xorg- error 104
w3b
xorg- error 104
Post autor: w3b »
Witam, troche glupio, ze moj pierwszy post i od razu problem :P no ale nic.... wyszlo jak wyszlo.
Tak wiec problem jest jasny nie dziala mi xorg ;) a dokladnie mowiac nie odpala sie z poziomu zwyklego uzytkownika( z roota chodzi :) ).
Gdy odpale startx otrzymuje:
hostname: Unknown host
xauth: creating new authority file /home/w3b/.serverauth.1727
xauth: (argv):1: bad display name "wzgorza:0" in "list" command
xauth: (stdin):1: bad display name "wzgorza:0" in "add" command
X: warning; nice() of process failed: Permission denied
X: warning; process set to priority -1 instead of requested priority -10
X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.12-1-686 i686
Current Operating System: Linux wzgorza 2.4.27-2-686 #1 Wed Nov 30 21:55:37 JST 2005 i686
Build Date: 16 March 2006
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 20 12:21:12 2006
Fatal server error:
xf86OpenConsole: Cannot open /dev/tty0 (No such file or directory)
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
xauth: (argv):1: bad display name "wzgorza:0" in "remove" command
Log jaki zostawia xorg wyglada nastepujaco
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 20 12:10:38 2006
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/OTF" does not exist.
(WW) The directory "/usr/share/fonts/X11/CID/" does not exist.
(**) FontPath set to "/usr/share/fonts/X11/misc/,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/100dpi/,/usr/share/fonts/X11/75dpi/,/usr/share/fonts/X11/misc/,/usr/share/fonts/X11/TTF/,/usr/share/fonts/X11/OTF,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/CID/,/usr/share/fonts/X11/100dpi/,/usr/share/fonts/X11/75dpi/"
(**) RgbPath set to "/usr/share/X11/rgb"
(**) ModulePath set to "/usr/lib/xorg/modules,/usr/lib/xorg/modules"
(WW) xf86ReadBIOS: Failed to open /dev/mem (Operation not permitted)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.0
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
ABI class: X.Org Video Driver, version 0.8
Fatal server error:
(WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor
(WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor
natomiast moj xorg.conf wyglada prawie jak defaultowy
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/share/X11/rgb"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc/"
FontPath "/usr/share/fonts/X11/TTF/"
FontPath "/usr/share/fonts/X11/OTF"
FontPath "/usr/share/fonts/X11/Type1/"
FontPath "/usr/share/fonts/X11/CID/"
FontPath "/usr/share/fonts/X11/100dpi/"
FontPath "/usr/share/fonts/X11/75dpi/"
EndSection
Section "Module"
Load "extmod"
Load "dbe"
Load "dri"
Load "glx"
Load "record"
Load "xtrap"
Load "freetype"
Load "type1"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
#DisplaySize 330 240 # mm
Identifier "Monitor0"
VendorName "NEC"
ModelName "NEC FE791SB"
### Comment all HorizSync and VertSync values to use DDC:
HorizSync 30.0 - 96.0
VertRefresh 50.0 - 160.0
Option "DPMS"
EndSection
Section "Device"
### Available Driver options are:-
### Values: : integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "UseFBDev" # [<bool>]
#Option "Rotate" # [<str>]
#Option "VideoKey" #
#Option "FlatPanel" # [<bool>]
#Option "FPDither" # [<bool>]
#Option "CrtcNumber" #
#Option "FPScale" # [<bool>]
#Option "FPTweak" #
Identifier "Card0"
Driver "nv"
VendorName "nVidia Corporation"
BoardName "NV11 [GeForce2 MX/MX 400]"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
siedzialem troche juz nad tym, byly jeszcze inne errory dotyczace fontow ale z tym sobie jeszcze poradzilem, jak widac cos jest nie tak:P
Z gory dziekuje za pomoc
fik
Post autor: fik »
Ten problem wystąpił zaraz po instalacji systemu, czy jak zabiłeś X'y? Jeśli w tym drugim przypadku to spróbuj poczyścić X'owe pliki w /tmp, być może zostały jakieś śmieci.
Jeśli Xorg odpala się z roota to jest to problem lokalnego użytkownika. Nie wiem na bank, ale chyba user musi być dodany do grupy video? Spróbuj.
pzdr.
w3b
Post autor: w3b »
okej zaraz sprobuje :) lece na kochanego debianka ;)
