Netia, Sagem F@st 800e4 si
WiCiO_MeDi
Netia, Sagem F@st 800e4 się resetuje i rozłącza nonstop
Post autor: WiCiO_MeDi »
Witam szanowne grono.
Mam uruchomiony serwer na Debianie Lenny. Wykonałem na nim instrukcje zgodnie z opisem ISP workaround i wszystko działało (około 2m-ce) do czasu aż modem zaczął świrować. Log messages:
Jan 20 14:06:03 kernel: [ 4957.606778] usb 2-2: [ueagle-atm] (re)booting started
Jan 20 14:06:04 kernel: [ 4958.734843] firmware: requesting ueagle-atm/DSP4p.bin
Jan 20 14:06:04 kernel: [ 4958.988516] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 20 14:06:04 kernel: [ 4958.988516] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 20 14:06:04 kernel: [ 4959.179837] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Jan 20 14:06:19 kernel: [ 4974.504694] usb 2-2: [ueagle-atm] (re)booting started
Jan 20 14:06:20 kernel: [ 4975.632734] firmware: requesting ueagle-atm/DSP4p.bin
Jan 20 14:06:21 kernel: [ 4975.900700] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 20 14:06:21 kernel: [ 4975.900700] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 20 14:06:21 kernel: [ 4976.011044] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Jan 20 14:06:31 pppd[5244]: LCP: timeout sending Config-Requests
Jan 20 14:06:31 pppd[5244]: Connection terminated.
Jan 20 14:06:31 pppd[5244]: Modem hangup
Jan 20 14:06:42 kernel: [ 4997.131966] usb 2-2: [ueagle-atm] modem synchronization failed (may be try other cmv/dsp)
Jan 20 14:06:42 kernel: [ 4997.131973] usb 2-2: [ueagle-atm] (re)booting started
Jan 20 14:06:43 kernel: [ 4998.261468] firmware: requesting ueagle-atm/DSP4p.bin
Jan 20 14:06:43 kernel: [ 4998.509983] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 20 14:06:43 kernel: [ 4998.509983] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 20 14:06:43 kernel: [ 4998.714020] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Jan 20 14:07:01 pppd[5244]: Using interface ppp0
Jan 20 14:07:01 pppd[5244]: Connect: ppp0 <--> 0.35
Jan 20 14:07:08 kernel: [ 5023.849833] usb 2-2: [ueagle-atm] modem synchronization failed (may be try other cmv/dsp)
Jan 20 14:07:08 kernel: [ 5023.849839] usb 2-2: [ueagle-atm] (re)booting started
Jan 20 14:07:09 kernel: [ 5025.003605] firmware: requesting ueagle-atm/DSP4p.bin
Jan 20 14:07:10 kernel: [ 5025.175532] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 20 14:07:10 kernel: [ 5025.175532] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 20 14:07:10 kernel: [ 5025.357389] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Jan 20 14:07:25 kernel: [ 5040.395595] usb 2-2: [ueagle-atm] (re)booting started
Jan 20 14:07:26 kernel: [ 5041.524235] firmware: requesting ueagle-atm/DSP4p.bin
Jan 20 14:07:26 kernel: [ 5041.754436] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 20 14:07:26 kernel: [ 5041.754436] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 20 14:07:26 kernel: [ 5041.966433] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Jan 20 14:07:31 pppd[5244]: LCP: timeout sending Config-Requests
Jan 20 14:07:31 pppd[5244]: Connection terminated.
Jan 20 14:07:31 pppd[5244]: Modem hangup
Jan 20 14:07:41 kernel: [ 5057.014088] usb 2-2: [ueagle-atm] (re)booting started
Jan 20 14:07:42 kernel: [ 5058.142133] firmware: requesting ueagle-atm/DSP4p.bin
Jan 20 14:07:43 kernel: [ 5058.350102] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 20 14:07:43 kernel: [ 5058.350102] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 20 14:07:43 kernel: [ 5058.495922] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Jan 20 14:08:01 pppd[5426]: Plugin pppoatm.so loaded.
