[ 0.239020] pci_bus 0000:02: resource 0 [io 0x3c00-0x3cff]
[ 0.239032] pci_bus 0000:02: resource 1 [io 0x3800-0x38ff]
[ 0.239045] pci_bus 0000:02: resource 2 [mem 0x24000000-0x27ffffff pref]
[ 0.239058] pci_bus 0000:02: resource 3 [mem 0x34000000-0x37ffffff]
[ 0.239071] pci_bus 0000:06: resource 0 [io 0x3400-0x34ff]
[ 0.239083] pci_bus 0000:06: resource 1 [io 0x3000-0x30ff]
[ 0.239096] pci_bus 0000:06: resource 2 [mem 0x20000000-0x23ffffff pref]
[ 0.239109] pci_bus 0000:06: resource 3 [mem 0x30000000-0x33ffffff]
[ 0.239316] NET: Registered protocol family 2
[ 0.239616] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.240629] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.241109] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.241482] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.241559] TCP reno registered
[ 0.241638] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.241733] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.242243] NET: Registered protocol family 1
[ 0.242394] pci 0000:00:02.0: Boot video device
[ 0.242594] pci 0000:00:1f.2: power state changed by ACPI to D0
[ 0.242678] pci 0000:00:1f.2: power state changed by ACPI to D0
[ 0.242864] pci 0000:00:1f.4: power state changed by ACPI to D0
[ 0.242944] pci 0000:00:1f.4: power state changed by ACPI to D0
[ 0.243719] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 9
[ 0.243857] PCI: CLS 32 bytes, default 32
[ 0.244193] Unpacking initramfs...
[ 1.587140] Freeing initrd memory: 9608k freed
[ 1.640608] Simple Boot Flag at 0x36 set to 0x1
[ 1.642601] audit: initializing netlink socket (disabled)
[ 1.642727] type=2000 audit(1385938172.640:1): initialized
[ 1.700755] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.701516] VFS: Disk quotas dquot_6.5.2
[ 1.701692] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.702037] msgmni has been set to 1001
[ 1.702969] alg: No test for stdrng (krng)
[ 1.703246] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.703344] io scheduler noop registered
[ 1.703409] io scheduler deadline registered
[ 1.703508] io scheduler cfq registered (default)
[ 1.704097] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.704268] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.704341] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.705626] ERST: Table is not found!
[ 1.705698] GHES: HEST is not enabled!
[ 1.705816] isapnp: Scanning for PnP cards...
[ 2.060142] isapnp: No Plug & Play device found
[ 2.060513] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.081081] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.103102] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.104497] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
[ 2.105132] Linux agpgart interface v0.103
[ 2.105530] agpgart-intel 0000:00:00.0: Intel i815 Chipset
[ 2.105666] agpgart-intel 0000:00:00.0: detected gtt size: 65536K total, 65536K mappable
[ 2.106334] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[ 2.107061] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUE] at 0x60,0x64 irq 1,12
[ 2.109601] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.109700] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.110398] mousedev: PS/2 mouse device common for all mice
[ 2.110675] rtc_cmos 00:05: RTC can wake from S4
[ 2.111082] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 2.111198] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 2.111476] EISA: Probing bus 0 at eisa.0
[ 2.111558] Cannot allocate resource for EISA slot 1
[ 2.111628] Cannot allocate resource for EISA slot 2
[ 2.111696] Cannot allocate resource for EISA slot 3
[ 2.111797] EISA: Detected 0 cards.
[ 2.111864] cpuidle: using governor ladder
[ 2.111929] cpuidle: using governor menu
[ 2.113163] TCP cubic registered
[ 2.113445] NET: Registered protocol family 10
[ 2.115998] Mobile IPv6
[ 2.116155] NET: Registered protocol family 17
[ 2.116250] Registering the dns_resolver key type
[ 2.116392] Using IPI Shortcut mode
[ 2.117055] PM: Hibernation image not present or could not be loaded.
