Crunchbang nie dzia
Schadoow
Crunchbang nie działa BT na X201
Post autor: Schadoow »
Witam, mam problem z bluetooth, nie umiem go poprawnie zainstalować, na maszynie Lenovo thinkpad x201. Z góry dziękuję za wszelką pomoc.
/etc/init.d/bluetooth status
bluetooth is running.
A przy próbie uruchomienia np:
bluez-test-device Traceback (most recent call last):
  File "/usr/bin/bluez-test-device", line 28, in <module>
    adapter_path = manager.DefaultAdapter()
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 70, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.bluez.Error.NoSuchAdapter: No such adapter
Więc domyślam się, że sterowniki są nie zainstalowane albo niepoprawnie.
Info:
Linux crunchbang 3.2.0-4-amd64 #1 SMP Debian 3.2.68-1+deb7u3 x86_64 GNU/Linux
lspci -k
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
    Subsystem: Lenovo Device 2193
    Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
    Subsystem: Lenovo Device 215a
    Kernel driver in use: i915
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
    Subsystem: Lenovo Device 215f
00:16.3 Serial controller: Intel Corporation 5 Series/3400 Series Chipset KT Controller (rev 06)
    Subsystem: Lenovo Device 2162
    Kernel driver in use: serial
00:19.0 Ethernet controller: Intel Corporation 82577LM Gigabit Network Connection (rev 06)
    Subsystem: Lenovo Device 2153
    Kernel driver in use: e1000e
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
    Subsystem: Lenovo Device 2163
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
    Subsystem: Lenovo Device 215e
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 06)
    Subsystem: Lenovo Device 2166
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06)
    Subsystem: Lenovo Device 2168
    Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
    Subsystem: Lenovo Device 2167
    Kernel driver in use: i801_smbus
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 06)
    Subsystem: Lenovo Device 2190
    Kernel driver in use: intel ips
02:00.0 Network controller: Intel Corporation Centrino Advanced-N 6200 (rev 35)
    Subsystem: Intel Corporation Centrino Advanced-N 6200 2x2 AGN
    Kernel driver in use: iwlwifi
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
    Subsystem: Lenovo Device 2196
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
ff:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
lspci -n
00:00.0 0600: 8086:0044 (rev 02)
00:02.0 0300: 8086:0046 (rev 02)
00:16.0 0780: 8086:3b64 (rev 06)
00:16.3 0700: 8086:3b67 (rev 06)
00:19.0 0200: 8086:10ea (rev 06)
00:1a.0 0c03: 8086:3b3c (rev 06)
00:1b.0 0403: 8086:3b56 (rev 06)
00:1c.0 0604: 8086:3b42 (rev 06)
00:1c.3 0604: 8086:3b48 (rev 06)
00:1c.4 0604: 8086:3b4a (rev 06)
00:1d.0 0c03: 8086:3b34 (rev 06)
00:1e.0 0604: 8086:2448 (rev a6)
00:1f.0 0601: 8086:3b07 (rev 06)
00:1f.2 0106: 8086:3b2f (rev 06)
00:1f.3 0c05: 8086:3b30 (rev 06)
00:1f.6 1180: 8086:3b32 (rev 06)
02:00.0 0280: 8086:4239 (rev 35)
ff:00.0 0600: 8086:2c62 (rev 02)
ff:00.1 0600: 8086:2d01 (rev 02)
ff:02.0 0600: 8086:2d10 (rev 02)
ff:02.1 0600: 8086:2d11 (rev 02)
ff:02.2 0600: 8086:2d12 (rev 02)
ff:02.3 0600: 8086:2d13 (rev 02)
pone13
Post autor: pone13 »
Jesteś pewien, że ten notebook posiada moduł bluetooth?
Podaj dodatkowo wynik lsusb.
Garść informacji, które może pomogą...
Status interfejsu:
hciconfig status
Włączenie interfejsu:
hciconfig hci0 up
Zamiast hci0 może być inna nazwa, wypisze ją pierwsze polecenie.
Jeżeli nie ma żadnego dostępnego interfejsu wynik będzie pusty.
Sprawdzenie czy interfejs nie jest wyłączony przełącznikiem/skrótem klawiaturowym:
rfkill list
