Jak w tytule: teamviewer nie uruchamia GUI - aktualna wersja, pobrana ze strony producenta, bibliotek nie brakuje.
Menadżer okien Openbox, Debian aktualny.
Ktoś korzysta z tv na Debianie?
$ ./teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
Network process started (10229)
Launching TeamViewer GUI ...
W logu pełno błędów:
2020/04/25 20:35:11.011 10229 140603532504192 N Logger started.
2020/04/25 20:35:11.012 10229 140603532504192 N Found 0 stack dump files ...
2020/04/25 20:35:11.012 10229 140603532504192 N Found 0 core dump files ...
2020/04/25 20:35:11.012 10229 140603526866688 N+ Thread: SystemBusIO0
2020/04/25 20:35:11.012 10229 140603518473984 N+ Thread: SystemBusIO1
2020/04/25 20:35:11.013 10229 140603532504192 N systemd: logind service available
2020/04/25 20:35:11.014 10229 140603532504192 N systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=1]
2020/04/25 20:35:11.015 10229 140603532504192 N+ DBus: optional property DefaultControlGroup not found
2020/04/25 20:35:11.015 10229 140603532504192 N+ DBus: optional property KillProcesses not found
2020/04/25 20:35:11.016 10229 140603532504192 N LogindSessionInfo: New session LogindSessionInfo [id=1 user=jacek state=user active=1 reliable=1 infoId=2212294583] [path=/org/freedesktop/login1/session/_31 TTY=tty1 seat=seat0 display= vtnr=1 owner=[SysUser: jacek [uid=1000, gid=1000 home=/home/jacek gecos=jacek,,, shell=/bin/bash]] idle=1(1587831487000644) active=1 type=tty class=user state=active timestamp=1587831488507177 service=login defaultCG= leader=542 audit=1 remote=0 rHost= rUser= killProc=0]
2020/04/25 20:35:11.017 10229 140603532504192 N SysSessionInfoManager: observing sessions from logind is marked as reliable
2020/04/25 20:35:11.017 10229 140603532504192 N+ logind: session info '1' is for VT 1, skipping.
2020/04/25 20:35:11.017 10229 140603532504192 N SysSessionInfoManager: Session Information provided by VT [priority: 2]
2020/04/25 20:35:11.017 10229 140603532504192 N! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2020/04/25 20:35:11.018 10229 140603532504192 N!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.018 10229 140603532504192 N Starting as network
2020/04/25 20:35:11.019 10229 140603532504192 N Using systemd-logind for suspend/resume monitoring
2020/04/25 20:35:11.019 10229 140603532504192 N! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
2020/04/25 20:35:11.020 10229 140603532504192 N! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
2020/04/25 20:35:11.021 10229 140603532504192 N IdentityManagement: Load ManagerIDs from local Storage:
2020/04/25 20:35:11.022 10229 140603532504192 N System uptime: 8227 seconds
2020/04/25 20:35:11.022 10229 140603532504192 N SystemID m=1 s=0 e8b506057f1847938013d4444ba0c552
Start: 2020/04/25 20:35:11.022 (UTC+2:00)
Version: 15.4.4445 NI
Loglevel: Info (100)
License: 0
Server: master5.teamviewer.com
IC: -368753726
CPU: Intel(R) Core(TM) i3-4130T CPU @ 2.90GHz
CPU extensions: l9
OS: Lx Debian bullseye/s (x86_64)
IP: 192.168.1.111
MID: -368753726_3b7a42c89_8c7e31bc810cf781
MIDv: 0
Proxy-Settings: Type=0 IP= User=
2020/04/25 20:35:11.023 10229 140603532504192 N NetWatchDogLinux: using RTLink event handler
2020/04/25 20:35:11.023 10229 140603532504192 N RemoteSettingsMDRelationshipWatchDog: DEVICE ISN'T A MANAGED DEVICE
2020/04/25 20:35:11.023 10229 140602867971840 N RemoteSettingsStore: Cleanup all policies.
2020/04/25 20:35:11.023 10229 140603532504192 N RemoteSettingsStoreListener: Establish connection.
2020/04/25 20:35:11.023 10229 140602867971840 N RemoteSettingsStore::LoadLastReceivedPolicies : Storage Entry Remote_Settings_RemoteManagement_Policy empty
2020/04/25 20:35:11.023 10229 140602867971840 N RemoteSettingsStore::LoadLastReceivedPolicies : Storage Entry Remote_Settings_TVClientSetting_Policy empty
2020/04/25 20:35:11.023 10229 140603532504192 N Using IPC-Port 7239
2020/04/25 20:35:11.023 10229 140602867971840 N RemoteSettingsMDRelationshipWatchDog: DEVICE ISN'T A MANAGED DEVICE
2020/04/25 20:35:11.024 10229 140603270625024 N OSSessionEventTranslatorLinux::RegisterSessionEvents(): Start observing session events
2020/04/25 20:35:11.024 10229 140603270625024 N!! OSSessionEventTranslator: No session info available.