[ 2.117114] registered taskstats version 1
[ 2.117938] rtc_cmos 00:05: setting system clock to 2013-12-01 22:49:33 UTC (1385938173)
[ 2.118250] Initializing network drop monitor service
[ 2.118871] Freeing unused kernel memory: 452k freed
[ 2.121433] Write protecting the kernel text: 2600k
[ 2.121596] Write protecting the kernel read-only data: 1032k
[ 2.139064] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 2.200836] udevd[42]: starting version 175
[ 2.506741] thermal LNXTHERM:00: registered as thermal_zone0
[ 2.506825] ACPI: Thermal Zone [ATF0] (44 C)
[ 2.568649] Floppy drive(s): fd0 is 1.44M
[ 2.587992] FDC 0 is a post-1991 82077
[ 2.696333] Refined TSC clocksource calibration: 596.192 MHz.
[ 2.696458] Switching to clocksource tsc
[ 2.750447] firewire_ohci 0000:01:00.0: enabling device (0110 -> 0112)
[ 2.751384] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 9
[ 2.810888] firewire_ohci: Added fw-ohci device 0000:01:00.0, OHCI v1.0, 4 IR + 8 IT contexts, quirks 0x2
[ 2.826066] usbcore: registered new interface driver usbfs
[ 2.826237] usbcore: registered new interface driver hub
[ 2.833391] usbcore: registered new device driver usb
[ 2.836187] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.856730] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.857000] uhci_hcd 0000:00:1f.2: power state changed by ACPI to D0
[ 2.857083] uhci_hcd 0000:00:1f.2: power state changed by ACPI to D0
[ 2.857199] uhci_hcd 0000:00:1f.2: setting latency timer to 64
[ 2.857213] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 2.857357] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[ 2.857506] uhci_hcd 0000:00:1f.2: irq 9, io base 0x00001820
[ 2.857723] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.857803] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.857893] usb usb1: Product: UHCI Host Controller
[ 2.857961] usb usb1: Manufacturer: Linux 3.2.0-4-486 uhci_hcd
[ 2.858031] usb usb1: SerialNumber: 0000:00:1f.2
[ 2.858932] SCSI subsystem initialized
[ 2.866357] hub 1-0:1.0: USB hub found
[ 2.866458] hub 1-0:1.0: 2 ports detected
[ 2.866871] uhci_hcd 0000:00:1f.4: power state changed by ACPI to D0
[ 2.866961] uhci_hcd 0000:00:1f.4: power state changed by ACPI to D0
[ 2.867092] uhci_hcd 0000:00:1f.4: setting latency timer to 64
[ 2.867107] uhci_hcd 0000:00:1f.4: UHCI Host Controller
[ 2.867224] uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 2
[ 2.867384] uhci_hcd 0000:00:1f.4: irq 9, io base 0x00002400
[ 2.867627] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.867707] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.867798] usb usb2: Product: UHCI Host Controller
[ 2.867867] usb usb2: Manufacturer: Linux 3.2.0-4-486 uhci_hcd
[ 2.867938] usb usb2: SerialNumber: 0000:00:1f.4
[ 2.884695] hub 2-0:1.0: USB hub found
[ 2.884800] hub 2-0:1.0: 2 ports detected
[ 2.958179] libata version 3.00 loaded.
