http://www.sysresccd.org/Main_Page
Strona domowa projektu gdzie mozna sciagnac botowalna (w oparciu aktualnie o kernel 2.6.23 plytke (obraz iso ok ~170Mb) Na plytce zestaw narzedzi pomocnych w przypadku problemow, z komputerem i systemem.
Spis co zawiera (wersja ze strony)
Linux-kernel-2.6.23
SystemRescueCd-0.4.3 is based on linux-2.6.23.14. It was patched in order to add support for the Reiser4 file system, and add the Speakup screen reader for blind people. The precompiled kernel includes a lot of drivers, in order to work for most users.
GParted[1]
is the most interesting feature of this CD. Use this graphical partition tool to see a chart of your hard disk, create, format, delete, and modify partitions. (It can be considered the best free Partition-Magic clone).
GNU-Parted[2]
an excellent text based partitioning tool.
Sfdisk
sfdisk is a partition table tool. You can save and restore your partition table from/into a file. Even logical partitions are supported. For example, sfdisk -d /dev/hda > hda-backup will make a backup, and cat hda-backup | sfdisk /dev/hda will restore your partition table. It's very useful if you make an error with parted. Don't keep the backup on the hard disk of course! You need to copy the backup to another computer, or to any removable media.
TestDisk[3]
searches for lost partitions. It supports reiserfs, ntfs, fat32, ext2/3 and many others
Partimage-0.6.6[4]
saves/restores partitions of your hard disk into an image file. If you have a problem with your hard disk (virus, crash, error), you can restore it without having to reinstall the OS. (Ghost/DriveImage clone)
GRUB[5] / LILO[6]
are the most common bootloaders used with Linux. You can restore your bootloader from this SystemRescueCd. For example, if Windows removed GRUB, you can run grub from this CD, and reinstall this bootloader.
File System tools
Each file system has its own tools. For example XFS provides xfsprogs. It allows the user to format an existing partition, to resize another one, ... We provide reiserfsprogs for ReiserFS, Reiser4progs, xfsprogs for XFS, jfsprogs for JFS, e2fsprogs for ext2/ext3, ntfsprogs for NTFS, dosfstools for FAT/VFAT.
EVMS
(Enterprise Volume Management System) is a powerful logical volume manager. It allows you to manage the space of your hard disk with a more powerful approach than partitions.
Archiving tools
Of course, tar/gzip/bzip2 are provided for Unix users. This CD also contains zip/unzip, rar/unrar/unace for Windows users. It allows users to backup/restore their data from this bootable disc. We also added Dar (Disk Archiver). It's like tar but it's a lot more powerful.
Editors
During a system rescue, you may need to edit system files. We provide nano (a lightweight editor), vim-6.2[7] (VI Improved), qemacs (emacs clone), elvis and joe. You can also use Leafpad, a graphical text editor under X.Org.
Midnight Commander
MidnightCommander (mc) is a NortonCommander clone for Linux. It is very easy to use, and allows you to browse all the files on your hard disk. You can copy, rename, delete, move, search and edit files.
CD/DVD burning tools
You can use the cdrecord packages, that comes with mkisofs. It is the linux standard CD burning command from console. Mkisofs allows you to create an ISO image file to use with cdrecord. Cdw is a text based front end to make cdrecord and mkisofs easier to use. Udftools are provided for packet writing. Now, you can also use dvd+rwtools. This package makes DVD burning possible.
Network File Tools
We also provide basic network tools in order to allow you to exchange data with other computers. You can use ftp, ssh (client and server), ppp(connect to the internet), lynx (console web browser). LUFS (Linux Userland File System), NFS, and Samba mount -t smbfs //ip/share /mnt/path allow you to mount remote file systems
Network admin tools
Many standard network administration tools are provided: DNS-tools (such as nslookup), nmap (network exploration), netcat (network piping tool).
Security tools
Chkrootkit searches for a rootkit installed on your system (rootkit is a package installed by a hacker that allows them to hack it).
Anti-virus
Clam-AntiVirus[8] is a free sofware Anti-Virus. You can update the definitions from the CD-ROM, and scan your system for a virus.
Web browsers
Two lightweight web browsers are provided: lynx and links . They are useful if you need to have a look at a detailed documentation during your usage of the system. In FrameBuffer mode, the links web browser can be used as a graphical browser that shows images, and it has a nice GUI. You have to give options to the command line of the program in order to have the graphical mode enabled.
NTFS-3g[9]
allows mounting NTFS partitions with full Read and Write support. Read the manual for informations about how to use it. (In SystemRescueCd version 0.3.x, NTFS-3g replaces CaptiveNTFS).
Python-2.4[10]
is a very powerful and easy to use multi-paradigm high-level programming language, that supports Oriented Object Programming.
Perl-5.8[11]
is a powerful and free language. Many administration scripts, and many programs are written in perl.
Secure Deletion
Several wiping tools (such as shred and wipe) ensure that files are really erased from your hard disk.
Misc Tools
md5deep calculates the MD5 sum in subdirectories
System boot disks
The CD comes with many floppy disk images. These can be used as real boot floppy disks. They provide many important services. Here is a list of the provided disks:
FreeDos[12] allows running DOS programs without MS-DOS
MemTest+ test the physical memory, and tells if it is damaged or not
Gag (Graphical Boot Manager)[13] an easy to use Boot manager (such as LILO)
Ranish Partition Manager a bootable partition editor
Aida a powerful hardware enumeration/diagnostic/discovery tool (as sandra)
System Rescue CD
Jak byk napisane na zrzucie ekranu:
Window Maker.
Poza tym, w detailed-package-list:
Window Maker.
x11-wm windowmaker-0.92.0-r3