2020/04/25 20:35:11.024 10229 140603270625024 N NetworkControl::UpdateOnlineState alwaysOnline=0 delayOffline=0 otherProcess=0 restart=0
2020/04/25 20:35:11.543 10193 140166031134144 G Logger started.
2020/04/25 20:35:11.543 10193 140166031134144 G Found 0 stack dump files ...
2020/04/25 20:35:11.543 10193 140166031134144 G Found 0 core dump files ...
2020/04/25 20:35:11.544 10193 140166031134144 G systemd: logind service available
2020/04/25 20:35:11.545 10193 140166031134144 G systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=1]
2020/04/25 20:35:11.546 10193 140166031134144 G LogindSessionInfo: New session LogindSessionInfo [id=1 user=jacek state=user active=1 reliable=1 infoId=2212294583] [path=/org/freedesktop/login1/session/_31 TTY=tty1 seat=seat0 display= vtnr=1 owner=[SysUser: jacek [uid=1000, gid=1000 home=/home/jacek gecos=jacek,,, shell=/bin/bash]] idle=1(1587831487000644) active=1 type=tty class=user state=active timestamp=1587831488507177 service=login defaultCG= leader=542 audit=1 remote=0 rHost= rUser= killProc=0]
2020/04/25 20:35:11.547 10193 140166031134144 G SysSessionInfoManager: observing sessions from logind is marked as reliable
2020/04/25 20:35:11.548 10193 140166031134144 G SysSessionInfoManager: Session Information provided by VT [priority: 2]
2020/04/25 20:35:11.548 10193 140166031134144 G! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2020/04/25 20:35:11.549 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.549 10193 140166031134144 G Running on Qt 5.12.5
2020/04/25 20:35:11.568 10193 140166031134144 G Initialised XRandR extension 1.5 (base=89 error=147)
2020/04/25 20:35:11.597 10193 140166031134144 G MonitorInfo: [XRandR 1.2] CRTC HDMI2 1920x1080@60Hz [0, 0, 1920, 1080] - 1
2020/04/25 20:35:11.597 10193 140166031134144 G MonitorInfo: [XRandR 1.2] CRTC 1 has no outputs
2020/04/25 20:35:11.597 10193 140166031134144 G MonitorInfo: [XRandR 1.2] CRTC 2 has no outputs
2020/04/25 20:35:11.598 10193 140166031134144 G Virtual Desktop [0, 0, 1920, 1080]
2020/04/25 20:35:11.598 10193 140166031134144 G MonitorInfo: [XRandR 1.2] CRTC HDMI2 1920x1080@60Hz [0, 0, 1920, 1080] - 1
2020/04/25 20:35:11.598 10193 140166031134144 G MonitorInfo: [XRandR 1.2] CRTC 1 has no outputs
2020/04/25 20:35:11.598 10193 140166031134144 G MonitorInfo: [XRandR 1.2] CRTC 2 has no outputs
2020/04/25 20:35:11.604 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.614 10193 140166031134144 G!! ResourceLoader: loaded file '/home/jacek/teamviewer/tv_bin/resources/TVResource_pl.so' version () is not matching with application version (15.4.4445), Errorcode=11
2020/04/25 20:35:11.614 10193 140166031134144 G Loaded language 'pl', using locale 'pl'
2020/04/25 20:35:11.614 10193 140166031134144 G InterProcessBase::SecureNetwork created
2020/04/25 20:35:11.615 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.616 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.618 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.619 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.620 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.621 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.621 10193 140166031134144 G AutoLogin::Login: enabled: 1
2020/04/25 20:35:11.621 10193 140166031134144 G AccountLoginStateMachine::Reset
2020/04/25 20:35:11.622 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.622 10193 140166031134144 G!! ApplicationLookOfflineState::ApplicationAppearanceOfflineState: state not loaded, Errorcode=11
2020/04/25 20:35:11.623 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.623 10193 140166031134144 G!!!Own session could not be resolved, unable to startup, Errorcode=11
2020/04/25 20:35:11.624 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.624 10193 140166031134144 G Chat::Stop: Stopping chat
2020/04/25 20:35:11.626 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.627 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.629 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.630 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G InterProcessBase::ShutdownIPC: Shutdown IPC
2020/04/25 20:35:11.632 10193 140166031134144 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 9 failed with error 2, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 5 failed with error 2, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 6 failed with error 2, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 14 failed with error 2, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 10 failed with error 2, Errorcode=11
2020/04/25 20:35:11.632 10193 140166031134144 G interprocessbase::SecureNetwork destroyed
2020/04/25 20:35:11.635 10193 140166031134144 G Shutting down DBus IOHandler
Cześć, edycja:
Jeśli chodzi o:
Teraz większy problem:
(w pliku ~/.profile mam po prostu startx, a autologowanie przez getty@tty1.service )
i wolałbym by tak pozostało,
a wygląda na to, że to jest przyczyna tego błędu: https://www.reddit.com/r/voidlinux/comm ... r_to_work/
Może ktoś ma jakiś pomysł co z tym zrobić?
