Co tu jest źle? bo jak narazie te wszystkie błedy to dla mnie czarna magia :-o0 ) cvscedega_head
Enter choice:
0
Running Profile : cvscedega_head
/root/.WineCVS/sources/cvscedega/wine
WineCVS.sh - Progress(u) : Green is current
0 = Uninstall
1 = Cleanup
2 = CVS checkout
3 = Configure
4 = Make depend
5 = Make
6 = Make install
7 = Finish up
Checking out CVS ... May take a while
TIP: You can find an applications database on this page:
CVS checkout done... application default x11drvan check the:x
TIP: Useful linux gaming pages:e:rman)ion file.re info..
http://www.linux-gamers.net/rv]orum, as well as a forum for
http://www.linuxgames.com/, and middle-click in browser.
--- You can put things from [x11drv] section heregas.
0 = Uninstall
1 = Cleanup
2 = CVS checkout
3 = Configure
4 = Make depend
5 = Make
6 = Make install
7 = Finish up
Configuring ...
Configure done...
TIP: There is support for easy debug loggin in
cvscedega. Just add "log" as the first
parameter, like this:
cvscedega log -- hl.exe -console
0 = Uninstall
1 = Cleanup
2 = CVS checkout
3 = Configure
4 = Make depend
5 = Make
6 = Make install
7 = Finish up
Making depenencies ...
Make depend done...
0 = Uninstall
1 = Cleanup
2 = CVS checkout
3 = Configure
4 = Make depend
5 = Make
6 = Make install
7 = Finish up
Compiling ...
TIP: You can get basic support for Wine/Cedega by IRC:
Server: irc.freenode.net
--------- Error log - file /root/.WineCVS/sources/cvscedega/ErrorLog : ---------
ts_xlib.c: In function `TSXOpenIM':inehq
ts_xlib.c:1176: error: `XIM' undeclared (first use in this function)
ts_xlib.c:1176: error: syntax error before "r"
ts_xlib.c:1178: error: `r' undeclared (first use in this function)
ts_xlib.c:1178: warning: implicit declaration of function `XOpenIM'
ts_xlib.c:1178: error: `a0' undeclared (first use in this function)
ts_xlib.c:1178: error: `a1' undeclared (first use in this function)
ts_xlib.c:1178: error: `a2' undeclared (first use in this function)
ts_xlib.c:1178: error: `a3' undeclared (first use in this function)
ts_xlib.c: At top level:
ts_xlib.c:1183: error: syntax error before "TSXCheckIfEvent"
ts_xlib.c:1183: error: syntax error before '*' token
ts_xlib.c:1183: warning: type defaults to `int' in declaration of `TSXCheckIfEve nt'
ts_xlib.c:1183: error: `TSXCheckIfEvent' declared as function returning a functi on
ts_xlib.c:1183: warning: type defaults to `int' in declaration of `XPointer'
ts_xlib.c:1183: error: syntax error before "a3"
ts_xlib.c:1186: warning: type defaults to `int' in declaration of `wine_tsx11_lo ck'
ts_xlib.c:1186: error: `wine_tsx11_lock' redeclared as different kind of symbol
../include/ts_xlib.h:19: error: previous declaration of `wine_tsx11_lock'
ts_xlib.c:1186: warning: data definition has no type or storage class
ts_xlib.c:1187: warning: type defaults to `int' in declaration of `r'
ts_xlib.c:1187: error: `r' used prior to declaration
ts_xlib.c:1187: warning: implicit declaration of function `XCheckIfEvent'
ts_xlib.c:1187: error: `a0' undeclared here (not in a function)
ts_xlib.c:1187: error: `a1' undeclared here (not in a function)
ts_xlib.c:1187: error: `a2' undeclared here (not in a function)
ts_xlib.c:1187: error: `a3' undeclared here (not in a function)
ts_xlib.c:1187: error: initializer element is not constant
ts_xlib.c:1187: warning: data definition has no type or storage class
ts_xlib.c:1188: warning: type defaults to `int' in declaration of `wine_tsx11_un lock'
ts_xlib.c:1188: error: `wine_tsx11_unlock' redeclared as different kind of symbo l
../include/ts_xlib.h:20: error: previous declaration of `wine_tsx11_unlock'
ts_xlib.c:1188: warning: data definition has no type or storage class
ts_xlib.c:1189: error: syntax error before "return"
ts_xlib.c:1192: error: syntax error before '*' token
ts_xlib.c: In function `TSXSynchronize':
ts_xlib.c:1194: error: syntax error before '*' token
ts_xlib.c:1196: warning: implicit declaration of function `XSynchronize'
ts_xlib.c:1196: error: `a0' undeclared (first use in this function)
ts_xlib.c:1196: error: `a1' undeclared (first use in this function)
ts_xlib.c:1196: warning: assignment makes pointer from integer without a cast
ts_xlib.c:1201: error: syntax error before '*' token
ts_xlib.c:1203: error: syntax error before '*' token
ts_xlib.c: In function `TS_XInitImageFuncPtrs':
ts_xlib.c:1206: error: `a0' undeclared (first use in this function)
make[1]: *** [ts_xlib.o] Błąd 1
make[1]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/tsx11'
make: *** [tsx11/libwine_tsx11.so] Błąd 2
Error in Make
Try fixing the error based on the output above, and
run the script again, without paramaters (Eg: WineCVS.sh)
Próbowałem też z wine ale tam to nie wiem co jest grane - zainstalowało się wszystko ok, skonigurowałem i próbuje coś uruchomić. Gdy tylko wydam polecenie żeby uruchomił jakiś plik to wine zaczyna ''szaleć''. Wyskakuje mi mnóstwo komunikatów, że cały czas próbuje otworzyć dany plik. Otwiera mi się KILKASET nowych okien i wszędzie to samo pisze a w dodadku cały klocek muli :-/ Z 10 minut się męczyłem żeby to wyłączyć - w końcu sie udało. Nie chce znowu tego uruchamiać bo jeszcze sobie może system rozwale........Może ktoś już miał podobny problem itp ?
Z góry dzięki za pomoc!
