Zauważyłem, że nie wyłącza mi się ekran ani komputer nie przechodzi w stan wstrzymania mimo iż to mam tak ustawione. Jedynie jak pokrywa laptopa zostanie zamknieta to przechodzi w stan wstrzymania.
root@debian:/home/rafal# cat /etc/debian_version
9.3
root@debian:/home/rafal# xfce4-power-manager -V
Xfce Power Manager 1.4.4
Part of the Xfce Goodies Project
http://goodies.xfce.org
Licensed under the GNU GPL.
root@debian:/home/rafal# ps -ef | grep xfce4-power-manager
rafal 1300 1 0 sty04 ? 00:00:09 xfce4-power-manager
root 16742 15777 0 15:16 pts/0 00:00:00 grep xfce4-power-manager
root@debian:/home/rafal# xfce4-power-manager -q
root@debian:/home/rafal# xfce4-power-manager --debug --no-daemon
TRACE[xfpm-main.c:192] xfpm_start(): Starting the power manager
(xfce4-power-manager:17314): xfce4-power-manager-WARNING **: Unable to connect to session manager : Nie udało się połączyć z menadżerem sesji: SESSION_MANAGER environment variable not defined
TRACE[xfpm-xfconf.c:631] xfpm_xfconf_init(): lock screen FALSE
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for general-notification
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for critical-power-level
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for show-brightness-popup
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for handle-brightness-keys
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for critical-power-action
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for hibernate-button-action
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for sleep-button-action
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for brightness-level-on-ac
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for brightness-level-on-battery
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for brightness-slider-min-level
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for dpms-enabled
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for dpms-on-battery-sleep
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for dpms-on-battery-off
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for dpms-sleep-mode
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for inactivity-on-battery
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for inactivity-sleep-mode-on-ac
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for inactivity-sleep-mode-on-battery
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for brightness-on-ac
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for brightness-on-battery
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for network-manager-sleep
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for logind-handle-power-key
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for logind-handle-suspend-key
TRACE[xfpm-xfconf.c:164] xfpm_xfconf_load(): Using default configuration for logind-handle-hibernate-key
TRACE[xfpm-polkit.c:314] xfpm_polkit_init_data(): Using unix session polkit subject
TRACE[xfpm-polkit.c:406] xfpm_polkit_check_auth_intern(): Action=org.freedesktop.login1.power-off is authorized=TRUE
TRACE[xfpm-polkit.c:406] xfpm_polkit_check_auth_intern(): Action=org.freedesktop.login1.reboot is authorized=TRUE
TRACE[xfpm-polkit.c:406] xfpm_polkit_check_auth_intern(): Action=org.freedesktop.login1.suspend is authorized=TRUE
TRACE[xfpm-polkit.c:406] xfpm_polkit_check_auth_intern(): Action=org.freedesktop.login1.hibernate is authorized=TRUE
TRACE[xfpm-power.c:958] xfpm_power_get_power_devices(): Power device detected at : /org/freedesktop/UPower/devices/line_power_AC
TRACE[xfpm-power.c:916] xfpm_power_add_device(): 'line-power' device added
TRACE[xfpm-power.c:958] xfpm_power_get_power_devices(): Power device detected at : /org/freedesktop/UPower/devices/battery_BAT0
TRACE[xfpm-power.c:916] xfpm_power_add_device(): 'battery' device added
TRACE[xfpm-power.c:926] xfpm_power_add_device(): Battery device type 'battery' detected at: /org/freedesktop/UPower/devices/battery_BAT0
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 124 : ((XfpmButtonKey) BUTTON_POWER_OFF)
(xfce4-power-manager:17314): xfce4-power-manager-WARNING **: could not map keysym 1008ffa8 to keycode
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 213 : ((XfpmButtonKey) BUTTON_HIBERNATE)
