ProtonVPN nie uruchamia się.
sp5smy
Kontakt:
Post autor: sp5smy »
Debian 12
Proton zainstalował się bez problemu.
Łączy z serwerami w USA, Holandii i Japonii
Po wyłączeniu kompa i włączeniu proton przestaje się uruchamiać.
Konsola mówi to:
File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 39, in __call__ result = self._func(session, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 620, in update_servers_if_needed self.__proton_api.api_request( File "/usr/lib/python3/dist-packages/proton/api.py", line 294, in api_request raise ProtonAPIError(response) proton.exceptions.ProtonAPIError: Invalid access token During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 39, in __call__ result = self._func(session, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 411, in refresh self.__proton_api.refresh() File "/usr/lib/python3/dist-packages/proton/api.py", line 468, in refresh refresh_response = self.api_request( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/proton/api.py", line 294, in api_request raise ProtonAPIError(response) proton.exceptions.ProtonAPIError: Invalid refresh token During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/bin/protonvpn-cli", line 11, in load_entry_point('protonvpn-cli==3.13.0', 'console_scripts', 'protonvpn-cli')() File "/usr/lib/python3/dist-packages/protonvpn_cli/main.py", line 21, in main ProtonVPNCLI() File "/usr/lib/python3/dist-packages/protonvpn_cli/cli.py", line 65, in __init__ res = getattr(self, args.command)() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_cli/cli.py", line 133, in connect return self.cli_wrapper.connect(args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_cli/cli_wrapper.py", line 261, in connect servername, protocol = self.dialog.start() ^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_cli/cli_dialog.py", line 48, in start self.servers = self.session.servers ^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 675, in servers self.update_servers_if_needed() File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 42, in __call__ self.__handle_api_error(e, session, *args, **kwargs) File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 69, in __handle_api_error return getattr( ^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 154, in _handle_401 session.refresh() File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 42, in __call__ self.__handle_api_error(e, session, *args, **kwargs) File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 69, in __handle_api_error return getattr( ^^^^^^^^ File "/usr/lib/python3/dist-packages/protonvpn_nm_lib/core/session/session.py", line 207, in _handle_10013 raise APISessionIsNotValidError(error) protonvpn_nm_lib.exceptions.APISessionIsNotValidError: Invalid refresh token
Przywracam z migawki i wszystko jest ok!
Wyniki z konsoli proszę wklejać tu na forum lub na publiczne serwisy zewnętrzne typu pastebin.