[ 2.966282] ata_piix 0000:00:1f.1: version 2.13
[ 2.966516] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 2.974474] scsi0 : ata_piix
[ 2.976392] scsi1 : ata_piix
[ 2.978986] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1800 irq 14
[ 2.979074] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1808 irq 15
[ 3.150441] ata1.00: ATA-8: SAMSUNG HM160HC, LQ100-10, max UDMA/100
[ 3.150541] ata1.00: 312581808 sectors, multi 16: LBA48
[ 3.152480] ata2.00: ATAPI: HL-DT-ST DVDRAM GSA-T40N, JQ01, max UDMA/33
[ 3.166418] ata1.00: configured for UDMA/100
[ 3.167079] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HM160HC LQ10 PQ: 0 ANSI: 5
[ 3.168750] ata2.00: configured for UDMA/33
[ 3.174439] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-T40N JQ01 PQ: 0 ANSI: 5
[ 3.225819] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 3.226457] sd 0:0:0:0: [sda] Write Protect is off
[ 3.226540] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.226715] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.231927] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.232105] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.237430] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.308513] firewire_core: created device fw0: GUID 0800460300a62f7e, S400
[ 3.324148] sda: sda1 < sda5 sda6 sda7 sda8 sda9 > sda2 sda3
[ 3.328163] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.359361] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.359700] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 4.459732] PM: Starting manual resume from disk
[ 4.459840] PM: Hibernation image partition 8:9 present
[ 4.459848] PM: Looking for hibernation image.
[ 4.476647] PM: Image not found (code -22)
[ 4.476660] PM: Hibernation image not present or could not be loaded.
[ 4.583385] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.321182] udevd[291]: starting version 175
[ 6.754012] Marking TSC unstable due to TSC halts in idle
[ 6.754130] ACPI: acpi_idle registered with cpuidle
[ 6.764206] Switching to clocksource acpi_pm
[ 6.803631] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 6.827032] ACPI: Lid Switch [LID]
[ 6.827471] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 6.827586] ACPI: Power Button [PWRB]
[ 7.026659] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input3
[ 7.026781] ACPI: Video Device [GCH0] (multi-head: yes rom: yes post: no)
[ 7.030457] parport_pc 00:0b: reported by Plug and Play ACPI
[ 7.030615] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 7.139884] ACPI: Battery Slot [BAT1] (battery absent)
[ 7.141021] ACPI: Battery Slot [BAT2] (battery absent)
[ 7.154348] sony_laptop: Sony Programmable IO Control Driver v0.6
[ 7.154463] sony_laptop: detected Type2 model
[ 7.159730] ACPI: AC Adapter [ACAD] (on-line)
[ 7.166640] input: Sony Vaio Keys as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:09/SNY6001:00/input/input4
[ 7.167020] input: Sony Vaio Jogdial as /devices/virtual/input/input5
[ 7.169254] sony_laptop: device allocated minor is 58
[ 7.172941] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 7.182160] sony_laptop: Sony Notebook Control Driver v0.6
[ 7.207734] Intel 82802 RNG detected
[ 7.249376] iTCO_vendor_support: vendor-support=0
[ 7.253185] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 7.253546] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 7.293355] yenta_cardbus 0000:01:02.0: CardBus bridge found [104d:80df]
[ 7.420669] yenta_cardbus 0000:01:02.0: ISA IRQ mask 0x0838, PCI irq 9
[ 7.420756] yenta_cardbus 0000:01:02.0: Socket status: 30000820
[ 7.420832] pci_bus 0000:01: Raising subordinate bus# of parent bus (#01) from #01 to #05
[ 7.421078] yenta_cardbus 0000:01:02.0: pcmcia: parent PCI bridge window: [io 0x3000-0x3fff]
[ 7.421180] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff: excluding 0x3000-0x30ff 0x3400-0x34ff 0x3800-0x38ff 0x3c00-0x3cff
[ 7.456167] yenta_cardbus 0000:01:02.0: pcmcia: parent PCI bridge window: [mem 0xf4100000-0xf41fffff]
[ 7.456282] pcmcia_socket pcmcia_socket0: cs: memory probe 0xf4100000-0xf41fffff: excluding 0xf4100000-0xf410ffff
[ 7.456532] yenta_cardbus 0000:01:02.0: pcmcia: parent PCI bridge window: [mem 0x20000000-0x27ffffff pref]
[ 7.456638] pcmcia_socket pcmcia_socket0: cs: memory probe 0x20000000-0x27ffffff: excluding 0x20000000-0x27ffffff
[ 7.469661] yenta_cardbus 0000:01:02.1: CardBus bridge found [104d:80df]
[ 7.517308] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 7.597243] yenta_cardbus 0000:01:02.1: ISA IRQ mask 0x0838, PCI irq 9
[ 7.597347] yenta_cardbus 0000:01:02.1: Socket status: 30000410
[ 7.597424] pci_bus 0000:01: Raising subordinate bus# of parent bus (#01) from #05 to #09
[ 7.597552] yenta_cardbus 0000:01:02.1: pcmcia: parent PCI bridge window: [io 0x3000-0x3fff]
[ 7.597653] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3000-0x3fff: excluding 0x3000-0x30ff 0x3400-0x34ff 0x3800-0x38ff 0x3c00-0x3cff
[ 7.628133] yenta_cardbus 0000:01:02.1: pcmcia: parent PCI bridge window: [mem 0xf4100000-0xf41fffff]
[ 7.640661] Error: Driver 'pcspkr' is already registered, aborting...
