Mysql problem z włączeniem usługi
filipo767
Post autor: filipo767 »
Przywróciłem pliki z kopi zapasowej folderu /var/lib/mysql gdzie była moja baza danych. Po restarcie całkowitym maszyny nie można się zalogować i włączyć usługi mysql z terminala.
Oto wykaz z dziennika logów. Nie mam pojęcia o co chodzi,proszę o pomoc
See "systemctl status mariadb.service" and "journalctl -xe" for details.
root@138-201-178-164:/var/run/mysqld# journalctl -xe
-- Logs begin at Sat 2019-02-02 11:02:10 CET, end at Sat 2019-02-02 11:15:52 CET
Feb 02 11:02:10 138-201-178-164 systemd-journald[46]: Journal started
-- Subject: The journal has been started
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The system journal process has started up, opened the journal
-- files for writing and is now ready to process requests.
Feb 02 11:02:10 138-201-178-164 systemd-journald[46]: Runtime journal (/run/log/
journal/e99f11664be0498a9058bec3da43b127) is 8.0M, max 409.6M, 401.6M free.
-- Subject: Disk space used by the journal
-- Runtime journal (/run/log/journal/e99f11664be0498a9058bec3da43b127) is curren
tly using 8.0M.
-- Maximum allowed usage is set to 409.6M.
-- Leaving at least 614.4M free (of currently available 3.9G of disk space).
-- Enforced usage limit is thus 409.6M, of which 401.6M are still available.
-- The limits controlling how much disk space is used by the journal may
-- be configured with SystemMaxUse=, SystemKeepFree=, SystemMaxFileSize=,
-- RuntimeMaxUse=, RuntimeKeepFree=, RuntimeMaxFileSize= settings in
-- /etc/systemd/journald.conf. See journald.conf(5) for details.
Feb 02 11:02:10 138-201-178-164 systemd[1]: systemd-journal-flush.servic
e: Failed to set invocation ID on control group /system.slice/systemd-journal-fl
ush.service, ignoring: Operation not permitted
Feb 02 11:02:10 138-201-178-164 systemd[1]: Starting Flush Journal to Persistent
 Storage...
-- Subject: Unit systemd-journal-flush.service has begun start-up
