Problem z fglrx
zjam
Problem z fglrx
Post autor: zjam »
Mam problem z akceleracja fglrx - debian sid:
bląd log Xorg
drmOpenByBusid: drmOpenMinor returns -1023
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 6, (OK)
drmGetBusid returned ''
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0x2000
(II) fglrx(0): [drm] mapped SAREA 0x2000 to 0xa719a000
(II) fglrx(0): [drm] framebuffer handle = 0x3000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0):     Name: fglrx
(II) fglrx(0):     Version: 8.24.8
(II) fglrx(0):     Date: Apr 11 2006
(II) fglrx(0):     Desc: ATI FireGL DRM kernel module
(WW) fglrx(0): Kernel Module version does *not* match driver.
(EE) fglrx(0): incompatible kernel module detected - HW accelerated OpenGL will not work
(II) fglrx(0): [drm] removed 1 reserved context for kernel
(II) fglrx(0): [drm] unmapping 8192 bytes of SAREA 0x2000 at 0xa719a000
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                  *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO)             *
(WW) fglrx(0): * no 3D acceleration available                *
(WW) fglrx(0): ********************************************* *
dmesg
fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[fglrx] Maximum main memory to use for locked dma buffers: 929 MBytes.
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 209
[fglrx] module loaded - fglrx 8.24.8 [Apr 11 2006] on minor 0
[fglrx:firegl_unlock] *ERROR* Process 4500 using kernel context 0
lspci
01:00.0 VGA compatible controller: ATI Technologies Inc RV350 AS [Radeon 9550]
01:00.1 Display controller: ATI Technologies Inc RV350 ?? [Radeon 9550] (Secondary)
xorg.conf
Section "ServerLayout"
        Identifier     "Default Layout"
        Screen      0  "aticonfig Screen 0" 0 0
        InputDevice    "Generic Keyboard"
        InputDevice    "Configured Mouse"
EndSection
Section "Files"
        # path to defoma fonts
        FontPath     "/usr/share/fonts/X11/misc"
        FontPath     "/usr/share/fonts/X11/cyrillic"
        FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath     "/usr/share/fonts/X11/Type1"
        FontPath     "/usr/share/fonts/X11/100dpi"
        FontPath     "/usr/share/fonts/X11/75dpi"
        FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
        Load "dbe"
        Load  "i2c"
        Load  "bitmap"
        Load  "ddc"
        Load  "dri"
        Load  "extmod"
        Load  "freetype"
        Load  "glx"
        Load  "int10"
        Load  "type1"
        Load  "vbe"
EndSection
Section "InputDevice"
        Identifier  "Generic Keyboard"
        Driver      "kbd"
        Option      "CoreKeyboard"
        Option      "XkbRules" "xorg"
        Option      "XkbModel" "pc105"
        Option      "XkbLayout" "pl"
EndSection
        Identifier  "Configured Mouse"
        Driver      "mouse"
        Option      "CorePointer"
        Option      "Device" "/dev/input/mice"
        Option      "Protocol" "ExplorerPS/2"
        Option      "Emulate3Buttons" "true"
EndSection
Section "Monitor"
        Identifier   "Generic Monitor"
        HorizSync    28.0 - 51.0
        VertRefresh  43.0 - 60.0
        Option      "DPMS"
EndSection
Section "Monitor"
        Identifier   "aticonfig Monitor 0"
EndSection
Section "Device"
        Identifier  "ATI Technologies, Inc. RV350 AS [Radeon 9600 AS]"
        Driver      "ati"
EndSection
Section "Device"
        Identifier  "ATI Graphics Adapter 0"
        Driver      "fglrx"
        BusID       "PCI:1:0:0"
#       Option "UseInternalAGPGART" "yes"
EndSection
Section "Screen"
        Identifier "Default Screen"
        Device     "ATI Technologies, Inc. RV350 AS [Radeon 9600 AS]"
        Monitor    "Generic Monitor"
        DefaultDepth     24
        SubSection "Display"
                Depth     1
                Modes    "1024x768" "800x600" "640x480"
        EndSubSection
                Depth     4
        EndSubSection
                Depth     8
        EndSubSection
                Depth     15
        EndSubSection
                Depth     16
        EndSubSection
                Depth     24
        EndSubSection
EndSectionSection "Screen"
        Identifier "aticonfig Screen 0"
        Device     "ATI Graphics Adapter 0"
        Monitor    "aticonfig Monitor 0"
        DefaultDepth     24
                Viewport   0 0
                Depth     24
        EndSubSection
EndSection
Section "DRI"
        Mode         0666
EndSection
prosze o wszelka pomoc
Verdan
Re: Problem z fglrx
Post autor: Verdan »
zjam pisze:
Sprawdz raz jeszcze czy masz wkompilowane DRM i googlnij w poszukiwaniu podobnego problemu.
Pozdrawiam,
Verdan
zjam
Post autor: zjam »
fglrx: version magic '2.6.16-2-686 686 gcc-4.1' should be '2.6.16-2-686 686 gcc-4.0'
Jak odinstaluje gcc-4.1 to gcc command not found jak ten moduł skompilować na 4.0 ?
chyl-o
Post autor: chyl-o »
A probowales zainstalowac gcc4.0?
dodi
Post autor: dodi »
mam 4.0 ale pakietem gcc jest wersja 4.1, musze przekompilować jądro zapewne pod 4.1 i bedzie k :)
Verdan
zjam pisze: Jak odinstaluje gcc-4.1 to gcc command not found jak ten moduł skompilować na 4.0 ?
Nie musisz odinstalowywać wersji gcc którą aktualnie masz jeśli chcesz mieć inną (pod warunkiem, że nie kłócą się zależności). Dostęp do innych gcc masz po wpisaniu komendy gcc-[Wersja].
Np. gcc-3.3. Wpisz gcc i stuknij dwa razy tab (jeśli masz completition).
Pozdrawiam,
V.