Jan 20 14:08:01 pppd[5426]: pppd 2.4.4 started by root, uid 0
Jan 20 14:08:01 pppd[5426]: Using interface ppp0
Jan 20 14:08:01 pppd[5426]: Connect: ppp0 <--> 0.35
Jan 20 14:08:01 pppd[5244]: Exit.
I tak w kółko, a jak zaskoczy to działa przez kilka godzin po czym znowu się rozłącza. Mam w cronie skrypt:
#!/bin/bash
ping -c 1 wp.pl > /dev/null 2>&1
if [ ! $? -eq 0 ]; then
  /usr/sbin/pppd call linnet
fi
I jak widać modem jest skonfigurowany przez linnet.
Serwer jest postawiony w firmie i ludzie muszą mieć do niego dostęp z zewnątrz (dyndns daje rade).
Bardzo proszę o jakieś sugestie gdzie błąd leżeć może.
Zastanawiam się dlaczego tak mało odpowiedzialnie podchodzisz do działania własnej firmy lub firmy, w której pracujesz. Modem ten jest przeznaczony dla użytkownika zwykłego komputera domowego. W przypadku serwera, przy ciągłej pracy, może odmówić współpracy nie tyle sam modem co źródło zasilania, jakim jest port usb. Przyczyn takiego zachowania modemu może być bardzo dużo. Myślę, że lepiej zainwestować w porządny ruter niż dochodzić dlaczego tak się dzieje w tym przypadku. Modem raczej jest sprawny (rzadko ulega awariom).
Możesz spróbować zasilić modem z dwóch niezależnych gałęzi usb i nie nie korzystać z żadnych innych urządzeń wymagających portu usb.
WiCiO_MeDi
Dziękuję za odpowiedź.
Firma nie należy do mnie, jestem pracownikiem. Oczywiście, że sugerowałem łącze biznesowe (mamy domowe), chciałem kupić ruter ADSL (szef: mamy już jakiś stary, więc po co nam kolejny). Ja tu tylko pracuję :)
Wracając do meritum:
Do komputera jest podpięty tylko modem, kabel USB i zasilanie. Konfiguracja komputera jest z 2009r. (c2d e6600, płyta asus nForce 9300, etc). Jeśli dobrze zrozumiałem mam spróbować stworzyć kabelek z dwoma wtyczkami USB (z czego jedna ma być podpięta tylko pod +5v i -5v) oraz jednym "gniazdkiem" pod modem. Zlecę elektrykowi :)
Rozumiem, że takie błędy RACZEJ nie wynikają ze złej konfiguracji oprogramowania..
PS.
A może by tak kupić na allegro modem pod LAN, one mają zasilanie zewnętrzne i są przeznaczone do ciągłej pracy.. dobrze kombinuję?
Stop, żadne minus pięć. Z portu USB modem jest zasilany napięciem plus pięć wolt. Tego typu kable można kupić gotowe. Można też zrobić, tylko wcześniej należy sprawdzić jak jest zbudowany kabel USB, chociażby tu: http://pl.wikipedia.org/wiki/USB.
Można uszkodzić płytę lub modem jak się coś źle podepnie. Najlepiej kup gotowy kabel.
Trudno powiedzieć co jest powodem takich komunikatów. Mam ten modem z neostradą i dziwne informacje nieraz wyświetla ale działa.
WiCiO_MeDi
Ok, tak napisałem bo dokładnie na wiki zobaczyłem styki '+' i '-', a wiem że tam jest 5V i wyskoczyłem z wnioskami w złym kierunku :-?
Kłopotu nie będzie bo mamy w firmie wykwalifikowanego elektryka/elektronika, który sobie z tym poradzi, a jak nie to się kupi.
