Logowanie przez SSH bez has
Logowanie przez SSH bez hasła
Próbowałem się posłużyć skryptem dla shella ze strony:
kliknij tutaj
Niestety nadal pyta o hasło, przez ręczny eksport kluczy też próbowałem i cały czas to samo.
Jakaś rada?
kliknij tutaj
Jakaś rada?
sprawdz to i to
Po zatym wlasnie sprawdzilem link ktory podales ale niestety nie ma tam zadnego skryptu.
Mowie tutaj o tej stronie http://projects.ludwikc.net/passwordless_ssh (link ze strony autora)
Zamiesc ten skrypt moze wtedy bedzie mozna powiedziec cos wiecej
[/code]
[/code]
Chodzi o ten skrypt. Sprawdze to co mi podales dziekuje.
#!/bin/sh
cd $HOME
echo "Passwordless ssh (v. 0.6)"
echo "Enter your ssh username:"
read user
echo "Host (or ip):"
read host
# Ports added in 0.4
echo "Enter ssh port: (press Enter if you don't know)"
read port
if port=NULL
then port=22
fi
echo "Wait for connection and type password for given username"
scp -P $port $HOME/.ssh/id_rsa.pub $user@$host:~/id_rsa-passwordless.pub
echo "Success: RSA key exported."
echo "Last with-password ssh login..."
ssh $user@$host -p $port "if [ -d $dotssh ]
then
echo "Success: Directory $HOME/.ssh/ exists."
else
echo -e "There is no $HOME/.ssh/ directory." && mkdir $HOME/.ssh && echo "Success: Directory $HOME/.ssh has been created"
fi &&
cat ~/id_rsa-passwordless.pub >> .ssh/authorized_keys && rm id_rsa-passwordless.pub && chmod 700 ~/.ssh && chmod 600 ~/.ssh/authorized_keys && exit"
echo "Authorization successful!"
# Added in 0.3 version - symlinks providing easier login
echo ""
if [ -d $HOME/.ssh/passwordless_login ]
then
echo "Directory $HOME/.ssh/passwordless_login has been created during last passwordless_ssh usage."
else
mkdir $HOME/.ssh/passwordless_login
fi
echo ssh $user@$host -p $port >> ~/.ssh/passwordless_login/$host
chmod +x ~/.ssh/passwordless_login/$host
ln -s ~/.ssh/passwordless_login/$host $host
echo "From now-on simply type ./$host, to log-in without password."
echo "Passwordless ssh by Ludwik C. Siadlak ([url]http://ludwikc.net[/url]). GPL Licence. Have a nice day!"
Re: Logowanie przez SSH bez hasła
A demon ssh na maszynie do której sie podłaczasz, skonfigurowany jest do pracy z authorized_keys?dacula pisze:Witam.
kliknij tutaj
Jakaś rada?
http://rapidshare.com/files/252635583/s ... h.txt.html
tutaj masz mój skrypt.
Wygeneruj klucz na komputerze, z którego się łączysz, po czym w tablicy adresów podaj IP komputera, do którego uzyskać chcesz dostęp, po czym odpal skrypt. Usuń tylko ostatnie linijki tam gdzie wykonywane jest przykładowe działanie skryptu.