[ 7.649431] pcmcia_socket pcmcia_socket1: cs: memory probe 0xf4100000-0xf41fffff: excluding 0xf4100000-0xf410ffff
[ 7.649692] yenta_cardbus 0000:01:02.1: pcmcia: parent PCI bridge window: [mem 0x20000000-0x27ffffff pref]
[ 7.649792] pcmcia_socket pcmcia_socket1: cs: memory probe 0x20000000-0x27ffffff: excluding 0x20000000-0x27ffffff
[ 7.752007] snd_intel8x0m 0000:00:1f.6: setting latency timer to 64
[ 7.856141] MC'97 1 converters and GPIO not ready (0xff00)
[ 7.857675] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 8.308160] intel8x0_measure_ac97_clock: measured 55376 usecs (2662 samples)
[ 8.308247] intel8x0: clocking to 48000
[ 8.356116] pcmcia_socket pcmcia_socket0: pccard: CardBus card inserted into slot 0
[ 8.356266] pci 0000:02:00.0: [1033:0035] type 0 class 0x000c03
[ 8.356313] pci 0000:02:00.0: reg 10: [mem 0x00000000-0x00000fff]
[ 8.356462] pci 0000:02:00.0: supports D1 D2
[ 8.356475] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot
[ 8.356531] pci 0000:02:00.1: [1033:0035] type 0 class 0x000c03
[ 8.356570] pci 0000:02:00.1: reg 10: [mem 0x00000000-0x00000fff]
[ 8.356706] pci 0000:02:00.1: supports D1 D2
[ 8.356718] pci 0000:02:00.1: PME# supported from D0 D1 D2 D3hot
[ 8.356770] pci 0000:02:00.2: [1033:00e0] type 0 class 0x000c03
[ 8.356809] pci 0000:02:00.2: reg 10: [mem 0x00000000-0x000000ff]
[ 8.356945] pci 0000:02:00.2: supports D1 D2
[ 8.356957] pci 0000:02:00.2: PME# supported from D0 D1 D2 D3hot
[ 8.357011] pci 0000:02:00.0: BAR 0: assigned [mem 0x34000000-0x34000fff]
[ 8.357095] pci 0000:02:00.1: BAR 0: assigned [mem 0x34001000-0x34001fff]
[ 8.357177] pci 0000:02:00.2: BAR 0: assigned [mem 0x34002000-0x340020ff]
[ 8.358207] ehci_hcd 0000:02:00.2: enabling device (0000 -> 0002)
[ 8.358363] ehci_hcd 0000:02:00.2: EHCI Host Controller
[ 8.358481] ehci_hcd 0000:02:00.2: new USB bus registered, assigned bus number 3
[ 8.380361] ehci_hcd 0000:02:00.2: irq 9, io mem 0x34002000
[ 8.392107] ehci_hcd 0000:02:00.2: USB 2.0 started, EHCI 1.00
[ 8.392294] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.392371] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.392462] usb usb3: Product: EHCI Host Controller
[ 8.392530] usb usb3: Manufacturer: Linux 3.2.0-4-486 ehci_hcd
[ 8.392600] usb usb3: SerialNumber: 0000:02:00.2
[ 8.393304] hub 3-0:1.0: USB hub found
[ 8.393393] hub 3-0:1.0: 5 ports detected
[ 8.419663] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 8.419852] ohci_hcd 0000:02:00.0: enabling device (0000 -> 0002)
[ 8.419996] ohci_hcd 0000:02:00.0: setting latency timer to 64
[ 8.420086] ohci_hcd 0000:02:00.0: OHCI Host Controller
[ 8.420206] ohci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 4
[ 8.420369] ohci_hcd 0000:02:00.0: irq 9, io mem 0x34000000
[ 8.450996] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding 0x170-0x177 0x1f0-0x1f7 0x370-0x37f
