Czytnik kart SD i Ubuntu
szlejk
Post autor: szlejk »
Proszę o pomoc w uruchomieniu cztnika kart sd w laptopie acer aspire 5720, system Ubuntu 14.4. Przestał działać po aktusalizacji systemu.
Mirek
Re: Czytnik kart SD i Ubuntu
Podaj wyniki komend:
lsb_release -a
lsusb
uname -r
dmesg | grep -i usb
szlejk
lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 14.04.4 LTS
Release:	14.04
Codename:	trusty
lsusb
Bus 002 Device 002: ID 5986:0102 Acer, Inc Crystal Eye Webcam
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 uname -r
3.13.0-86-generic
dmesg | grep -i usb
[    0.669003] ACPI: bus type USB registered
[    0.669003] usbcore: registered new interface driver usbfs
[    0.669003] usbcore: registered new interface driver hub
[    0.669003] usbcore: registered new device driver usb
[    3.177758] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.177963] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    3.192074] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    3.192173] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.192180] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.192186] usb usb1: Product: EHCI Host Controller
[    3.192192] usb usb1: Manufacturer: Linux 3.13.0-86-generic ehci_hcd
[    3.192197] usb usb1: SerialNumber: 0000:00:1a.7
[    3.192391] hub 1-0:1.0: USB hub found
[    3.192777] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    3.208113] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    3.208223] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.208230] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.208235] usb usb2: Product: EHCI Host Controller
[    3.208240] usb usb2: Manufacturer: Linux 3.13.0-86-generic ehci_hcd
[    3.208246] usb usb2: SerialNumber: 0000:00:1d.7
[    3.208435] hub 2-0:1.0: USB hub found
[    3.208730] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.208756] uhci_hcd: USB Universal Host Controller Interface driver
[    3.208931] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    3.209030] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    3.209034] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.209036] usb usb3: Product: UHCI Host Controller
[    3.209039] usb usb3: Manufacturer: Linux 3.13.0-86-generic uhci_hcd
[    3.209042] usb usb3: SerialNumber: 0000:00:1a.0
[    3.209182] hub 3-0:1.0: USB hub found
[    3.209476] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    3.209576] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    3.209579] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.209582] usb usb4: Product: UHCI Host Controller
[    3.209585] usb usb4: Manufacturer: Linux 3.13.0-86-generic uhci_hcd
[    3.209587] usb usb4: SerialNumber: 0000:00:1a.1
[    3.209727] hub 4-0:1.0: USB hub found
[    3.210019] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[    3.210105] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.210108] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.210111] usb usb5: Product: UHCI Host Controller
[    3.210113] usb usb5: Manufacturer: Linux 3.13.0-86-generic uhci_hcd
[    3.210116] usb usb5: SerialNumber: 0000:00:1d.0
[    3.210259] hub 5-0:1.0: USB hub found
[    3.210550] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[    3.210647] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.210650] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.210652] usb usb6: Product: UHCI Host Controller
[    3.210655] usb usb6: Manufacturer: Linux 3.13.0-86-generic uhci_hcd
[    3.210658] usb usb6: SerialNumber: 0000:00:1d.1
[    3.210800] hub 6-0:1.0: USB hub found
[    3.211097] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[    3.211184] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.211187] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.211190] usb usb7: Product: UHCI Host Controller
[    3.211193] usb usb7: Manufacturer: Linux 3.13.0-86-generic uhci_hcd
[    3.211195] usb usb7: SerialNumber: 0000:00:1d.2
[    3.211334] hub 7-0:1.0: USB hub found
[    3.520024] usb 2-4: new high-speed USB device number 2 using ehci-pci
[    3.946299] usb 2-4: New USB device found, idVendor=5986, idProduct=0102
[    3.946306] usb 2-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.946312] usb 2-4: Product: Acer Crystal Eye webcam
[   24.370923] input: Acer Crystal Eye webcam  as /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/input/input15
[   24.371073] usbcore: registered new interface driver uvcvideo
[   24.371076] USB Video Class driver (1.1.1)
[   24.728069] usb 7-2: new full-speed USB device number 2 using uhci_hcd
[   24.901078] usb 7-2: New USB device found, idVendor=0a5c, idProduct=2101
[   24.901087] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   24.901094] usb 7-2: Product: Acer Module
[   24.901100] usb 7-2: Manufacturer: Broadcom Corp
[   25.744447] usbcore: registered new interface driver btusb
[  323.560170] usb 7-2: USB disconnect, device number 2
