Ponizej wklejam okno debugowania.
System
K3b Version: 0.12.16
KDE Version: 3.5.3
QT Version: 3.3.6
Kernel: 2.6.16-2-k7
Devices
_NEC DVD_RW ND-3540A 1.01 (/dev/hdd, ) at /media/cdrom0 [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-R; DVD-RW; DVD-R dwuwarstwowa; DVD+R; DVD+RW; DVD+R dwuwarstwowa] [DVD-ROM; DVD-R sekwencyjna; DVD-R dwuwarstwowa sekwencyjna; DVD-RW w trybie ograniczonego zastępowania; DVD-RW sekwencyjny; DVD+RW; DVD+R; DVD+R dwuwarstwowa; CD-ROM; CD-R; CD-RW] [Sesja naraz (SAO); TAO; RAW; SAO/R96R; Surowe/R96R; Ograniczone zastępowanie]
Used versions
cdrecord: 2.1.1a03
cdrecord
/usr/bin/X11/cdrecord: Warning: Running on Linux-2.6.16-2-k7
/usr/bin/X11/cdrecord: There are unsettled issues with Linux-2.5 and newer.
/usr/bin/X11/cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
/usr/bin/X11/cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler
/usr/bin/X11/cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
/usr/bin/X11/cdrecord: WARNING: This causes a high risk for buffer underruns.
scsidev: '/dev/hdd'
devname: '/dev/hdd'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Linux sg driver version: 3.5.27
Error: Cannot gain SYS_RAWIO capability.Is cdrecord installed SUID root?
/usr/bin/X11/cdrecord: Warning: using inofficial version of libscg (debian-0.8debian2 '@(#)scsitransp.c 1.91 04/06/17 Copyright 1988,1995,2000-2004 J. Schilling').
SCSI buffer size: 64512
/usr/bin/X11/cdrecord: This version of cdrecord does not include DVD-R/DVD-RW support code.
/usr/bin/X11/cdrecord: See /usr/share/doc/cdrecord/README.DVD.Debian for details on DVD support.
Cdrecord-Clone 2.01.01a03 (i686-pc-linux-gnu) Copyright (C) 1995-2005 Joerg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to <cdrtools@packages.debian.org>.
The original author should not be bothered with problems of this version.
TOC Type: 1 = CD-ROM
Using libscg version 'debian-0.8debian2'.
Driveropts: 'burnfree'
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : '_NEC '
Identifikation : 'DVD_RW ND-3540A '
Revision : '1.01'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x000A
Profile: 0x002B
Profile: 0x001B
Profile: 0x001A
Profile: 0x0015
Profile: 0x0014
Profile: 0x0013
Profile: 0x0011
Profile: 0x0010
Profile: 0x000A (current)
Profile: 0x0009
Profile: 0x0008 (current)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96R RAW/R96R
Drive buf size : 1343488 = 1312 KB
FIFO size : 4194304 = 4096 KB
/usr/bin/X11/cdrecord: Operation not permitted. Cannot send SCSI cmd via ioctl
Track 01: data 685 MB
Total size: 787 MB (78:03.02) = 351227 sectors
Lout start: 788 MB (78:05/02) = 351227 sectors
cdrecord command:
/usr/bin/X11/cdrecord.mmap -v gracetime=2 dev=/dev/hdd speed=24 -dao driveropts=burnfree -eject -data /home/luksus/freespire_1.0.13.iso