[ 8.454382] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x3f0-0x3ff 0x4d0-0x4d7
[ 8.455502] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 8.459001] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 8.459976] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xcbfff 0xd8000-0xfffff
[ 8.460467] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[ 8.461032] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
[ 8.461317] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 8.506474] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 8.506564] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.506655] usb usb4: Product: OHCI Host Controller
[ 8.506723] usb usb4: Manufacturer: Linux 3.2.0-4-486 ohci_hcd
[ 8.506793] usb usb4: SerialNumber: 0000:02:00.0
[ 8.508184] hub 4-0:1.0: USB hub found
[ 8.508288] hub 4-0:1.0: 3 ports detected
[ 8.508691] ohci_hcd 0000:02:00.1: enabling device (0000 -> 0002)
[ 8.508887] ohci_hcd 0000:02:00.1: setting latency timer to 64
[ 8.508902] ohci_hcd 0000:02:00.1: OHCI Host Controller
[ 8.509098] ohci_hcd 0000:02:00.1: new USB bus registered, assigned bus number 5
[ 8.509264] ohci_hcd 0000:02:00.1: irq 9, io mem 0x34001000
[ 8.544121] pcmcia_socket pcmcia_socket1: pccard: PCMCIA card inserted into slot 1
[ 8.544346] pcmcia_socket pcmcia_socket1: cs: memory probe 0xf4110000-0xf41fffff:
[ 8.545824] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: excluding 0x170-0x177 0x1f0-0x1f7 0x370-0x37f
[ 8.551691] input: PS/2 Mouse as /devices/platform/i8042/serio1/input/input7
[ 8.559383] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: excluding 0x3f0-0x3ff 0x4d0-0x4d7
[ 8.560731] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 8.561636] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 8.595969] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 8.596166] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.596260] usb usb5: Product: OHCI Host Controller
[ 8.596329] usb usb5: Manufacturer: Linux 3.2.0-4-486 ohci_hcd
[ 8.596399] usb usb5: SerialNumber: 0000:02:00.1
[ 8.603146] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input8
[ 8.610443] excluding 0xf41fe000-0xf420bfff
[ 8.610842] pcmcia 1.0: pcmcia: registering new device pcmcia1.0 (IRQ: 3)
[ 8.615036] pcmcia_socket pcmcia_socket1: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xcbfff 0xd8000-0xfffff
[ 8.615575] pcmcia_socket pcmcia_socket1: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[ 8.615863] pcmcia_socket pcmcia_socket1: cs: memory probe 0x60000000-0x60ffffff: clean.
[ 8.618645] hub 5-0:1.0: USB hub found
[ 8.618754] hub 5-0:1.0: 2 ports detected
[ 8.638239] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 8.824106] 3c574_cs: ASIC rev 1,
[ 8.856025] 3c574_cs 1.0: eth0: Megahertz 574B at io 0x300, irq 3, hw_addr 00:04:75:79:01:5a
[ 8.858581] 3c574_cs 1.0: eth0: 0K FIFO split 1:1 Rx:Tx, autoselect MII interface.