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 150 : ((XfpmButtonKey) BUTTON_SLEEP)
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 233 : ((XfpmButtonKey) BUTTON_MON_BRIGHTNESS_UP)
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 232 : ((XfpmButtonKey) BUTTON_MON_BRIGHTNESS_DOWN)
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 244 : ((XfpmButtonKey) BUTTON_BATTERY)
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 238 : ((XfpmButtonKey) BUTTON_KBD_BRIGHTNESS_UP)
TRACE[xfpm-button.c:183] xfpm_button_xevent_key(): Grabbed key 237 : ((XfpmButtonKey) BUTTON_KBD_BRIGHTNESS_DOWN)
TRACE[xfpm-battery.c:189] xfpm_battery_refresh_icon(): Battery state 4
TRACE[xfpm-battery.c:240] xfpm_battery_refresh_icon(): Battery icon xfpm-primary-charged
TRACE[xfpm-power.c:958] xfpm_power_get_power_devices(): Power device detected at : /org/freedesktop/UPower/devices/mouse_0003o046DoC52Fx0002
TRACE[xfpm-power.c:916] xfpm_power_add_device(): 'mouse' device added
TRACE[xfpm-power.c:926] xfpm_power_add_device(): Battery device type 'mouse' detected at: /org/freedesktop/UPower/devices/mouse_0003o046DoC52Fx0002
TRACE[xfpm-battery.c:189] xfpm_battery_refresh_icon(): Battery state 2
TRACE[xfpm-battery.c:240] xfpm_battery_refresh_icon(): Battery icon input-mouse080
TRACE[xfpm-power.c:214] xfpm_power_check_polkit_auth(): using logind suspend backend
TRACE[xfpm-power.c:1449] xfpm_update_blank_time(): Timeout: 10
TRACE[xfpm-power.c:1463] xfpm_power_change_presentation_mode(): presentation mode FALSE, changing to TRUE
TRACE[xfpm-dpms.c:337] xfpm_dpms_inhibit(): dpms inhibited TRUE
TRACE[xfpm-power.c:1449] xfpm_update_blank_time(): Timeout: 0
TRACE[xfpm-manager.c:643] xfpm_manager_inhibit_sleep_systemd(): Inhibiting systemd sleep: handle-power-key:handle-suspend-key:handle-hibernate-key:handle-lid-switch
(xfce4-power-manager:17314): xfce4-power-manager-WARNING **: Unable to set the kernel brightness switch parameter to 0.
TRACE[xfpm-backlight.c:259] xfpm_backlight_brightness_on_ac_settings_changed(): Alarm on ac timeout changed 9
TRACE[xfpm-backlight.c:280] xfpm_backlight_brightness_on_battery_settings_changed(): Alarm on battery timeout changed 120
TRACE[xfpm-manager.c:753] xfpm_manager_show_tray_icon(): Showing tray icon
TRACE[xfpm-manager.c:731] xfpm_manager_tray_update_icon(): updating icon
TRACE[xfpm-manager.c:717] xfpm_manager_tray_update_tooltip(): updating tooltip
root@debian:/home/rafal# xfce4-power-manager --dump
Xfce power manager version 1.4.4
Obsługuje narzędzia PolicyKit
Obsługuje menedżera sieci
Potrafi wstrzymać działanie komputera: Prawda
Potrafi zahibernować działanie komputera: Prawda
Uprawniony do wstrzymywania: Prawda
Uprawniony do hibernowania: Prawda
Uprawniony do wyłączania: Prawda
Posiada akumulator: Prawda
Posiada panel jasności: Prawda
Posiada przycisk zasilania: Prawda
Posiada przycisk zahibernowania: Prawda
Posiada przycisk wstrzymania: Prawda
Posiada pokrywę ekranu: Prawda
root@debian:/home/rafal# xfconf-query -c xfce4-power-manager -lv
/xfce4-power-manager/blank-on-ac 5
/xfce4-power-manager/brightness-switch 0
/xfce4-power-manager/brightness-switch-restore-on-exit 1
/xfce4-power-manager/dpms-on-ac-off 7
/xfce4-power-manager/dpms-on-ac-sleep 6
/xfce4-power-manager/inactivity-on-ac 15
/xfce4-power-manager/lid-action-on-ac 1
/xfce4-power-manager/lid-action-on-battery 1
/xfce4-power-manager/lock-screen-suspend-hibernate false
/xfce4-power-manager/logind-handle-lid-switch false
/xfce4-power-manager/power-button-action 3
/xfce4-power-manager/presentation-mode true
/xfce4-power-manager/show-tray-icon 1
root@debian:/home/rafal# xset q
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000000
XKB indicators:
00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 500 repeat rate: 33
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 20/10 threshold: 10
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 0 cycle: 0
Colors:
default colormap: 0x20 BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
/usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,built-ins,/usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,built-ins
DPMS (Energy Star):
Standby: 360 Suspend: 0 Off: 420
DPMS is Disabled