Kolejny "ciekawy" komunikat z syslog:
Jan 21 12:23:26 sekut kernel: [ 8717.112744] usb 2-2: [ueagle-atm] modem synchronization failed (may be try other cmv/dsp)
Jan 21 12:23:26 sekut kernel: [ 8717.112750] usb 2-2: [ueagle-atm] (re)booting started
Jan 21 12:23:27 sekut kernel: [ 8718.303760] firmware: requesting ueagle-atm/DSP4p.bin
Jan 21 12:23:27 sekut kernel: [ 8718.573428] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 21 12:23:27 sekut kernel: [ 8718.573428] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 21 12:23:27 sekut kernel: [ 8718.811295] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
*** Jan 21 12:23:55 sekut kernel: [ 8747.037020] usb 2-2: [UEAGLE-ATM] reading cmv failed with error -110 ***
Jan 21 12:23:56 sekut kernel: [ 8748.037037] usb 2-2: [ueagle-atm] (re)booting started
Jan 21 12:23:57 sekut kernel: [ 8749.167478] firmware: requesting ueagle-atm/DSP4p.bin
Jan 21 12:23:58 sekut kernel: [ 8749.475299] usb 2-2: [ueagle-atm] ATU-R firmware version : a10050b
Jan 21 12:23:58 sekut kernel: [ 8749.475299] firmware: requesting ueagle-atm/CMV4p.bin.v2
Jan 21 12:23:58 sekut kernel: [ 8749.584355] usb 2-2: [ueagle-atm] modem started, waiting synchronization...
Czy ten błąd cmv może oznaczać coś konkretnego?
Ten konfig działa praktycznie od kwietnia 2009r. i do tej pory nie było takich komunikatów, albo były tak sporadyczne, że ich nawet nie zauważyłem. Szukam źródła kłopotu, bo podejrzewam: komputer, modem, linię telefoniczną (jest przekombinowana w budynku i bywają z nią kłopoty) albo z usługę (z Netią też były zwarcia).
Nie wiem. Może spróbuj ponownie skonfigurować połączenie:
http://debian.linux.pl/viewtopic.php?p=89292#89292
WiCiO_MeDi
Nie pomogło.. Jest tak samo jak było z małym dodatkiem:
Jan 21 14:18:05 sekut pppd[6850]: Couldn't increase MTU to 1500. Using 1492
Może należałoby zasięgnąć do podstaw, czyli najpierw sprawdzić wszystkie kable a później grzebać w systemie ;-)
Kolega elektryk chory, więc pozwolę sobie wrócić do tematu w przyszłym tygodniu po "wymianie" kabla USB i prawdopodobnie przy nowym kablu telekomunikacji, bo to gniazko było kiedyś zalane.....
Póki co dziękuję za pomoc!
beel
Post autor: beel »
Może to nie jest rozwiązanie, które by cię satysfakcjonowało. Aczkolwiek rozważałeś pozbycie się tego modemu? A w zamian postawić jakiś Ethernetowy (np. któryś model SpeedStream z usługi DSL od TP)? Z życia wiem, iż z nimi mniej problemów, w przyszłości może okazać się istotne.
WiCiO_MeDi
A wiesz, że sam zasugerowałem to rozwiązanie w mojej drugiej wypowiedzi w tym temacie?
Ano rozważam tą opcję bo byłaby najbezpieczniejsza, tylko patrząc pobieżnie na allegro widziałem same rutery albo modemy na USB.
Teraz szukając SpeedStream znalazłem za 120zł, więc prawie tyle co jakiś lichy ruter.
Sam posiadałem takie cacko jak miałem usługę Dialnet i śmigało że aż miło.
Ale powtórzę się: nie moja firma, a szef sknera.
Pobawimy się kabelkami, a jak to nie pomoże to się zainwestuje w firmę 8-)
beel
Post autor: beel »
WiCiO_MeDi pisze:A wiesz, że sam zasugerowałem to rozwiązanie w mojej drugiej wypowiedzi w tym temacie?
Czytałem pobieżnie. U mnie gdzieś się kurzy taki SS, ma nawet firmware odpowiedni wgrany i testowany był na usłudze Netii. Jedynym mankamentem jego było to, że musiał mieć przełącznik "w pobliżu". Z tego co pamiętam to SS był to koszt ~50zł.