[ 10.546778] Adding 978940k swap on /dev/sda9. Priority:-1 extents:1 across:978940k
[ 10.568672] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 11.188247] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 11.384551] loop: module loaded
[ 15.491245] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 15.615116] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[ 15.726477] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 15.835981] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[ 18.935243] RPC: Registered named UNIX socket transport module.
[ 18.935343] RPC: Registered udp transport module.
[ 18.935409] RPC: Registered tcp transport module.
[ 18.935475] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 19.022242] FS-Cache: Loaded
[ 19.205910] FS-Cache: Netfs 'nfs' registered for caching
[ 19.249022] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 22.172317] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input9
[ 24.332231] Bluetooth: Core ver 2.16
[ 24.332427] NET: Registered protocol family 31
[ 24.332497] Bluetooth: HCI device and connection manager initialized
[ 24.332571] Bluetooth: HCI socket layer initialized
[ 24.332638] Bluetooth: L2CAP socket layer initialized
[ 24.334061] Bluetooth: SCO socket layer initialized
[ 24.386240] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 24.386294] Bluetooth: BNEP filters: protocol multicast
[ 24.571145] lp0: using parport0 (interrupt-driven).
[ 24.591717] ppdev: user-space parallel port driver
[ 29.552057] eth0: no IPv6 routers present
[ 137.636090] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[ 137.771310] usb 3-1: New USB device found, idVendor=0dda, idProduct=2005
[ 137.771419] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 137.771509] usb 3-1: Product: 2.0 Card Reader
[ 137.771593] usb 3-1: Manufacturer: ICSI
[ 137.771673] usb 3-1: SerialNumber: ABCD1234
[ 137.840124] Initializing USB Mass Storage driver...
[ 137.840659] scsi2 : usb-storage 3-1:1.0
[ 137.841103] usbcore: registered new interface driver usb-storage
[ 137.841179] USB Mass Storage support registered.
[ 139.084642] scsi 2:0:0:0: Direct-Access ICSI CF Card CF 1.3A PQ: 0 ANSI: 0 CCS
[ 139.087182] scsi 2:0:0:1: Direct-Access ICSI MS Card MS 1.3A PQ: 0 ANSI: 0 CCS
[ 139.089721] scsi 2:0:0:2: Direct-Access ICSI SD Card MMC/SD 1.3A PQ: 0 ANSI: 0 CCS
[ 139.092109] scsi 2:0:0:3: Direct-Access ICSI SM Card SM 1.3A PQ: 0 ANSI: 0 CCS
[ 139.105219] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 139.105515] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 139.113825] sd 2:0:0:1: [sdc] Attached SCSI removable disk
[ 139.120408] sd 2:0:0:1: Attached scsi generic sg3 type 0
[ 139.128225] sd 2:0:0:2: [sdd] 985088 512-byte logical blocks: (504 MB/481 MiB)
[ 139.128750] sd 2:0:0:2: Attached scsi generic sg4 type 0
[ 139.129752] sd 2:0:0:2: [sdd] Write Protect is off
[ 139.129864] sd 2:0:0:2: [sdd] Mode Sense: 43 00 00 08
[ 139.131406] sd 2:0:0:2: [sdd] No Caching mode page present
[ 139.131529] sd 2:0:0:2: [sdd] Assuming drive cache: write through
[ 139.142755] sd 2:0:0:2: [sdd] No Caching mode page present
[ 139.142858] sd 2:0:0:2: [sdd] Assuming drive cache: write through
[ 139.145065] sd 2:0:0:3: [sde] Attached SCSI removable disk
[ 139.146533] sd 2:0:0:3: Attached scsi generic sg5 type 0
[ 139.147133] sdd: sdd1
[ 139.155893] sd 2:0:0:2: [sdd] No Caching mode page present
[ 139.155999] sd 2:0:0:2: [sdd] Assuming drive cache: write through
[ 139.158605] sd 2:0:0:2: [sdd] Attached SCSI removable disk
[ 167.287068] EXT4-fs (sda1): unable to read superblock
[ 176.549059] FAT-fs (sdd1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
