http://debian.linux.pl/viewtopic.php?t= ... e56ce7a206
I pokazało mi się nagle... :shock:
(EE)Failed to load module "nvidia" (module does not exsist ,0)
(EE)No drivers availableKod: Zaznacz cały
"waiting for root file system... ..."Kod: Zaznacz cały
/dev/hdb1       /               ext3    defaults,errors=remount-ro 0       1
/dev/hdb5       none            swap    sw              0       0
/dev/hde        /media/cdrom0   udf,iso9660 user,noauto     0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto  0       0Kod: Zaznacz cały
/dev/sdb1       /               ext3    defaults,errors=remount-ro 0       1
/dev/sdb5       none            swap    sw              0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto  0       0A to ci ciekawostkaKaka' pisze:Bo w kernelu 2.6.21 (bodajże) zostały zmienione oznakowania dysków
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default		0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout		5
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title		Windows 95/98/NT/2000
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
# kernel	/vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##      kopt_2_6_8=root=/dev/hdc1 ro
##      kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=/dev/hdf1 ro linux26
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=
## should update-grub lock old automagic boot options
## e.g. lockold=false
##      lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(single-user) single
# altoptions=(single-user mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## ## End Default Options ##
title		Debian GNU/Linux, kernel 2.6.21-2-686
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.21-2-686 root=/dev/hdf1 ro linux26
initrd		/boot/initrd.img-2.6.21-2-686
savedefault
title		Debian GNU/Linux, kernel 2.6.21-2-686 (single-user mode)
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.21-2-686 root=/dev/hdf1 ro linux26 single
savedefault
title		Debian GNU/Linux, kernel 2.6.18-4-686
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-4-686 root=/dev/hdf1 ro linux26
initrd		/boot/initrd.img-2.6.18-4-686
savedefault
title		Debian GNU/Linux, kernel 2.6.18-4-686 (single-user mode)
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-4-686 root=/dev/hdf1 ro linux26 single
savedefault
title		Debian GNU/Linux, kernel 2.6.18-4-486
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-4-486 root=/dev/hdf1 ro linux26
initrd		/boot/initrd.img-2.6.18-4-486
savedefault
title		Debian GNU/Linux, kernel 2.6.18-4-486 (single-user mode)
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-4-486 root=/dev/hdf1 ro linux26 single
savedefault
### END DEBIAN AUTOMAGIC KERNELS LISTKod: Zaznacz cały
root		(hd0,0)
initrd		/boot/initrd.img-2.6.21-2-686Kod: Zaznacz cały
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.21-2-686 root=/dev/sdf1 ro linux26
